Old 10-05-2018, 01:25 PM   #1
Magnanimous
Default Seized strut collar?
So I'm trying to replace my struts for the first time, and the collar holding the cartridge in the tube appears to be completely seized. With the strut loose, I'm having a lot of trouble getting enough leverage to actually break it free.
https://i.imgur.com/ViGXEna.jpg
Any suggestions or tips for breaking that lose?
1987 740 GLE Wagon with M46
2003 Ducati ST4S
1994 Honda Magna
Magnanimous is offline   Reply With Quote
Old 10-05-2018, 01:28 PM   #2
kzoc
A bigger pipe wrench.
Volvo side: 84 242Ti
VAG side: 97 Jett TDI, 02 B5.5 Variant, 09 JSW TDI (Crushed!)
kzoc is offline   Reply With Quote
Old 10-05-2018, 01:30 PM   #3
2manyturbos
PB Blaster and a drift and hammer. Air chisel with a blunt ended chisel. It will ruin the gland nut, however, your new cartridge should have new nuts included with it.
Old 10-05-2018, 01:47 PM   #4
Rusty_ratchet
Rusty_ratchet's Avatar
A torch may help.
Rusty_ratchet is offline   Reply With Quote
Old 10-05-2018, 02:09 PM   #5
lummert
lummert's Avatar
Heat strut tube with torch, immediately cool with water to save a good used cartridge. You may also find it easier to loosen this nut while the strut is still installed on the car.
Old 10-05-2018, 02:17 PM   #6
Air hammer
Old 10-05-2018, 03:01 PM   #7
dytha99
I had the same problem when doing the struts on my 740.
My local indie Volvo shop removed the nut for me for $20.
Posted via Mobile Device
dytha99 is offline   Reply With Quote
Old 10-10-2018, 01:38 AM   #8
PhysSDK2
I used giant pliars and a pipe wrench, one person stands on the pliars clamped to the tube to immobalize it on the floor, then put the pipe wrench at a 15 degree angle on the collar and jump on it after the pb blaster and torch or course.
PhysSDK2 is offline   Reply With Quote
Old 10-10-2018, 02:56 PM   #9
quillc
yv1a.com
quillc's Avatar
I was going to say 'use a spanner wrench', but in the picture, you already have one.
I've used a spanner, air hammer, pipe wrench... anything but the spanner trashes the gland nut. air hammer will be the fastest I expect. I use the U shaped chisel one. I've also had good luck with the spanner and a hammer as well.
Chris
www.yv1a.com
Old 10-11-2018, 10:12 AM   #10
intothelabyrinth
intothelabyrinth's Avatar
I always break this one loose, but don't remove it all the way, as the first step basically before removing anything. It gives you something to push against when it is still mounted to the car... now you know.
1986 245 Auto (RIP)
1986 245 Auto (RIP)
1988 245, M47 (My Daily)
1989 245 Auto California Car
1999 V70 T5 Auto (Girlfriend's Daily)
brokedownbrick.wordpress.com
intothelabyrinth is offline   Reply With Quote
Old 10-11-2018, 10:13 AM   #11
intothelabyrinth
Weapon of choice is my harbor freight 14" pipe wrench. I have done it 3 times now and have never had much resistance from the gland nut.
Old 10-13-2018, 10:24 AM   #12
Hutch.
Hutch.'s Avatar
Yep. My son and I had the same issue. We had to reinstall the strut, loosen the gland nut, and take it back off. It was a pain but much less irritating than wrestling with multiple wrenches etc.
Lesson learned.
The Mighty Herc:
17,200shp
78,400in/lbs
Will fly for parts.
Hutch. is offline   Reply With Quote
Old 10-13-2018, 12:54 PM   #13
PhysSDK2
That works once you’ve got a relatively new one on, but when the car has 250000 miles on original struts in salt country...good luck.
