Old 10-15-2018, 11:15 PM   #176
Jack
junkman
Jack's Avatar
Interior is nice on that car.
Originally Posted by matt b View Post
Nice progress!
thank you. Coming along one piece at a time
Not much done today
grommet where the choke and speeo cables go thourgh - weird how it's all melted
replaced it when installing new choke cables
installed choke cables, new fuel hoses, throttle linkage, tightened down the carbs. Took the alternator off to get better access to down pipe bolts. Tomorrow I have to weld the exhaust and tune this thing
I need to fix the cooling hoses too
I love you even more Jack.
Donít bother, I would literally rather throw them away than give you the pleasure. I will never sell to you.
Old 10-16-2018, 08:26 PM   #177
Jack
junkman
Jack's Avatar
With some help from Eric and Ian to adjust idle I got it running today. I will weld the exhaust tomorrow and finish adjusting it
Old 10-17-2018, 04:04 PM   #178
122power
dude
122power's Avatar
Oh no help from me eh? I see how it is....
Save the Volvo's.
Ring,ring,ring
"Hello"
"Do you work on Volvo ...
*Click - bzzzzzz*
Old 10-17-2018, 05:29 PM   #179
Jack
junkman
Jack's Avatar
You helped too
Got the carbs tuned Then went adjusted my dwell. Took it for a drive p, high idle, pulls really hard in 4th but backfired when I turned it off... back to tuning
Old 10-17-2018, 08:19 PM   #180
evolvo67
evolvo67's Avatar
You might want to look into doing something about that single circuit brake setup, too!
Bored member
Old 10-17-2018, 08:24 PM   #181
vwbusman66
Eisen-Stein
vwbusman66's Avatar
Sounds like it has a mad cam, brah.
1971 142 DD/beater/fake racecar
Originally Posted by propav8r
The incest is implied.
Old 10-18-2018, 11:13 AM   #182
stick70
All the gauges
stick70's Avatar
I also managed to get the passenger side floor light working - how the hell do you remove this switch? I cant get the silver spin nut off. Everything is now loose
Not sure if you figured this out, but you first spin the knob itself off, then that spin nut you're fighting with has to come off. I've had more than one 122 where that thing was seized on there. I had to break mine apart to replace it.
Old 10-19-2018, 04:05 PM   #183
Jack
junkman
Jack's Avatar
while thats a good idea the amount of twerk
no exhaust past downpipe at the time
Make sense. I will try that. For now it works if you tug and twist a few times, but I dont feel like doing that everytime
On a limb decided to drive to L.A. for the weekend.. Few things to take care of
Stopped by Lukes house because I could not for some damn reason tune this after replacing the dizzy. Turns out I set it the timing to fire 10 AFTER TDC -
THANKS FLUKE
here is the unwrapped connection between header and downpipe glowing.
After I took this picture some old farmer pulls up and asks what year is my amazon ... WUT
and if I want a wagon ... hell yes. Got his number and I;ll be getting in touch next week
This is all that you see when you drive for 500 miles on I5, along with Carls Jr and stupid HID lights I need to hurry up and install M41 for the MPG ... holy hell
and this is what you see when you get here. I don't miss this place
Old 10-25-2018, 02:59 AM   #184
Jack
junkman
Jack's Avatar
on the way back from LA my "known good alternator" took a crap. As I was going down grapevine. Drove for another 180 or so miles with headlights on... middle of nowhere I was going to buy two batteries and make it home but got AAA to tow me instead, son had school in morning and everything was closed.
thought maybe my fuse was acting up so I stopped for twerking
womp womp
waiting for tow truck exit 347 on I5
ordered an alternator kit
picked up Billies and 29 front and something size bars from Jeffery finally. Thank you
installed the shocks
(no pictures)
picked up a few tune up goodies from Eric and Ian. Finally meet them - like long lost family members
firewall grommet specific to temp gauge
connecting rod end links
old - also found that relay rod is super hard to turn so Im going to try one from 65 with zirk fitting. It has some play but no geese at moment
dizzy that failed me - no insulation kit. I tried installing points
got this from Eric - in order how it goes
after - need to set gap
decided to do the passenger floor while waiting for parts
I havent decided if I want to cut the hole as big as the replacement panel. There's no rust past here so why bother ???
before grinding spot welds
after spot welds / done for today
Old 10-25-2018, 11:28 AM   #185
matt b
Nice work on the floor. Will you coat or spray anything inside those frame extensions ? Getting ready to do just that on my P1800.
Old 10-25-2018, 01:30 PM   #186
Jack
junkman
Jack's Avatar
I haven’t thought of that.... there’s no rust inside of them, probably just spray black fleet paint
I’ll make sure to draw a penis on the inside too
Any ideas ?
Old 10-25-2018, 01:51 PM   #187
matt b
I havenít thought of that.... thereís no rust inside of them, probably just spray black fleet paint
Iíll make sure to draw a penis on the inside too
Any ideas ?
That goes without saying.
Old 01-31-2019, 08:29 PM   #188
R32RennSport
Outlaw Amazonian
R32RennSport's Avatar
Any updates? I feel like I can relate to this thread well.
Steven
1966 Volvo Amazon, 2004 VW R32 Golf
Old 01-31-2019, 10:03 PM   #189
sksmith
sksmith's Avatar
I think Jack may have been banned.....
Don't know what happened.
Old 01-31-2019, 10:21 PM   #190
vwbusman66
Eisen-Stein
vwbusman66's Avatar
It is my understanding that Jack needed to take some time away to deal with stuff.
A self-imposed ban if you will.
Old 02-01-2019, 12:10 AM   #191
R32RennSport
Outlaw Amazonian
Ah well that's too bad. Maybe someone here who was local to him knows how things got on with this project.
Old 02-01-2019, 12:20 AM   #192
matt b
Self imposed for sure.
Old 04-17-2019, 09:53 PM   #193
Jack
junkman
Jack's Avatar
see below
took 6 months minus 9 days off to focus on Bitcoin again
in no particular order
oil breather
before
after
replaced windshield gasket, fixed minor rust issues, repainted the surface, sealed with sealer
factory glue hard as a rock - used a wire wheel
painted
polished the wipers
before
after
installed
got rear flappies
installed the alternator
bracket
old
new - by HIperfomance
Old 04-17-2019, 10:20 PM   #194
Jack
junkman
Jack's Avatar
old fuse panel has some connectors loose
new
installed sway bars
forgot to take picture or rear one
messed up my mirror backing up
kept the original post and installed later oval mirror - posts are different with different bolt spacing
polished up the backing
forgot to take picture but I "rebuilt" the dome light - installed new ball in switch after loosing the original for the 3rd and final time
polished up the relay
before
after
some tail lights come painted separating the sections - most dont - I didnt feel like painting mine so I just taped it off
before - note how running light "spills" into the reverse and brake
tape
after
I was going to repaint and straighten out my passenger fender
before
found someone had a good BONDO time with the fender
theres more - fuk
so I used one from my old car that I sold - body "survived" the fire and parts are super straight on it. Best part is all the undercoating is gone
only picture i have of the donor - you can see it on the ground
after sandblasting - super quick
applied a layer of rust neutralizer - some rust was still showing
primer
had to bring it into the laundry room to dry for few days - it was raining and cold at the time
installed
restored my instrument cluster
like a new car
regular light bulbs, I LOVE the glow from it at night. I dont know why someone would ever put in LEDs
rear license plate bracket - before
after - powdercoated and replaced screws with bolts
more dynamat
driver side window fell down - again. this time it was the pulley
"new" yankee bar/towel rack powdercoated brackets, painted the inside grey
installed
Old 04-17-2019, 10:41 PM   #195
Jack
junkman
Jack's Avatar
forgot to take a picture but I installed B20 rocker arm assembly - the oil passages are bigger
old
installed a powdercoated center oil cap valve cover that came off an early 1800
M41 time
found that all my "school bus" cover plates were junk
mocking it up with a M40 because I can install that without a jack
test fitting - doesnt take much sheet mental
welded - forgot to take pictures of paint/sealant etc
this thing is heavy
1/2 way in. After this shot I had to remove jack (not me) and lay under and manual finish the job. It got really personal. Found out later the reverse gear is crap. Will come out later and be rebuild (at some point) and a known good one will go in
carpet - both fronts are done
My new cat - she goes on rides sometimes
Preview of some things I been doing
brought these home
Old 04-17-2019, 10:54 PM   #196
vwbusman66
Eisen-Stein
vwbusman66's Avatar
OH HELLO THERE.
Now seeing this makes me reconsider 234 swapping the 142.
Dammit.
Old 04-17-2019, 11:00 PM   #197
Jack
junkman
Jack's Avatar
OH HELLO THERE.
Dammit.
please take pipe dreams to your local psychic
Old 04-18-2019, 06:02 PM   #198
matt b
Good to have you back.
You're doing that sedan justice, nice work! I wish I had a dash pad to trade you, it would clean up the interior of that car so much.
Old 04-18-2019, 06:24 PM   #199
sksmith
sksmith's Avatar
Glad to see your back. Rust repairs are looking great, except for that artwork. You're a sick boy!!
Steve
Old 04-18-2019, 09:15 PM   #200
Jack
junkman
Jack's Avatar
Odometer crossed 1K. It was at 0 on March 24th. Car is getting old quickly
Thank you
Dashpad -soon. I try to do things on the cheap first.............
What’s worse is that I had new front seat upholstery and foam (for one seat) and other car parts stolen from my porch... about $850 worth of stuff
Steve
Thank you
but that’s how I sign my checks man
dome light works with doors
powdercoated glove/speaker shelf. Painted the material SEM and installed a larger speaker - painted it black to hide it. I keep forgetting to get a longer screw for the shelf clip on kick panel
debating if I should install this grill on this car or the 67 wagon- I leaning toward this car. only thing wrong with it is the bottom center section, between front and radiator - need to cut one out from a wrecked one and paint to match the door/fender.
picture before washing it. Powder coat grill insert gloss or semi gloss black ?
