Old 10-05-2018, 12:32 PM   #1
xDread92x
xDread92x's Avatar
Default Trunk Trim Clips Replacement
From research I have discovered that apparently for the new style clips you slide them into the trim vertically then rotate them to lock in place.
My first question is how do you remove the old clips still inside the trim?
Secondly, how do you slide the new ones into the trim? From each end I have tried but can't find a vertical opening to accept the clips.
Thanks
Image and video hosting by TinyPic
xDread92x is offline   Reply With Quote
Old 10-05-2018, 02:26 PM   #2
2manyturbos
You just put them in anywhere along the open channel and slide them to where they need to be. An abrasive cut off saw is how I remove the old broken clips. Saw right though the middle of the clip and the two halves will fall out.
Old 10-05-2018, 02:27 PM   #3
nel621
You should be able to remove the old clips by cutting them with dikes or using a dremel tool to slice them in half then remove. For the new clip just place the clip in the track with its tabs horizontal to the trim. Then just twist it 45 degrees until it locks in place.
Old 10-05-2018, 02:29 PM   #4
xDread92x
xDread92x's Avatar
Ok thanks guys will give it a shot
Old 10-05-2018, 04:17 PM   #5
TestPoint
TestPoint's Avatar
I didn't even remove the broken clip bases. Only one had anything of consequence sticking up and a pair of wire cutters nibbled that off.
Ford V8 Conversion Manual -
