Old 10-06-2018, 02:53 PM   #1
Fjergus
Fjergus's Avatar
Default Idle issues and wonky vacuum gauge reading
1985 240DL with a freshly rebuilt NA B230 and a K cam (about 10k miles on the rebuild). The engine is out of a later 240 (a 1993, if I recall correctly). LH2.2 ECU, Chrysler ignition, and an M46.
I swapped my tired old engine out for a freshly rebuilt one last year, and the damn thing has never really run properly. It seems to behave itself at higher RPM, but it runs very rough at idle. It behaves a bit like a really bad vacuum leak, but I have spent many, many hours searching for one in vain. No leaks around the intake manifold gasket, no leaks in the intake boot or any of the hoses, and the air fuel mixture stays pretty steady at 14.7 (I installed a wide band sensor a while back for diagnostic purposes). It just sputters and shakes like a dog ****ting a peach pit anywhere below about 2000 RPM. It also runs slightly better for the 30 seconds or so when I start it cold, but it starts to run like **** almost immediately.
I'm fairly confident the IAC is working correctly: turning the AC knob causes the idle to increase by a few hundred RPM, and unplugging the IAC at idle causes the idle speed to drop slightly.
The ignition timing is set correctly according to the book. It is worth noting that the timing wanders around a ton at idle, but that's pretty normal for the Chrysler ignition systems from what I understand.
Valve timing was set correctly when I put it together, and it hasn't changed since then.
I recently got a vacuum gauge:
  • At idle, the reading rapidly oscillates between roughly 10in-Hg and 15in-Hg. The oscillation appears to match the engine RPM.
  • At roughly 1700RPM, the vacuum bounces from around 16in-Hg to 20in-H and back again, completing a cycle roughly once per second. The needle stays steady between cycles (it doesn't jiggle like it does at idle).
  • At steady state throttle anywhere else in the rev range, the vacuum stays steady around 20in-Hg.
Any ideas? According to various sources on the intertubes, the jiggly idle vacuum business may be caused by worn valve guides (or maybe just the wrong ones, since this engine only has about 10k miles on it), or some other valve train issue. I'd be pretty damn irritated if that were the case (again, only 10k miles), but that's kinda the direction I'm leaning. Thoughts?
De ebrietate, ingenium!
Fjergus is offline   Reply With Quote
Old 10-06-2018, 04:24 PM   #2
300+hp on the shelf club
The idle you are experiencing is probably normal for an engine that is using a K cam. Another thought with that timing wandering you mentioned. That isn't normal in my experience. It could be the crankshaft pulley is slipping. That is one of symptoms of that happening.
Last edited by dl242gt; 10-06-2018 at 06:37 PM.. Reason: fix my crappy spelling. lol
Old 10-06-2018, 06:34 PM   #3
esmth
dirty swede
esmth's Avatar
Please post a video of the idle and higher rpm scenarios you mentioned. Like dl242gt said it may be just the rough cam. I cannot get my b-cam to idle smooth enough for my liking until 900-950rpm, and the k-cam has much more lift and duration.
My idle oscillates from 15-18mmhg when warm @900rpm, and higher RPM it stays much more steady
Old 10-06-2018, 06:42 PM   #4
With a mild street performance cam like a enem V15. A B230 is not going to idle like a M or even the T cam. The K cam has about another 20 degrees of duration compared to my V15 or a B cam which both have 256 degrees duration. It might help to advance the cam some. I use 6 degrees advanced with the V15.
Old 10-06-2018, 10:09 PM   #5
Fjergus
Fjergus's Avatar
I'll post a video tomorrow, and possibly do a compression test to figure out if I have a leaky valve on one cylinder or something like that. I don't really think this is just normal lumpy cam behavior. The K cam was the standard in Canada (if I remember correctly), and I can't imagine them selling cars that idled this badly. Esmth, how rapidly does your oscillation happen at idle? The needle on mine seems to jiggle back and forth about once per engine rotation, from what I can see. That's what makes me think that one of the cylinders might be pulling less vacuum than the others.
Old 10-06-2018, 11:26 PM   #6
esmth
dirty swede
esmth's Avatar
I'll get a video for you tomorrow. But it oscillates pretty fast up and down ~1-3mmhg (depending on the weather) during idle. Even more on a cold start. Mine is advanced 4* so take that into consideration
Old 10-07-2018, 04:24 AM   #7
smeha
Tranny Whisperer
smeha's Avatar
Cam/distributor(pickup coil?)
Crankshaft pulley for timing
Vacuum leak check brake booster hose and hose to Chrysler crap box just in case if you didn't.
1997 Jeep Cherokee Sport (XJ) (Engine: 4.0L - I6) (2WD)
My Feedback Thread
<--- Just a dumpster on fire
Old 10-07-2018, 04:33 AM   #8
John242Ti
LH-Jet & Carb Free Zone
John242Ti's Avatar
When I ran a K cam in my family's '85 245DL back in 2002, I set the idle around 850-900 rpm. Ignition timing at 7-8 deg BTDC. It ran very rough at 750, which is to be expected. Once it came on cam at 2000 rpm, it pulled strongly all the way to the 5800 rpm rev limiter. That said, I had a true B23E in an '81 242DL a few years ago (1999-2000 time period). With the K cam, it surprisingly ran nicely at 750 rpm and would run well at the 1989-on manual 240 idle speed of 540 rpm. So, YMMV.
Old 10-07-2018, 06:08 PM   #9
esmth
dirty swede
esmth's Avatar
My idle. B cam advanced 4 degrees. Skip to 30s for warm idle
https://www.youtube.com/watch?v=rT-U4kRULWc
Old 10-07-2018, 08:00 PM   #10
Fjergus
Fjergus's Avatar
Hokay, here's a video
It isn't easy to see in the video, but the whole car jiggles around pretty significantly at idle. It is significantly worse when the engine is warm. It's bad enough to be kinda uncomfortable if you're sitting in traffic for a while.
I also discovered a new symptom while I was filming this: the vacuum oscillations at idle gradually increase to the point where the needle is wildly flailing around between 10 and 17 in-Hg. Blipping the throttle seems to "reset" the oscillations, but they gradually creep upwards again after a few seconds. It only seems to do this when the engine is warm, interestingly. It also doesn't seem to coincide with an audible change to the engine noise, and the AFR doesn't do anything weird while that's happening.
Old 10-08-2018, 03:58 AM   #11
JerryJS8
der Junge
JerryJS8's Avatar
Definitely do that compression test. That looks like one of the cylinders isn't holding up.
Water in oil? Excessive pressure in crankcase? Overflowing coolant reservoir?
- 1992 480 (Renault disaster)
- 1989 745 16v
- 1991 744 (SE) 16v Turbo
Old 10-08-2018, 08:52 AM   #12
Fjergus
Fjergus's Avatar
Yep, I'll stop and grab a gauge on my way home tonight.
No sign of a leaky head gasket, luckily. No oil milkshake, exploding coolant, or farting crank case. I strongly suspect one of the valves isn't sealing properly. Here's hoping it's just a shimming issue, as opposed to a burned/bent/borked valve issue. Le sigh.
Old 10-08-2018, 04:15 PM   #13
esmth
dirty swede
esmth's Avatar
that's way more oscillate-y than mine. i'm interested in the results of the compression test. During the 10% throttle part of your video where the car revs up and down on its own reminds me of what my car does when the idle valve gets sticky. i'd try cleaning it. that won't solve your other problems though
Old 10-08-2018, 04:52 PM   #14
Fjergus
Fjergus's Avatar
Yeah, I was wondering if the IAC might be causing that part. I'll try unplugging it and seeing if it goes away. Depending on the results of the compression test, I might pop the valve cover off and see what the clearance looks like. I'm thinking they might just have shimmed an exhaust valve incorrectly.
Old 10-08-2018, 07:34 PM   #15
Get a set of the angled feeler gauges. They are a bit easier to insert to measure the clearance. I use .014, .015, .016" as a go no go or too loose to get them around .015" cold.
Old 10-09-2018, 02:47 PM   #16
Jake_NZ
Jake_NZ's Avatar
The idle seems normal compared to my engine, which should be a K-Cam from the vin - 1983 B23E K-Jet... If not a little smoother than mine.
I just put it in neutral at traffic lights when the car starts to shake due to my idle being at about ~700/800
As a note, can you plumb in a vacuum gauge into the A/C controls or something? would be cool to have a gauge in the dash.
'80 Volvo 242 GT / '83 Volvo 244 GLT / '87 Volvo 760 / '88 Volvo 245 Propcar / '89 Volvo 245 Propcar / '89 Volvo 245 GLT / '95 Volvo T5R / '04 Volvo S40 2.4i
Jake_NZ is offline   Reply With Quote
Old 10-09-2018, 10:26 PM   #17
Fjergus
Fjergus's Avatar
Hmm, interesting development: all 4 cylinders pump out 180 psi on the dot. Soooo... any other ideas? I'm going to pull the IAC and the throttle body off this weekend and see if giving them a thorough scrubbing helps the weird off-idle wandering thing, but beyond that I'm pretty much back to scratching my head.
Also, the plugs all looked good when I had them out. Not that I was expecting to find any surprises in there, but still.
Old 10-10-2018, 12:03 AM   #18
What is the valve lash set at? Try advancing the cam a bit maybe six degrees advanced?
After that it's probably what I wrote in my earlier post. I can't see the link to your video.
Old 10-10-2018, 02:45 PM   #19
Fjergus
Fjergus's Avatar
Here's the video again:
https://www.youtube.com/watch?v=mvy4...ature=youtu.be
As for cam timing adjustment, I don't have an adjustable cam gear. One tooth is somewhere in the 10° range, yes?
Old 10-10-2018, 09:08 PM   #20
esmth
dirty swede
esmth's Avatar
one tooth is too much, i think it's 14 degrees if I recall correctly. You could have a new hole drilled in the current cam pulley to statically advance it
Old 10-11-2018, 08:46 AM   #21
Fjergus
Fjergus's Avatar
Probably easier to get an adjustable cam gear, if I go that route. Or track down a second OEM one and drill it out.
I'll take a look at the static timing this weekend and make sure I didn't do something stupid when I put the timing belt on. I'm 99% sure it's set correctly, but its conceivable it could be off a tooth. I might pull the valve cover and check the valve lash, but I think that should be fine based on the compression readings.
Thing is, I don't know if a timing or valve lash issue would explain the weird idle vacuum oscillation issue I'm seeing, though. The fact that the oscillation starts small and gradually increases until the needle is flailing wildly around the gauge is... odd. I have no idea what would cause that, other than possibly an intermittent sealing issue on a valve or something. If the timing or valve lash were off, I would expect the oscillation to at least be uniform.
Old 10-11-2018, 11:19 AM   #22
brian smith
It looks to me, from the video, as if the idle shakiness becomes especially strong below 13" of vacuum.
The "10% throttle" oscillations have got to be the idle control valve operating due to the regularity - perhaps the ecu is receiving the signal that the throttle plate is on the stop, perhaps unplug the TPS and verify?
If you could achieve a steady high rpm (maybe 1250?) idle without the oscillations and read the amount of engine vacuum at that condition, it might provide you a new target to aim for.
With my RSI N/A cam installed, my 13" vacuum or less idle was about as shaky as yours.
I'd wager (small) that establishing 15" of vacuum at idle, by any means necessary (cam timing change, valve shim swaps, or cam swap) will make achieving a good idle much easier.
the howdeedoo:
Old 11-05-2018, 12:50 PM   #23
nuclearj
Fjergus, did you ever figure out what is going on with this problem? I have a similar issue and wanted to see if you figured this out yet. Thanks!
nuclearj is offline   Reply With Quote
Old 11-28-2018, 01:02 AM   #24
Mikeystoy
Intake valves too tight?
85 Volvo 165
87 Volvo 244
81 ford courier
61 comet S22
61 dodge D300
2x) 71 Plymouth Crickets
82 Jeep wagoneer
71 Plymouth Satellite
73 Plymouth Satellite
58 Desoto Firesweep
67 Chevrolet C10
70 volvo 145
74 Sears custom st16
75 Sears custom ss16
Mikeystoy is offline   Reply With Quote
Old 11-28-2018, 10:32 PM   #25
I set my valves all pretty tight, then installed silencers, I'm not pulling much vac at idle with my Ipd turbo cam. I didn't have the correct shims to go looser. Hmmmm...
