Tom Clark
- Sep 11, 2009
- Albany, OR
1982 244T, no fuel pressure after replacing fuel sending unit.
replaced the fuel sending unit for fuel gauge related issues.
ran great before replacing sending unit
has 6 month old IPD high flow in-tank pump
has 6 Month old main fuel pump
crank no start after replacing sending unit
double checked wiring from sending unit to pump is not backwards (not backwards)
double checked grounds (good)
voltage to pump = 10V
voltage to connector in trunk = 10V
no noise from in-tank pump when key on engine off
removed fuel lines from sender and attempted cranking (no fuel delivered from in-tank pump)
did the newish IPD in-tank pump roll over on me or am I missing something?
