#101 |
![]() AWESOME!!! I really love how it's looking!
#102 |
Volvo Friends
![]() I guess this will tide me over until you start working on the amazon.
#103 | ||||
Has been
![]() Quote:
![]() edit:// uuuuuuuuugh |
#104 |
#helpbrock2k16
![]() beautiful. is this still turboed?
2006 S80 2.5T 2000 Jurassic park xj |
#105 |
An Anomaly
![]() Awesome turn of events is awesome.
1994 945ti | 15g @ 14psi, Turbosmart EBC, AEM Failsafe WB, 3"/2.5" exhaust, do88 intercooler, iPd cam, STS cam gear, Ostrich LH tune, sbabbs EZK chip, green giants, K&N, Yoshifab CCV/Can/Cap, iPd SS brake lines, TME, Eibach, BNE, Koni suspension, iPd sways, iPd panhard, Cherry Turbos upper/lower braces, forged BBS RG-Rs, Michelin Pilot SS, ecodes, V90 bits. 1985 744ti | 13.8 @ 100.5 mph - Sold after 20 years. ![]() |
#106 |
Has been
#107 |
Volvo Friends
![]() ![]() Are you aware this exists now? |
#108 |
Chubfest 2009 Survivor
![]() Join Date: Nov 2002
![]() Is it still the t6 with turbo pistons or are you back to a stock 960 motor?
I have a t5 sitting at the shop but thinking of your car back at Carlsen always makes me think hard about the 6.
Hank Scorpio is from the Simpsons. You can call me Doug ;) Will trade guitars/guitar parts for go fast goodies or stuff I need. Just PM. www.kauerguitars.com the second best way to upset neighbors and alienate people. History: Car 1 (242) | Car 2 (t5r) | Car 3 (255) |
#109 |
B6304 douche
![]() Now make fiberglass molds of those fenders and make me a set of vacuum bagged carbon fiber ones.
97 965R M90 My car! It's Purple! 267K+! 15.66@89.14 83 Group A 242. 7k+ original miles. Long term project. 98 V90 Parts car. Olive Green. 197K+ 98 V90 Parts car. Tropical Green. 177K+ 59 Austin Healey Bugeye Sprite. Project car. 94 Miata. Weekend car with 66K+ original miles! 94 Miata. LeMons project. 960 build thread: http://forums.turbobricks.com/showthread.php?t=231763 |
#110 |
![]() Join Date: Jul 2002
![]() those flares turned out really nice.
#111 | ||
Has been
![]() Quote:
I still have the t6 lump, it's ostensibly destined for my 122. In 10 years. Apparently. Edit:// I have thought about making molds. I'll revisit it I guess when I'm totally done with them. I'd like to mold the rear too, but I don't know how I'd install Fiberglas parts if I ever needed to use them. Last edited by the poi; 01-03-2014 at 06:38 PM.. |
#112 |
Subtle as a V8 544
![]() On the sheetmetal work (I have this insane belief that I'll someday have fender work to do): What thickness metal did you use for the front flares? Is every teensy ass little piece fully welded? That must have been tedious. Why so many teensy pieces, vs fewer larger pieces, then shaping with a hammer/dolly? Did you leave the welding wire in place? Great job!! |
#113 | ||
Anime Lord
![]() Quote:
My S90 thanks you again and again for the T6 bits ![]() ![]() Also... considering you are you.... why not quad turbo Toyota 1GZ because baller?
Tentacle SUV 12 xc90; stuff including v8 and towbar etc... Powered by Beetroot recently crushed Volvo's 1990 244, 99 v70 t5, 98 v70 t5, 2002 s80 t6, 98 940s |
#114 |
B6304 douche
![]() I would love a set of those spindles. You should sell the design to Ben. He might actually make them.
#115 |
#helpbrock2k16
#116 | |
No crust.
![]() Quote:
My $.02 |
#117 | |
Has been
![]() Quote:
![]() The metal is all 22ga--I ordered it from Onlinemetals--they cut it into strips for pretty cheap. The bits aren't fully welded, probably about 50%? I basically put one stitch on every other joint until it was done, so nothing ever warped. I ground down the beads on the top (for the most part) and then applied body filler on the top. Then I seam sealed all the seams on the backside, so no water intrudes under the filler. I decided to do the strips because it seemed, to be blunt, less artsy. I felt I could make the sides more symmetrical if I had something I could easily copy and mirror, and this way let me do it! Tentacle--you get those parts installed yet? I don't think I've seen it! I'm just doing a Chebby so I don't have to worry about fine-tuning. My goal is to finally just finish the damn thing so I can work on other projects. I'll be doing an E-Rod LS3, so it'll be totally smog legal, and more importantly, turn-key tuned with several thousand man-hours of engineering into it. |
#118 |
Not such a PRVert Anymore
![]() No he hasn't. The s90 is on his to do list :p
#119 | |
B6304 douche
![]() Quote:
#120 |
No crust.
![]() I've now used the stuff extensively on a few different projects and, while it's no bolt, it has worked well. As with any adhesive, surface prep is key.
One nice thing about the 116 is that, while it is a 2 part adhesive, you can apply it with a standard caulk gun (unlike many other 3M and Fusor offerings). Just be sure to buy a pack of mix tips. |
#121 |
Has been
#122 |
![]() Damn....great progress, love the flares, just right!
The E-Rod LS3 is an interesting and wise choice, looking at the spec sheet you just barely got in with your car being an '95 model..lucky you!
#123 |
#124 |
No crust.
#125 |
![]() Yessss... I like this.
1994 945 Turbo Vikingchip EcoMax, 16T, 3" exhaust, TB coilovers/Mitsu. L200 spring, Work VS-S5. ![]() |
