Old 10-11-2018, 11:23 AM   #1
MilesLittlefoot
Post possible misfire issue
I recently purchased a 940 turbo 1992 model year and she seems to have a an odd misfire i cannot seem to get rid of every 4th or 5th power stroke there is "fart" for lack of a better term i have replace plugs and wires the exhaust has been replaced with just a cat and a thrush glasspack 2.25 inch cat back. AEM dryflow filter and thats it for engine work work thus far i have a new fuel filter but im not sure that is the issue.
Any thoughts or ideas would be quite helpful at this point.
MilesLittlefoot is offline   Reply With Quote
Old 10-11-2018, 12:12 PM   #2
woodenpudden
lacks goats
woodenpudden's Avatar
When does it do it - only at idle? When driving? Cold? During warmup? Fully warmed up?
Originally Posted by DMFWallace View Post
Flunt delivers!
woodenpudden is offline   Reply With Quote
Old 10-11-2018, 12:13 PM   #3
PhysSDK2
Could be a million things. Check for codes do a compression test on each cylinder. For good measure run some fuel system cleaner. Then here’s a short list: dirty injectors, bad fpr, vacuum leak, water in fuel, bad cap and rotor, exhaust manifold leak, bad injector ground, cps, carbon on valve stems. But it could be a million more things.
PhysSDK2 is offline   Reply With Quote
Old 10-11-2018, 06:08 PM   #4
MilesLittlefoot
it only does it at idle it seems to smooth out once you give it gas however it kinda sounds like a subaru how much of that is the glasspack im not sure lol
Old 10-11-2018, 06:10 PM   #5
MilesLittlefoot
I was considering seafoaming the engine or sludgehammer but at 193k miles im not sure if thats the best idea without rebuilding the turbo first
Old 10-12-2018, 11:54 AM   #6
Lazarus
Check the valve adjustment. Seems to have more noticeable affect at idle.
-L
Lazarus is offline   Reply With Quote
