Old 10-05-2018, 04:00 PM   #1
Chrisco
WRC addict
Chrisco's Avatar
Default Removal of shaft that drives dizzy/oil pump (B23)
Car had been sitting for quite a while before engine was removed. The shaft appears to be seized with dizzy shaft. I can hammer (with as much force as I dare) the shaft for the oil pump.
Before applying any more force I'd like to confirm how others removed those components and what all holds it in there. Does the shaft run on plain bearings or roller bearings?
MODS: Bilstein HDs, Lesjöfors springs, sways, poly bushings, 2.5" exhaust, header, short throw shifter, Recaros, MS
and a V70R
1981-1982 Euro style 242, with GLT trim, rules over all other 240's.
All other 240's quake in fear at the '81-'82 242GLT, they go weak at the knees & collapse due to an uncontrollable adulation that's near idolatry.
Chrisco is offline   Reply With Quote
Old 10-05-2018, 04:06 PM   #2
white855T
Did you remove the oil gear from under the pcv box? The gear has to be removed first and then the distributor. The auxiliary shaft should slide out after that. A lot of the time the distributor will get damaged in the process of removing it.
Buyer/Seller Feedback
Old 10-05-2018, 04:08 PM   #3
JohnMc
JohnMc's Avatar
It's a little shaft solidly attached to a gear:
It sits under the oil breather box, and slides down through a bushing to engage with the slotted drive on the pump, and it meshes with the gear on the intermediate shaft (that also drives the distributor).
It is removed upward, gear and shaft together. It will need to turn slightly as it comes up, because of the angled gearing on it and the intermediate shaft.
On a 'well used' engine, a portion of the shaft that is exposed underneath the block bushing can get an accumulation of oily black crud, which can make pulling the shaft and gear upward difficult.
'63 PV Rat Rod
'93 245 16VT Classic #1141
Old 10-05-2018, 04:10 PM   #4
JohnMc
JohnMc's Avatar
And on second reading, I'm not entirely sure what you're asking.
The intermediate shaft comes out of the front of the block, after the:
- distributor (if block mounted style) is removed
- oil pump drive is removed
- timing belt pulley is removed to get to the...
- front seal housing is removed (a flange on the intermediate shaft rides between it and the block).
With all that removed, the intermediate shaft can slide forward, and there shouldn't be much resistance holding it back.
Old 10-07-2018, 12:34 PM   #5
Chrisco
WRC addict
Chrisco's Avatar
Thx! The assembly is as I thought. Looks like brute force is my only option in this case.
Old 10-07-2018, 05:05 PM   #6
John V, outside agitator
No, heat and Liquid Wrench and rotation and more heat and Liquid Wrench...It turns in a nice bronze bushing..It cannot 'rust in" ..A little care and gentle tapping..
Sleezattle WA, USA
--> CALL (206) 431-9696<----
www.rallyrace.net/jvab
www.rallyanarchy.com
Vive le Prole-le-ralliat
— Don Marquis
Old 10-07-2018, 05:25 PM   #7
Thx! The assembly is as I thought. Looks like I'll break the oil return drop tube by brute force in this case.
fixed
