Where did you get your Spartan Locker from. Been eyeballing a lunchbox locker for a while now.
Ebay. Surprisingly quiet when you use 140w gear oil
Not sure on the ratio yet, I'll attempt to clean the tag off tonight.
Called the machine shop yesterday and they'll shave the head for $50.
Next race is in two weeks so I suspect the engine mods won't happen before then. If I can source a locker I may try to get that under the cr before then and save engine mods for the last race or over winter.
Would throwing a B or K cam in quickly do anything or is it a waste of time?
K was stock in B23E on other markets than Norte Americano cars.. So not very frequently found, hence the cachet of "ooooooouuuu rare! must be worth a million dollarz"All great input as usual.
Ursan, So far the car is all stock except a glass pack and side exit exhaust. Well that and the m47 that's obviously not factory in a 740.
Culbertson, how much was the locker? How was the install process?
John, that's a great point. I didn't mention how much when I got that price. I'll have to call back in tomorrow. What cars/years/engines did the k cam come in? I've been searching bit and I'm not finding any solid info.
Ok, I have a few b18/b20's and a couple b21's. I guess I need to pull some valve covers. Cams are marked on the end right? Easily visible?
Mr.'Bone, how much was the locker? How was the install process?
If you shave the head that much there will be slack in the belt, which translates to the cam timing being off and adjustable cam gear being a solution.
I think I've heard of people using a Pinto 2.3L T-belt?
Nope, not even close. *EDIT to remove personal attack. You know better.I think I've heard of people using a Pinto 2.3L T-belt?
2.0 pinto belt for square tooth. Kyle found a Hyundai timing belt that's 1-tooth shorter for the round tooth setup. I'll see if I can get the part #.VB242 said:I'm pretty sure it's the 2.0l pinto engine, I have one somewhere.
