Old 03-23-2016, 11:46 PM   #26
propav8r
F*ck Edgar
propav8r's Avatar
Originally Posted by GTJordan View Post
Pretty sure there is a video of it running in the FB group?!
Originally Posted by Chance View Post
FML I just broke my 3 month Fakebook boycott for a ****ing weed whacker
Serves me right, no one on TB gets **** done that fast
Ahahahahahaah yesssss
K-Jet to Megasquirt Article
The Departed: 1981 245, 1983 245 Turbo, 1983 244 Turbo, 1983 242 Turbo, 1984 244, 1985 245 Turbo, 1989 244, 1989 765, 1990 245 Turbo, 1991 244, 1992 245, 1997 855
Old 03-23-2016, 11:54 PM   #27
propav8r
F*ck Edgar
propav8r's Avatar
Old 03-24-2016, 12:32 AM   #28
MoCounselor
MoCounselor's Avatar
Sounds like a Honda! ;)
MoCounselor is offline   Reply With Quote
Old 03-24-2016, 02:06 PM   #29
propav8r
F*ck Edgar
propav8r's Avatar
Got these cut at the waterjet shop next door today. The header should be in sometime next week, then I can chop and weld to my heart's content.
One for me, one for Brock, one for Andrew.
Old 03-24-2016, 02:16 PM   #30
Pro Sneaker Peddler
Man a shorty bottom mount header a la B204GT would be sweet for me. Oh well.
Old 03-24-2016, 02:17 PM   #31
Walter
Walter's Avatar
I laughed out loud at the running video.
Walter is offline   Reply With Quote
Old 03-24-2016, 08:34 PM   #32
Old Iron
I Roll
Old Iron's Avatar
Great project, nice to see someone taking the path less traveled and not doing the typical megasquirt of b230ft swap!
Turbobricked
Old 03-25-2016, 11:22 AM   #33
quillc
yv1a.com
quillc's Avatar
Instead of MS, buy one of these: http://www.123ignition.nl/id/50.html
Alternatively, I have a boat points distributor. You would have to set up a vacuum advance for that however.
Chris
www.yv1a.com
Old 03-28-2016, 04:22 PM   #34
propav8r
F*ck Edgar
propav8r's Avatar
That's all well and good, but that's money. I have the MS1 stuff laying around the house.
Got my ford header in today. It's so close it's not even funny. The top four studs even line up with the ford flange.
Crappy picture is crappy
Volvo flange on Ford gasket
I'll lop the ford flange off and then goop it back on to the Volvo flange. A cursory glance at the position of the manifold says it'll clear the body of the car. It'll be close though.
Old 03-28-2016, 04:30 PM   #35
Pro Sneaker Peddler
That B21 better have like, 12:1 CR
Old 03-28-2016, 04:35 PM   #36
cwdodson88
good god whats the id on those primaries!?!
The Build Thread
SVEA - PUSHROD TURBO!
Old 03-28-2016, 04:38 PM   #37
propav8r
F*ck Edgar
propav8r's Avatar
It doesn't currently, but it may eventually.
1 5/8" - 1 3/4"
Old 03-28-2016, 04:43 PM   #38
cwdodson88
going to need a pretty fat cam, eh? Or is the stepped primary going to keep the reverb in check?
Very cool that it fits-ish. It sure looks good.
Old 03-28-2016, 04:44 PM   #39
Pro Sneaker Peddler
1 5/8" - 1 3/4"
Take the rotating assy out and shave the **** outta the block and head, install Pinto belt. DO EEEEET
Old 03-28-2016, 04:51 PM   #40
propav8r
F*ck Edgar
propav8r's Avatar
I have no idea, nor do I really care. I'm not shooting for huge NA power.
Old 03-28-2016, 06:52 PM   #41
cosbySweater
cosbySweater's Avatar
god I kinda wanna use one of those headers on my 16v n/a car
Old 03-28-2016, 06:54 PM   #42
Lord_Athlon
Just damn
Make your own thread.
84 242 turbo msII
My build https://forums.tbforums.com/showthread.php?t=8675309
Old 03-29-2016, 03:36 PM   #43
propav8r
F*ck Edgar
propav8r's Avatar
Ordered up a RHD throttle cable today. If I have time after pulling parts off the 760 and boxing them up, I have a pretty simple idea for the throttle cable bracket that should work fine.
Old 04-04-2016, 10:13 AM   #44
propav8r
F*ck Edgar
propav8r's Avatar
Awwww, someone rated my thread, yay!
Should be able to make some progress on the car this week. Finally sourced the correct crank gear, so I can get the front of the motor together. I have a sort of cobbled TPS setup, but I'm still on the fence about just buying something that'll bolt on and work.
Snagged an old school adjustable cam gear from Impolvo while I was in Chapel Thrill.
Old 04-04-2016, 11:12 AM   #45
propav8r
F*ck Edgar
propav8r's Avatar
After considering it for about 3 minutes, I just bought the TPS kit. It'll look cleaner and be less cobbled than what I was planning on doing.
Old 04-04-2016, 08:45 PM   #46
slow240
Home Schooled
slow240's Avatar
Good choices. Now hurry up and makeep it run.
And while you're at it, would you work on the other one to? Jeez man, you have too many cars that I'm emotionally invested in.
I'll polish your face
'90 244. blue, tall, ghetto, fabulous.
http://forums.turbobricks.com/showthread.php?t=310740
Old 04-05-2016, 10:08 AM   #47
propav8r
F*ck Edgar
propav8r's Avatar
The only thing I lack for the '79 is a set of wheels, a clutch for the T5, and a Microsquirt. I'll get it going again soon enough.
Old 04-05-2016, 10:16 AM   #48
Pro Sneaker Peddler
Dafuq are you putting a T5 behind a low power engine for?
Old 04-05-2016, 10:24 AM   #49
propav8r
F*ck Edgar
propav8r's Avatar
Scene points.
Old 04-05-2016, 11:55 AM   #50
Pro Sneaker Peddler
Scene points.
