Old 06-20-2014, 01:03 AM   #1
2-3 Heaven
Default T5 swap gone bad
So my M47 went in my '90 245. I figured why not do a T5 swap. Got the fluid in it tonight and fired up the car to a slight squeaking from the trans. It wasn't bad and went away with light pressure on the clutch pedal.
The big problem comes in when I push the pedal in further. I get a couple of inches of travel without issue, but then I get some nasty grinding. I tried pushing the pedal in a little past where it started and the engine starts to die. Below is my setup. Please help guys. Oh, the pedal is adjusted so I have an 1/8" of freeplay at the fork which is basically maxed out the adjustment on the cable.
WCT5 from a '95 Mustang V6
'93 Mustang V8 input shaft
Trimmed bearing sleeve .68" to match shorter input shaft
Mustang V8 TO bearing
Mustang 4cyl turbo 9" disc
Stock Volvo pressure plate
Stock Volvo dogdish flywheel
M46 clutch fork w/ Kaplhenke blocks
Triangles Unlimited spacer
2-3 Heaven is offline   Reply With Quote
Old 06-20-2014, 03:11 AM   #2
sbabbs
sbabbs's Avatar
We'll on any manual transmission if you push the throw out bearing too far it will push the pressure plate fingers into the clutch disc. Common problem. You need to adjust something so your not pushing it too far.
1990 745 B230FT Getrag JohnV flywheel 240mm clutch 13c A-cam 3.54 G80 542K MILES
Old 06-20-2014, 08:44 AM   #3
poulrais
poulrais's Avatar
Clutch disk put in with wrong side facing the FW?
1990, Volvo 740 16v +T
Old 06-20-2014, 09:50 AM   #4
SwedishBee
Drill em deep
SwedishBee's Avatar
Should this setup have Volvo or Ford throw out bearing?
Originally Posted by CrazyChopStick View Post
I bought an 850.
SwedishBee is offline   Reply With Quote
Old 06-20-2014, 10:07 AM   #5
Lord_Athlon
Sf1k Kryptonite
Lord_Athlon's Avatar
Ford. He said hes using the ford bearing retainer.
Originally Posted by rvolvor
Old 06-20-2014, 10:50 AM   #6
soclosenotnear
What are the blocks and spacer? Does it matter if you use the m46/m47 clutch fork?
soclosenotnear is online now   Reply With Quote
Old 06-20-2014, 10:51 AM   #7
The v8 ford TO bearing is really short and not a good match for the height needed for the Volvo pressureplate.
My guess is your clutch fork is hitting the pressureplate.
Other thing you should check is clutch pedalwear. Sometimes the hole becomes a slot and that can really mess up your engagement range.
www.BEIGEPOWER.com
Kaplhenke Racing Facebook
The only safe bet is Ben.©
Old 06-20-2014, 11:16 AM   #8
Mylesofsmyles
Volvo Spec for clutch fork free play is 1.5mm, not 1/8", though I don't think that'll help your issue any.
Old 06-20-2014, 11:22 AM   #9
That won't make any difference.
Old 06-20-2014, 12:32 PM   #10
2-3 Heaven
I guess I should have mentioned that the clutch isn't disengaging, so I don't think that this is it.
Old 06-20-2014, 12:35 PM   #11
Chewy
Chewy's Avatar
Disc too thick?
Able to measure stock disc vs mustang disc?
Originally Posted by alreadyupsidedown View Post
Just think of K-jet as an extremely complicated mechanical Rube-Goldberg carburetor.
Originally Posted by volvo240skunk37 View Post
Good God son, you're just a pile of fail.
A-A-Ron
Now: 69 142 "Inga" Build Thread
Had: 80 242 "Elsa" Build Thread
Chewy is offline   Reply With Quote
Old 06-20-2014, 12:36 PM   #12
2-3 Heaven
I double-checked this before I installed everything else. Plus it looked like the disc wouldn't have even installed clearance-wise the other way due to interference with the flywheel and pilot bearing.
Old 06-20-2014, 12:37 PM   #13
2-3 Heaven
The clutch pedal feels good, but I'll check it out.
What TO bearing should I use instead? Will I need to change the bearing retainer as well?
Old 06-20-2014, 12:42 PM   #14
2-3 Heaven
Originally Posted by Chewy View Post
Disc too thick?
I didn't measure them but did just take a quick look side by side. They looked incredibly close. I just swapped stock Volvo for stock 4cyl Mustang. The Volvo disc was only a few months old with basically no miles. How much difference would you need to create an issue?
Old 06-20-2014, 01:06 PM   #15
http://www.summitracing.com/parts/mcl-16515
These work great, lets you get it all setup pretty nicely.
Old 06-20-2014, 01:53 PM   #16
Mylesofsmyles
Hmmm, sounds like the freeplay I mentioned is suspect...
Maybe you should adjust it within spec.
Also, when I did my T5 Conversions, I had trouble with the "aftermarket" style clutch cable...I couldn't get enough adjustment. I exclusively use the O.E. style, where the set knob, threads onto the cable housing itself....the other style, with limited adjustment on plastic fine threads doesn't get tight enough.
O.P. you mentioned grinding....as in grinding when trying to engage a gear or just in general? If the clutch doesn't fully disengage, then it'll grind going into gear...I'm sure you know this.
Sounds an awful lot, like the clutch cable adjustment is off. 1.5MM freeplay is SPEC for VOLVO
Old 06-20-2014, 01:54 PM   #17
Lord_Athlon
Sf1k Kryptonite
He is saying it grinds when he puts in the clutch. Freeplay wont make it do that.
Old 06-20-2014, 02:11 PM   #18
2-3 Heaven
Perfect, thanks. I'll pull the trans tomorrow to make sure, but this looks like the issue.
Not to go all TB on you, but wouldn't spacing out the pivot ball work as well?
Old 06-20-2014, 02:16 PM   #19
2-3 Heaven
I can see your point, but it is grinding from the bellhousing without even trying to get it into gear, which I don't see happening if it is just an adjustment issue. I'll nail down the adjustment once the grinding is cleared up and I have a fork return spring installed. I have enough adjustment to get it within spec, but nothing more. I'm guessing once I have the proper length TO bearing installed, I'll gain a bunch of adjustment.
Damian
Old 06-20-2014, 02:44 PM   #20
Falconxl
Check to make sure the bearing retainer is not pushing the clutch disc up against the flywheel. When I did my T-5 swap the clutch would not release even after adjusting the cable and shimming the pivot with no change we measured the distance to the center hub of the clutch disc and discovered the retainer was pushing on it, so I had to trim about 1/8" off the retainer to get the clearance from the clutch disc. Transmission was from a 91 Mustang GT so it should have fit without problems, may have just been a bunch of small variances that all added up to the interference.
Falconxl is offline   Reply With Quote
Old 06-20-2014, 02:58 PM   #21
2-3 Heaven
That's the one thing I didn't measure, if I'm honest. I shortened it to match the input shaft change, but never actually checked the clearance. I don't think it would cause the other issues I'm having, but I will certainly look it over before I throw the trans back in.
How did shimming the pivot work for you? I don't mind ordering the bearing that Ben recommended, but I'm being a bit impatient. I just did coilovers and most of the poly bushings in the car, and I'm getting antsy to drive it.
Old 06-20-2014, 03:06 PM   #22
DaveD
DaveD's Avatar
This is what happened to me. Fork would travel too far and contact pressure plate.
Build Thread
DaveD is offline   Reply With Quote
Old 06-20-2014, 06:19 PM   #23
Hank Scorpio
Chubfest 2009 Survivor
Hank Scorpio's Avatar
When I did this years ago before the to adapters, my Volvo TO wouldn't make contact before the fork hit the PP. Should be easy enough to visually see thru the bellhousing hole while someone works the clutch.
Old 06-21-2014, 01:07 AM   #24
Mylesofsmyles
Could also have a broken rivet on the fork pivot ball
Old 06-21-2014, 09:53 AM   #25
Canadan
Canadan's Avatar
Could just pull the trans and find out yourself instead of asking for speculation. ..just saying
Canadan is offline   Reply With Quote
