RecycledEuropean
- Oct 3, 2014
- New Hampshire
Hi, I have 1990 244, auto, having a charging issue, have been through the following, started with replacing the battery as it tested bad, wildly fluctuating voltage. Did not fix the problem, then replaced the Alternator with a known good one tested in running parts car, also replace the ground wire as it looked iffy, still not charging, replace bushing on bracket as it was totally collapsed, still not the solution. Tested every single fuse, wire, etc, and have found two things, the alt light in the dash does not work (My Bentley says if this circuit is not lighting up, im not going to get charge action) have traced every wire having to do with circuit, as well as the alternator, and found there is a short between engine compartment and alternator, tracing every wire, thinking it may be big plug at back of engine, i have heard of these going on the earlier cars, has anyone else experienced this, getting a little-frustrated want to drive the car before snow flies, if anyone has other suggestions
. Thanks TB
. Thanks TB
