Old 01-29-2019, 07:56 PM   #701
Atom D&D
Atom D&D's Avatar
Phone mount (also the head unit in HQ). Goes in the upper dash location
The hinge probably looks a little funny, but like a suicide door hinge, in order to keep the gap tight I need the insert to hinge “out” rather than just pivot along the edge. All of the middle stack openings will have similar polished aluminum trim rings
I used a generic push-lock-spring cabinet latch for positioning and motion.
Atom D&D is offline   Reply With Quote
Old 01-29-2019, 09:16 PM   #702
doucheNozzle
doucheNozzle's Avatar
So awesome.
However, what happens when you get a different phone?
Edit: You should also design a wireless charger for there. Even if your phone doesn't support it yet
'00 XC70 SE - Slow
'04 V70 T5A - Feels Fast
Old 01-29-2019, 09:35 PM   #703
Atom D&D
Atom D&D's Avatar
Originally Posted by doucheNozzle View Post
So awesome.
As long as the phone fits I can always just make a new plate/insert/holder as required. Not installed yet is the plug that the phone will “dock” to when slid in. For charging and audio.
Old 01-29-2019, 11:31 PM   #704
Vol242vo
Vol242vo's Avatar
So cool...
Derek - 1980 242
Old 02-02-2019, 03:01 PM   #705
Atom D&D
Atom D&D's Avatar
Updates:
Wrapped some of the dash components. Also found out I was sent the wrong color early on and used that color to wrap my door panels. Not a huge deal since I intended on re-doing to upper panels two tone anyway. Gauge panel trim is just sitting in there. Have some trimming to do in order to get things fitting better.
I was contacted by Dgerry (on R3V) from G-Pop Shop in Arkansas who was interested in helping out with the build from a turbo standpoint. Since I had already bought the turbo I was going to use and don’t have to moneys to buy anything nice and new, he offered to do a little trade work with me. I sent him my new turbo to upgrade. He installed new journal bearings, new upgraded 360 thrust bearing, new seals (including a stepped gap version on the turbine side). He balanced it, leak checked it and changed to a billet GTX3076 compressor wheel. It’s on it’s way back to me and I couldn’t be more excited.
I still need to iron out some dash details before I can wrap it. It’s tough when I get antsy to not just wrap it and put it in. Carpet kit will be coming soon and I have a pair of custom floor mats getting sewn up as I type.
Old 02-02-2019, 03:12 PM   #706
Duder
His Dudeness, El Duderino
Duder's Avatar
Interesting; I didn't know China was making journal bearing GT3076R knock-offs.
Is the "GTX" compressor wheel a genuine one, or also a China copy?
That C255 compressor design flows quite a bit more than the old BCI-18 that your turbo came with; should be a healthy upgrade.
Old 02-02-2019, 03:35 PM   #707
80/20 speed parts club
The "GT3071" I have here uses GT30 housings, turbine wheel, and what appears to be a BW K27/S200 compressor wheel.
Old 02-02-2019, 04:55 PM   #708
matt b
G-Pop shop rocks, great to see lend you a hand. I've sent them 5-6 turbos over the years and never had an issue.
Old 02-02-2019, 05:05 PM   #709
Atom D&D
Atom D&D's Avatar
It was a Chinese GT2871 that I sent him. He modified it to accept the “NOS GTX3076” (quoting him) wheel he had on the shelf. The wheel that was on it was 49mm x 71mm, and the one he put in is 56mm x 75mm.
I’m excited to get this thing in and running.
Old 02-02-2019, 07:20 PM   #710
Atom D&D
Atom D&D's Avatar
Drone video shot by Andrew (@absonracing on IG)
https://youtu.be/8CiRyXyqWSY
Old 02-03-2019, 01:44 AM   #711
Duder
Duder's Avatar
So it's a 2876 now then? That's a healthy mismatch between turbine and compressor. The GT28 turbine wheel is only 54mm on the inducer (major) diameter.
Old 02-06-2019, 09:56 PM   #712
Atom D&D
Atom D&D's Avatar
Just as an FYI, not everything magically works out for me. I am not going to have funds, or time, to get my front seats upholstered before I’ve got stuff to do this coming spring so I decided to paint/dye the front seats. I had some custom color mixed up and prepped/sprayed the seats. I know it’s not a solid long term solution, but I figured I could get one season out of it. Well, after getting it all done it felt “dry”. Not like how it usually is. I stuffed my arm up in the seat to remove the hangers I used while spraying and everywhere the seat wrinkled the paint cracked. I drug a nail across it and it flakes right off. FML. Now I need to strip off all the paint, re-prep and spray again. I won’t be using custom mixed paint this time (I’m blaming that material), but instead an off-the-shelf rattle can color. This is gonna be a pain in the a$$.
Old 02-06-2019, 11:11 PM   #713
matt b
The leather and the paint didn't get along ? That sucks..... I have had good success with canned upholstery paint but I have never tried a seat.
Old 02-07-2019, 12:24 AM   #714
Atom D&D
Atom D&D's Avatar
None of it got along. I just started the removal process in the centers. I tested a patch with some rattle can SEM in great that I had and it was soft, supple and stuck like chuck. Just got some hours of stripping ahead of me.
Old 02-09-2019, 06:42 PM   #715
Atom D&D
Atom D&D's Avatar
Set up the workshop after doing a fair amount of shoveling. Came up with a pretty good rattle can combo that got the seat color pretty close. Test fit the Nardi. Slightly smaller, so it blocks even more of the gauges for me. That’s why I added LEDs on the lower inner gauge bolt locations. They’re turn signal repeaters. From my driving position the turn indicators are 100% blocked. Now I need to make a top half cluster bezel.
The kids and I also took some storage bins I had and we built some snowball fighting forts.
The 11 year old is tall for his age, and the three year old is short for his age, so we tried to stage the wall height so it could work for both
Old 02-10-2019, 06:13 PM   #716
matt b
Same 3 yr old I spoke to when Danny, you and I got wings in Seattle ?
I love your gauge cluster, can't say it enough.
Old 02-10-2019, 07:34 PM   #717
Atom D&D
Atom D&D's Avatar
Same one!
Old 02-10-2019, 09:25 PM   #718
matt b
Originally Posted by Atom D&D View Post
Same one!
Old 02-14-2019, 08:49 PM   #719
Atom D&D
Atom D&D's Avatar
Hoping to possibly wrap the dash tomorrow AM! Pretty excited. I think I’ve got enough of the detail stuff completed to move forward. Pretty excited to check that off. I’ll still need to make the polished aluminum “chrome” strip.
Old 02-14-2019, 09:10 PM   #720
Vol242vo
Vol242vo's Avatar
Looking good!
Old 02-15-2019, 11:05 PM   #721
Atom D&D
Atom D&D's Avatar
I’ll put together a longer post once I get some better daytime pics tomorrow. Got dark fast today
Oh, and test stickers!
Old 02-15-2019, 11:50 PM   #722
Vol242vo
Vol242vo's Avatar
Dash is spot on dead sexy. Love the chrome strip between the black and red. If you’re selling those stickers put me down for one.
Old 02-16-2019, 12:21 AM   #723
Atom D&D
Atom D&D's Avatar
Was trying to give a nod to the Amazon dash.
These ones will just be give aways. Was trying to see what the turn around time and quality was for having the stickers made. I’ll have some for sale before too long. Hopefully some shirts too. I need to fund this build somehow.
Old 02-16-2019, 04:54 AM   #724
Shifted
On the Hill
Shifted's Avatar
That is really nice.
He built my Bose 901s all by himself...
Doing something because you enjoy it is a must in life.
Originally Posted by ME II View Post
Without mistakes there is no learning.
"The mountain streams that rush on by/Show the fish a-jumpin' and reflect the open sky/The fresh clean smell of the pines/Symbol of unchanging times/All around this sacred land/Strangely, though, I've found my way/Right here I'm a-gonna stay/In this land" Tom Johnston/Doobie Brothers "Ukiah"
Lifeboat for the plankwalkers/otherwise disenfranchised.
Shifted is online now   Reply With Quote
Old 02-16-2019, 08:28 AM   #725
sdewolfe
sdewolfe's Avatar
I will take two XXL shirts when you have them.
Regards,
Mr. Shannon DeWolfe
--(I've taken to using Mr. because my name misleads folks on the WWW; I'm a 63 year old fat man.
sdewolfe is offline   Reply With Quote
