Old 09-13-2007, 03:22 PM   #26
stray
Hey, thats my picture of the car from the side.
This is one of my favorite cars ever. Seeing it in person was killer.
stray is offline   Reply With Quote
Old 02-10-2008, 03:57 AM   #27
RedFridge
RedFridge's Avatar
I'm bumpin this ride!
RedFridge is offline   Reply With Quote
Old 02-11-2008, 01:59 AM   #28
the poi
Has been
the poi's Avatar
And I'm slackin on the thread update
Updated the brakes. Its still broke and slow though, primarily because my switch to MSII means I have to re-tune and ****. Also, a hot-start issue has reared its ugly head, and my gut instinct is that its a fluid/mechanical issue with the fuel rail vapor locking. Hooray. Maybe not though. Also, I don't have anything with a reliably fast serial port, so some things drop data while burning, so I have to be especially careful that I don't hose anything. On the plus side, I'm done with all the mechanical **** I wanted to do (read: the brakes) so now I can just tune, and polish the goddamn tuning (****er still hates starting)
Old 04-09-2008, 12:23 AM   #29
the poi
Has been
the poi's Avatar
Updates, I guess. HIDs! Also, the car runs beautifully currently, revs nice, misfire free, it's solid. I'm maxing my 46lbers at 95%dc at 15psi right now. That's the last mechanical change on the list, bigger injectors that aren't 20 years old (and will fit nicely in the rail!). The only nagging problem right now is hard starting--what's causing this is a weak VR signal, so sync is inconsistent at cranking speed. My battery is crapping itself, so it cranks at such a low speed, that might be the issue (~150rpm), as it improves greatly with my battery booster attached. Moving the sensor close to the wheel fixes the cranking, but then it overloads and resets above 3 grand, heh. So I need to improve the sensitivity, ideally, to really knock that out. The injector upgrade, some street tuning/beating, then I'll get it on a dynopak...
Old 06-30-2008, 10:51 AM   #30
BlackT5
BlackT5's Avatar
Need an update!
-Mark
95 850 T-5R
98 S70 T5M
00 V70R M66 AWD
04 V70R
05 S60R
BlackT5 is offline   Reply With Quote
Old 06-30-2008, 11:53 AM   #31
Captain Bondo
Exklusiv Zubehör Klub
Captain Bondo's Avatar
I am sooo tempted to skip the crank VR and set up a hall sensor... have you considered this? I think we talked about it...
It would be easy to just remove the little aluminum bracket form the back of the motor and modify it..
-Kenny
Old 06-30-2008, 09:21 PM   #32
Homer
OEMplus++
Homer's Avatar
Yah. Hell thats why my car wouldn't start most of the time. Old starter. 2.4 wouldn't like a Hall sensor that much though.
-Jacob:
2006 A4 - Comfy DD
Old 06-30-2008, 09:23 PM   #33
Captain Bondo
"Cherry" makes a sensor that looks close to a good fit. We discussed it before, it can be found on digikey, and sells elsewhere for like, 37 dollars.
I have had decent luck with Cherry sensors in industrial apps, I am going to give it a go.
Old 06-30-2008, 10:00 PM   #34
the poi
Has been
the poi's Avatar
A hall would help, I guess. Mine works right now, because of a more lenient code that will allow up to three missed syncs before starting over with the counting
Old 07-01-2008, 11:02 AM   #35
qwkswede
faster than you think
I have been running with a Cherry sensor of some sort for about 6 months now. No problems with it at all. It is the sensor I use on my 36-1 EDIS wheel. Just to give some experience. The sensor doesn't come with shielded wire. Either add your own shielding, or cut the wires down close to the sensor and run your own shielded multi-conductor cable. I am still running around with Chipotle burrito wrappers on mine, and its working well. I need to rewire that sucker sometime.
----edit-----
By the way chris. I like your project thread format with links to all the important other posts. I may have to steal the idea for my project thread sometime when I have energy to track down all the scattered stuff.
-Ken
1967 Volvo 122S
1992 Volvo 745 driver
Old 07-02-2008, 02:13 AM   #36
Captain Bondo
while it isn't a bad idea to shield it, the hall sensor's square wave digital output is not nearly as sensitive to noise vs. a VR sensor, so it's not a huge issue.
The one I am talking about comes either flying lead or with a connector though, might just get the one that uses a connector and wire my harness to that.
Old 07-02-2008, 02:31 AM   #37
qwkswede
Yeah, I have the flying lead one. And my car would hardly run with a VR sensor because of noise issues, until I very carefully shielded and played all the grounding games you can imagine. The Hall senor was supposed to be an improvement for the very reasons you state. But, my car wouldn't rev past 1500 rpm until I wrapped the wires in aluminum foil. Just an observation.
Old 07-02-2008, 02:39 AM   #38
Jordan
Jordan's Avatar
This car is soooooooooo cool! God I haven't read anything about it for a while and I just did. Wow.
(please dont go to the 850R bumper...)
My Buyer/Seller Feedback Thread
Jordan is offline   Reply With Quote
Old 08-08-2008, 06:46 AM   #39
DaButcher
Do a Burnout!
DaButcher's Avatar
Bitchin ride :-)
Ps. you need to fill up the gaps where you used to have your wiper arms for the front lights :-)
Also, what about getting someone to paint the IC, so it looks like you have the OEM front bumper? would be LOL, I think.
DaButcher is offline   Reply With Quote
Old 12-03-2009, 05:21 PM   #40
doucheNozzle
doucheNozzle's Avatar
It's been over a year! Any updates?
'00 XC70 SE - Slow
'04 V70 T5A - Feels Fast
Old 12-06-2009, 03:02 PM   #41
244tiCanuck
244tiCanuck's Avatar
yeah, what ever happened with this?
1996 Dodge Dakota 5.2 4x4 daily driver
1988 Vanagon GL
Originally Posted by spruill242 View Post
I've had my ass kicked many-a times by a goose.
Originally Posted by ghengiskhan View Post
FWD sedans are for guys that like to do other guys in the but and receive it in the buh-hootey.
RWD wagons are for guys that are ballers, they enjoy their sexuality, since they actually get girls.
Just sayin'.
Originally Posted by isaac View Post
Dude don't call me the freak just because you've beaten your taint into the consistency of an old baseball glove.
244tiCanuck is offline   Reply With Quote
Old 12-06-2009, 07:55 PM   #42
MrBill
fige=500Dollar Mistake
MrBill's Avatar
junked.
Someone say crazy rays?
Old 12-06-2009, 08:17 PM   #43
adrianpike
adrianpike's Avatar
chris drove through a preschool and is still cleaning the bits out of the bumpercooler.
I'm looking to buy, PM me if you've got any of it: LS bits, 93 850 bumper, ford 8.8", T5 WC, T56, Mustang IRS
Adrian is omniscient, you will never escape his wrath. - 500dollar744ti
doug was here
adrianpike is offline   Reply With Quote
Old 12-06-2009, 11:04 PM   #44
spruill244
Mahalos
spruill244's Avatar
haha^
Image and video hosting by TinyPic
68' 145S-Sold
90' 745T-Sold
95' 850R-Sold
83' 244T-Sold
96' 850R- Sold
spruill244 is offline   Reply With Quote
Old 12-21-2009, 06:57 PM   #45
Sir Psycho
holstrich 2.0
Sir Psycho's Avatar
*crickets*
Isaac
1995 940 Turbo:
531 head, Holset HE351 @ 20 psi, Emusa External Wastegate w/screamer, Mild Steel Header, 4" Downpipe, Ostrich Emulator, IPD Turbo Cam, TTR Cam Gear, Big Piping and Intercooler, 3" Exhaust, V8 T5 soon, Synapse Synchronic BOV, AEM Wideband, 18" Pegasus, B&G Springs, Billy HD's, Chassis Bracing, Sumimoto HTR ZIII 225/40/18
Sir Psycho is offline   Reply With Quote
Old 12-21-2009, 07:07 PM   #46
L8 APEKS
Yayayaya, hohohooo!!!
L8 APEKS's Avatar
Isn't he in school right now? Maybe he's just super busy and can't post?
Sean Williams
'94 850 Turbo Wagon (daily) :: 14.0 @ 98.5
B5234|AW50|TLAO tune|3" exhaust|NA cams|65mm tb|38mm BOV|E40 blend
'75 244GL (project) :: 8.4 @ 85.6
B230FT|AW71|1031|gutted|TLAO chips|welded 3.73|19T|3" exhaust|IPD cam|E62 blend|55 lb inj. (@ 4 bar)
CLICK HERE for the 244 BUILD THREAD!
BRAND NEW Mitsubishi 18T and 19T turbo conversions for sale...from $450...CLICK HERE or PM for details!
L8 APEKS is offline   Reply With Quote
Old 12-21-2009, 07:10 PM   #47
DanielRogers
nonsense. no one's ever too busy to post on tb.
93 940T - 20G / IPD springs / Bilstein's / K-cam / 3" / upper strut brace / chips
Originally Posted by adrianpike View Post
i will shoot you through the internet.
DanielRogers is offline   Reply With Quote
Old 04-09-2010, 02:31 AM   #48
dieselboy
Whooty patrol
dieselboy's Avatar
Curious bump
I heard it's n/a again and he dailys it.
'82 242t hy35 @28psi, ebay header, big intercooler, microsquirt ecm, rsi stg2 cam, arp headstuds, tremec tko600, 3" exhaust, 13" brembos, coilovers, saabspoiler, 245/40r17s, lots of yoshifab stuff.
'12 flex ecoboost "kats" car
'93 940 turbo lifted #trophyvo
'08 f350 4x4 v10 cclb
'97 f-350 4x4 offroad toy
'94 4700 dt466 International toterhome build
dieselboy is offline   Reply With Quote
Old 04-09-2010, 12:30 PM   #49
Wagner
Tbricks MIG Welding Champion
Wagner's Avatar
Some say that it has rust on the steering wheel and that it is used to transfer lumber from Mexico to USA when it rains. All we know for sure is that it's called a Volvo 960.
Cops pulled me over. Papers, they said. Scissors, i replied. Still i did not win. Go figure.
Wagner is offline   Reply With Quote
Old 04-09-2010, 07:46 PM   #50
klr142
Turbo, what?
klr142's Avatar
Nice one!
