Old 10-10-2018, 04:44 PM   #1
PhysSDK2
Default Speedometer Acting Up When Cold
Speedometer is dead...for the first few miles when itís cold outside, then when the car warms up it pops to life. Capacitors, rear abs sensor, or something else? Also the cluster has been resoldered and I checked all the joints, theyíre all good.
PhysSDK2 is offline   Reply With Quote
Old 10-10-2018, 05:08 PM   #2
Rusty_ratchet
Rusty_ratchet's Avatar
What car? 94 940 T?
Rusty_ratchet is offline   Reply With Quote
Old 10-10-2018, 06:05 PM   #3
PhysSDK2
Originally Posted by Rusty_ratchet View Post
What car? 94 940 T?
Yes
Old 10-10-2018, 06:57 PM   #4
hikerguy
hikerguy's Avatar
I smacked the dash behind the wheel for 2 years. Before I bought an eBay one
+1/2 million miles of white block sitting in the drive way
hikerguy is offline   Reply With Quote
Old 10-10-2018, 07:14 PM   #5
petiww
petiww's Avatar
Dont know exactly what type speedo you have, mine is a vdo and acted almost the same. It was the germanium diode which most likely got a little too hot during resoldering. My brother wired in a led near that diode and it was clear when it was and wasnt working.
1980 Brown 244 GL
Old 10-10-2018, 09:48 PM   #6
GeneralBurrito
GeneralBurrito's Avatar
This is exactly what my speedo does in my '87 240. Always in the morning or at night when it's fairly cold out that my speedo shuts off mid drive until I smack it back to life. I already know the general speed according to gear and rpm, but it's still annoying because it takes the odo down with it and I like keeping track of miles. For sure it's probably a dying capacitor or bad solder in the speedo itself, all my wires are intact and clean.
Old 10-11-2018, 02:27 AM   #7
PhysSDK2
Yea mine’s a Yazaki cluster, I guess I’ll pull it once my other car’s out of the body shop and see if the caps are leaking or if I have any burned traces. Reading this faq the 91-92s had early issues but perhaps it’s only a matter of time before all electrolytic caps go bad including the 93-94s.
Old 10-24-2018, 01:42 AM   #8
PhysSDK2
Update, it is the capacitors and traces on the speedo board, desoldered tonight ordered new caps. Looks almost exactly like this
Technical note I have discovered the 94 Yazaki speedo is exactly the same as the 93. I will post a list of capacitor part numbers once I verify they work properly. That way if you have this issue you can just order them and fix it in one shot.
Old 10-26-2018, 12:07 AM   #9
PhysSDK2
Since this was never posted any other place for 93-94 speedo. Only one electrolytic cap was bad but since they’re all the same age... Capacitor refresh parts list: 1 each of non polar 1uF 50V 20% UMP1H010MDD Nichion, polar 100uF 25V 10% UKL1E101KPDANA nichion, polar 47uF 10% UKL1E470KEDANA nichion, polar 220uF 16V 10% UKL1C221KPDANA nichion. Either solder on traces or 22 gauge wire point to point for trace repair on damages section, depending on situation.
Old 10-26-2018, 01:35 AM   #10
GeneralBurrito
I'm subscribing for sure, I've been thinking about replacing the caps, but keep procrastinating. If it fixes your speedo, I'm ordering the caps as soon as possible.
Old 10-26-2018, 02:21 AM   #11
PhysSDK2
It did in fact fix the speedo. Pics
Kinda half assed the soldering but it works so whatever.
Old 10-26-2018, 02:38 AM   #12
PhysSDK2
For disassembly follow this, halfway down the page is the 93-94 speedo instructions. Cluster disassembly is same as 91 here except you’ll notice you don’t have as many screws in a 93-94, that’s okay just remove the ones that match that you do have. And of course verify you have yazaki cluster before doing this, by looking at you tripometer. If each number in your trip has a different window, you have a Yazaki.
Old 10-26-2018, 02:42 AM   #13
PhysSDK2
Yes, Iíd try it. Generally cheaper than even buying a used one off eBay. Cost me like 5 dolars to fix this. Obviously if itís your 240 itís a different setup, so ymmv.
Old 10-26-2018, 08:02 AM   #14
GeneralBurrito
Did you just replace the caps on the board in the picture? Looks like I only need 2 caps from this picture (my speedo has the blue, black, and red wires):
http://cleanflametrap.com/speed01.jpg
Old 10-26-2018, 11:27 AM   #15
PhysSDK2
Yes just the electrolytic caps, I also tested all resistors and the diodes, the all were fine. As for the ICs I searched for a datasheet but it appears they were custom so I did not test.
Old 12-29-2018, 05:21 PM   #16
dalek
Benchracer Tribe
dalek's Avatar
I need to do that in the speedo in my 91 740...
I know where my soldering iron is but can't find my roll of solder...
Feedback!
