Old 09-30-2017, 01:40 AM   #51
Mr.Borrie
The Sneaky F*ing Russian
Mr.Borrie's Avatar
Originally Posted by slow240 View Post
WHERE DO YOU KEEP FINDING 780 PARTS CARS!?!?!?!
I cant find any in the states, my 780 needs little bits of loving here and there.
Yeah Its crazy, i guess I know allot of volvo people. None of them where Really for sale somewhere
Mr.Borrie is offline   Reply With Quote
Old 09-30-2017, 03:39 AM   #52
slow240
Home Schooled
slow240's Avatar
you wouldn't happen to have a spare drivers side window seal would you (US drivers side that is lol)
I'll polish your face
'89 780. Fine Corinthian leather.
Old 09-30-2017, 08:38 AM   #53
domasa
domasa's Avatar
Awesome car. Well done Boris! Subbed.
Volvo 1995 940 NA
domasa is offline   Reply With Quote
Old 10-13-2017, 11:10 AM   #54
Mr.Borrie
Mr.Borrie's Avatar
Not sure what you are asking for? i have a spare door yes
Yeah i feel this is goint to be a nice one
meanwhile
While looking for a new Daily estate i came in contact with a guy that had a project 965. He was willing to trade my empty 780 for it
Old 03-24-2018, 08:05 AM   #55
Mr.Borrie
Mr.Borrie's Avatar
Floorpan time! My first welding ever too
Not done yet but for the first time i'm feeling ok
Old 11-17-2018, 06:39 AM   #56
Mr.Borrie
Mr.Borrie's Avatar
Peh interfall for my updates are taking a dump, allot of construction on the house etc.
Spend a few nights again with the welder, feeling more and more comfortable with that thing. I was really nervous on the roofpanel welding regarding flexing but both the rusted sunroof part and the 80s carkit antenna are now welded shut, will need a minimal filler.
Floor i patched up and recreated a box for the driverseat mounting. original one was to far gone
IMG-5544
IMG-20181116-173001
IMG-20181111-152650
IMG-20181111-152713
Old 01-07-2019, 03:55 PM   #57
Mr.Borrie
Mr.Borrie's Avatar
Welded up the last bits, rust spray and paint done too.
Redid the wires for the alternators so the system charges again.
Also welded up the petrol mount on the diesel exhaust damper.
Replaced the moonroof with the one of the black donor, leak free and works!
Technically its done.
Going to get the engine swap registered somewhere next month..
Also i was going to keep it stock but i am cleaning out the garage and found stuf of the 760 turbo build ..
volvo-780-dempers
Old 01-08-2019, 05:29 PM   #58
Vol242vo
Vol242vo's Avatar
Looking good! Wish I could just go through my garage and come across some desirable parts!
Derek - 1980 242
Old 01-08-2019, 06:13 PM   #59
Mr.Borrie
Mr.Borrie's Avatar
Trust me , you dont. It takes garages full with crap and have 2 nice things
Old 01-19-2019, 02:13 PM   #60
Mr.Borrie
Mr.Borrie's Avatar
Spend few hours on wiring, got Some gremlin in the lights and dash.
Degraded wiring FTL
Old 01-22-2019, 01:18 PM   #61
Mr.Borrie
Mr.Borrie's Avatar
Snapped this one just now, kinda cool how the lines of the car are
3-B9-A72-CE-CB47-47-B0-AA47-D8-BA037874-CD
Old 02-01-2019, 08:16 AM   #62
Mr.Borrie
Mr.Borrie's Avatar
B23-E019-A-482-F-4-D5-B-83-F0-41-ECCB3-DAECA
The petrol engine is now registered and checked by the gouvernement.
First drive with it since the swap. Few things i noticed
Noisy flywheel bearing
When i let off the gas big gray cloud from the exhaust
Oil in the enginebay.
Stuttering engine (but that was low fuel i think, was running on fumes)
The PO of the B230fk mentioned oil leaks so i think replace/clean flame trap and Some thicker oil.
Still a whole bunch of odds and ends till perfection but feels good the swap is apporved
Old 02-06-2019, 06:50 AM   #63
Mr.Borrie
Mr.Borrie's Avatar
Did a little check, at startup huge clouds again.
The PO said Some leaks at the engine and i suspected the PVC.
The actuator at the turbo was loose too.
I guess the engine having boost again really shows the pvc glogs.
The intake hose with oil and non at the turbo side confirms this.
Engine runs great otherwise. So time for a pvc job, perhaps a catchtank too?
4-A8-E24-C0-11-FB-491-B-B5-DF-7-C809-FE85145
617-CA5-E8-7-E8-D-4250-B8-D0-6-EB47-D2-F790-B
Old 02-20-2019, 09:38 AM   #64
Mr.Borrie
Mr.Borrie's Avatar
Cleaned out the intercooler, PVC and lines. Still the car smokes like crazy.
Smoke also coming out of the oil filler cap when removed and the dipstick.
The engine was leaky when i got it, drove it around just fine no smoke at all so i am at a loss why the sudden smoke problems.
Besides that been tinkering with the wiring connecting the cluster, now got the tach working and replaced some bulbs. also removed the EGR stuff as a 86 car does not need that here to pass inspection
Still this sucks as this way there is no way i can get it passed inspection with the clouds of gray smoke
D6494-E9-A-3107-4-B6-A-BAE6-04-B4-EFB3-AB66
IMG-0783
IMG-0807
IMG-0808
IMG-0865
IMG-0835
Old 02-20-2019, 01:33 PM   #65
J2_
J2_'s Avatar
Clouds at idle and when you let off the gas?
Did you check the turbo itself? Did you change the fuel filter? Maybe that has got some crap in it.
J2_ is offline   Reply With Quote
Old 02-20-2019, 03:48 PM   #66
Mr.Borrie
Mr.Borrie's Avatar
Yeah the dumpvalve and intercooler where full with oil and the pvc was glogged.
Big clouds when let off the gas. Have not driven the car het cause off the smoke it now makes at idle.
Just went in the garage and i do feel like there still is a diesel sort of smell.. not sure.
Checked the turbo and no real play, most of the oil was on the intake side not the turbo side
Old 03-15-2019, 02:24 PM   #67
Mr.Borrie
Mr.Borrie's Avatar
Replaced the oil and filter. Pvc and intercooler are now clean.
Replaced the sparkplugs, one near the firewall was gray/brown with white deposit.
Put in the new interior too so i get Some more garage space.
Did a conpression and the nr4 had 11 bar all the others 10 bar.
Still getting Some smoke from the dipstick hole. And Made a new video of the exhaust...
I think it must be the turbo at this point..?
https://youtu.be/TkEVzvSuH5c
83261-D94-A5-A3-4304-B4-C0-3-C35615-CA19-B
48774-BEC-68-EA-4-A84-8-E49-773-CF76-D9-EA7
515-DA2-B3-F0-C2-4-AAB-B2-D2-01-A20577-E159
3-B3-A1883-8370-4-CFF-8214-983-E2-CB116-D3
Old 03-15-2019, 03:24 PM   #68
dopski
Does it smell like fuel? > maybe pissing injector.
Or the oildrain of the turbo does not work.
dopski is offline   Reply With Quote
Old 03-15-2019, 04:55 PM   #69
Mr.Borrie
Mr.Borrie's Avatar
I was thinking this at one point as the oil was so thin, hence the replacement.
But how would that result in the smoke i am seeing now?
Oil return could very well be full to come to think of it looking at how the pvc was.
Neglected engine is neglected, still it was free so no complaints
Old 03-16-2019, 02:13 AM   #70
dopski
I once had a continuous spraying injector in a volvo 850. Result it ran on 4 cilinders. And the not burnt fuel left the exhaust as a whitegrey pufs.
Old 03-20-2019, 01:02 PM   #71
Mr.Borrie
Mr.Borrie's Avatar
Injectors swapped, no change.
Car starts up with no smoke at all, within one minute it starts to smoke from little to big constant clouds
Old 03-20-2019, 03:40 PM   #72
dopski
Oil return works?
Old 03-20-2019, 04:45 PM   #73
Mr.Borrie
Mr.Borrie's Avatar
My guess whas turbo at this point too.. i think it can still go for another round yes?
878-F236-A-1699-4237-8-B9-D-FD8-DA5639-D5-B
8-A21845-A-000-C-4-D28-9057-8-C77-DB25-BA29
DC5729-C0-DF17-41-A3-B216-121-CC878-D7-A8
8-EF1-B077-110-B-4-FC7-9-F62-B9704-B4-D7-C73
Old 03-21-2019, 04:41 AM   #74
dopski
Lol. Probably the oil part of the CHRA is clogged.
Old 03-21-2019, 05:47 AM   #75
Mr.Borrie
Mr.Borrie's Avatar
There is another 13c i had on the shelf in there now. Just need to do the returnline. I hate doing those and it was already late, this weekend perhaps she Will spin again
