Old 02-15-2017, 12:30 AM   #1
photoman327
photoman327's Avatar
Default M-46 service
Need to service the M-46 in my 84 242 and the book call for Type F or Type G. Call the dealer in Huntsville and they said Type G goes in the M-47 as well. Is the type G the mineral oil that you don't replace? Also where do you get a pan gasket or do I make my own? Car now has 144,000.
Old 02-15-2017, 12:47 AM   #2
Type F.
how psi a stock can support?
Old 02-15-2017, 12:59 AM   #3
photoman327
Type F.
I know but it did not smell Like Type F.
Old 02-15-2017, 01:13 AM   #4
Well it's ~20 years old, what do you expect it to smell like?
Or what Jim-Bob had to put in there, or band-aid the O rings?
Old 02-15-2017, 01:19 AM   #5
planetman
planetman's Avatar
I have always used ATF in M46s.
However if you have to have type G, I found this website in the UK.
http://www.carlube.co.uk/transmissio...smission-fluid
I have aftermarket oil pan gaskets for the J/P O/D for $9.60. Volvo OE pan gasket is $22.67.
Eric
Torrance, CA 90502
Old 02-15-2017, 01:26 AM   #6
quillc
yv1a.com
quillc's Avatar
Greenbook says type F for M46.
That said, I've seen people run all kinds of fluids.
Redline makes a synthetic type F.
IPD sells pan gaskets, but I've always just made my own from a sheet of FelPro that I have. Easy-peasy.
Chris
www.yv1a.com
Old 02-15-2017, 01:33 AM   #7
photoman327
Even burnt Type F should smell like type F. Never smelled anything like it. Will check in the morning.
Old 02-15-2017, 01:34 AM   #8
Simi
:3
Simi's Avatar
I have heard that Type F, 10w30 or 10w40 will work.
I am running 10w40 and I noticed that the box shifted smoother.
Simi is offline   Reply With Quote
Old 02-15-2017, 01:36 AM   #9
photoman327
That's is what I did when I had the 86 740 m-46. May have some type G.
Old 02-15-2017, 01:40 AM   #10
photoman327
Heard the same thing and jumped the gun and ordered redline MTL that I may not use if I have some G.
Old 02-15-2017, 10:28 AM   #11
Cwazywazy
Cwazywazy's Avatar
I just used el cheapo type F from Carquest. Works just fine, beats having nasty 20+ year old ATF by a lot.
Old 02-15-2017, 12:56 PM   #12
photoman327
Right! I have the right stuff from Volvo and after seeing the specs I would use Mobil 1 75wt gear oil. It's slick ****. Got some Redline coming and will check the spec but Mobil much cheaper[URL=http://s1335.photobucket.com/user/Impalaman6/media/Mobile%20Uploads/2017-02/D9D816E8-9695-489B-ADA3-3CFED29015DC_zpsg6nzxdkg.jpg.html][/
Old 02-15-2017, 01:03 PM   #13
photoman327
10-40 will work but check the specs of the right stuff and check that paint that has not been washed since I rubbed on it two weeks ago. Now for the rest of the car ! LOL
Old 02-15-2017, 01:48 PM   #14
oldschoolvolvo
oldschoolvolvo's Avatar
Good on ya.
-Mike
1998 V70 T5
Old 02-15-2017, 09:12 PM   #15
photoman327
Got the redline MTL in and it half dozen in one hand and 6 in the other. Going to see if I still have a material data sheet on the Mobil 1. Now thinging Redline or Volvo type G since both designed for manual transmission and redline may be the choice for extended periods. Type F although recommended not nearly as good as the the three mentioned. My car now at 144,000, will get the good stuff since I can't build a M-46.
Old 02-15-2017, 09:22 PM   #16
Tuff240
240 Ninja
Tuff240's Avatar
I've run Type F, Valvoline 10-30, 10-40, 20-50 and Redline MTL. Seemed to like the MTL best. Just my 2 cents.
-Patrick
Old 02-15-2017, 09:50 PM   #17
photoman327
How often do you you change it?
Old 02-15-2017, 09:55 PM   #18
Cwazywazy
Cwazywazy's Avatar
Volvo says it's for life after the break in change. 10-20 year intervals is probably fine IMO.
Old 02-15-2017, 09:57 PM   #19
Tuff240
240 Ninja
Tuff240's Avatar
Rarely do I own a car long enough that I need to change it.
Orange car I did all fluids every track day.
Other than that, I like to change any oil when it starts changing colors. Usually WAY before the recommended intervals. Takes some watching and testing to figure out. Redline motor oil in my orange 242 would start changing color around the 1500 mile mark depending on how hard I had been driving it.
Old 02-16-2017, 01:55 AM   #20
photoman327
Well, I keep them until the cows come home. Part of my overdrive issue was low fluid. Measured what I drained out and it was only 1.6 qts.
Old 02-16-2017, 07:15 PM   #21
photoman327
Serviced the M-46 and made the gasket
