Old 02-15-2017, 09:43 PM   #1
per0lund
per0lund's Avatar
Default Wasted spark v/s direct fire?
Iīm in to upgrading the wasted spark coil pack in to direct fire
In my mind a wasted spark is right what it says, wasted energy that probably could be better used.
I have four small standard E-core coils suited for most stock electronic four cylinder distributor ignition systems, with a primary resistance of 0,8 ohms, and the DiYAtotune quad spark ignition module.
The coils should each deliver 36000 volt@2000 sparks/min if fed with enough power.
It may bee the quad spark module is more suited for coils with 0,4 ohm primary resistance, but Iīm just not shure how the quad spark module will work with higher resistance
Iīm not experienced in direct fire systems, but if these coils work, I believe they still would be more efficient than the Bosch Motorsport coil pack (0,4 ohm at primary).
If it works it will be a very low budget direct fire system as these coils are only 18 U.S $ each
I havenīt checked out whether I need a extra camshaft sensor ,or if the software of MS3X V3.57 can use only the stock crank signal for direct fire.
I got a feeling someone else has tried this concept before me.
And I do not expect a great difference, but never the less it may still be a small improvement of engine efficiency, at a fairly decent cost.
Volvo 745 -90 B-230FK , M90, 3,31:1 Eaton diff,-MS3X 83 lbs/hr injectors TD04HL-20T
S60 2,5T AWD
SAAB 9-5 2,3T
Ford Thunderbird LX -95
per0lund is offline   Reply With Quote
Old 02-16-2017, 01:05 AM   #2
142 guy
If all you want to do is get rid of the double ended coil you don't need a cam sensor. You can still do the wasted spark trigger and firing arrangement; but, use an individual coil on plug (kind of difficult on a B230) or coil near plug arrangement on each sparkplug. I don't know the specifics of MS3. You might need an extra TC427 driver chip to provide 4 logic level ignition outputs. With the wasted spark arrangement you just fire two coils at the same time as opposed to sequential which requires the cam position signal.
Old 02-16-2017, 05:09 AM   #3
per0lund
per0lund's Avatar
I already have a DiyAutotune QuadSpark Ignition Module, and thought that would be enough, without having any extra TC427 driver chip.
Old 02-16-2017, 12:04 PM   #4
142 guy
If the MS3 has 4 (or more) logic level ignition outputs, then you are correct that you do not need an additional TC427 if you are running full sequential ignition; but that requires a cam trigger.
If you don't want to add the cam trigger and are prepared to retain the wasted spark triggering configuration; but, fire two coils at once , then if the MS3 software allows you to run wasted spark and reconfigure two existing logic level outputs to fire at the same time, you don't need a TC 427. You might be able to pair up two inputs to your quadspark and run them directly off of one logic output from the MS3 without a separate TC 427 driver. That would require that whatever the MS3 uses as a driver have enough current capability to drive two inputs on the quadspark at the same time. Without dissecting the MS3 to figure out its schematic, I would not risk that.
Perhaps its just easier for you to figure out a cam trigger and go full sequential rather than risk modifying the MS3.
Old 02-16-2017, 12:35 PM   #5
Lord_Athlon
Sf1k Kryptonite
Lord_Athlon's Avatar
Have you thought about reading the manual?
Originally Posted by rvolvor
Old 02-16-2017, 12:52 PM   #6
JohnMc
JohnMc's Avatar
This just doesn't work conceptually. It's a 4 stroke engine, the crank makes two complete rotations between each individual cylinder firing.
With only a crank signal, the ECU has no way to tell where in the cycle a given cylinder is, Nearing TDC on the compression stroke (need to fire that spark!) or nearing TDC on the exhaust stroke. Wasted spark setups just don't care, and they'll fire the spark in both situations, because it doesn't really hurt much of anything to fire a spark at the outgoing exhaust gasses.
To allow the ECU to tell the difference between the compression stroke and the exhaust stroke, you need a cam sensor. The cam turns at half the speed of the crank, so it can tell the ECU which phase a cylinder is in, compression or exhaust. And the ECU can only fire the spark when it needs to.
Yoshifab makes a nice adapter to run a DSM engine sensor in the block mounted distributor spot. This has both sensors in it - crank and cam. One sensor 4 wires, works great. It's a powered sensor too, so it sends nice clear 5V ON and OFF signals to the ECU, not those squirrelly variable voltage blips that the ECU has to make sense of that the stock flywheel sensor sends.
'63 PV Rat Rod
'93 245 16VT Classic #1141
Old 02-16-2017, 12:53 PM   #7
JohnMc
JohnMc's Avatar
Also, what Lord Athlon said. It's a learning curve, but you'll be better off understanding what all the sensors are doing, and why.
Old 02-16-2017, 06:57 PM   #8
per0lund
per0lund's Avatar
Well I expected a cam position sensor would be necessary, I plan to use one from the B-230GLE <-88 (in distributor).
This is a pic of the coils, larger than normal direct fire coils but not that large. I will make a "sort of" coilpack of my own.
Old 02-16-2017, 07:07 PM   #9
gross polluter
They see me trollin'
gross polluter's Avatar
Am I reading this right? You want to replace a wasted spark system.... with a wasted spark system?
Old 02-17-2017, 02:28 AM   #10
per0lund
per0lund's Avatar
Hardly, four coils a quad channel ignition module/amplifier, a cam position sensor, and a crank position sensor wouldnīt really be needed for wasted spark ignition.
Iīm more in to a sequential ignition or direct fire.
Old 02-17-2017, 02:59 AM   #11
cosbySweater
cosbySweater's Avatar
get a yoshifab cas and apropriate sensor and wire it up. or just run wasted spark, nothing wrong with that
1979 Volvo 244DL 6.0/4l80e,8.8,Ms3x goldbox ecu and Mircrosquirt tcu, s366 clone.
1982 Ford Fairmont Futura, 4.8/th400, 8.8, mircrosquirt, 7665 turbo, Project Cheap Thrills
Old 02-17-2017, 03:29 AM   #12
gross polluter
Guess I'm confused as to the point of this thread since this topic has been covered and executed hundreds of times.
X3 RTFM
Old 02-17-2017, 03:41 AM   #13
cosbySweater
Read the fvcking(factory) manual
Old 02-17-2017, 08:30 AM   #14
per0lund
per0lund's Avatar
The quad ignition module came without a complete documentation, I donīt find all specs about it.
Old 02-17-2017, 09:44 AM   #15
MrBill
fige=500Dollar Mistake
MrBill's Avatar
AFAIK the quadspark module is four BIP373s in a plastic box.
Someone say crazy rays?
Old 02-17-2017, 08:02 PM   #16
142 guy
If you go to the DIYAutotune website and look under Products / Ignition you will find your module. On that page there is a documentation link which covers connection of the module to the various versions of MS and the coils. Arranging for a cam position signal is a separate matter.
Old 02-18-2017, 05:28 PM   #17
per0lund
per0lund's Avatar
Yes I did, but wiring isnīt my worry, question is rather can this module operate these slightly higher primary impedance/resistance coils 0,8 ohm well. They won`t run hot in first place that's fore shure.
As I understood itīs most common to run 0,4 ohm HVC coils like the Bosch Motorsport wasted spark coil pack, or IGN-1 Inductive Coil.
I already have a extra distributor from a B-230E -85 engine with a hall sensor, I can use for cam signal. I don't se a problem in that.
Old 02-18-2017, 07:42 PM   #18
142 guy
If the DIYAutotune ignition module is based upon the Bosch BIP 373 driver, there may not be a point to a really low resistance coil. Do a search on 'Bosch BIP 373 datasheet' and you will find that the BIP 373 has an internal current limiting feature. The typical value is limiting at 12 amps. The maximum limiting value is 16 amps. The Vce sat value of the BIP is around 2 volts. If your car is running around 14 volts, the net voltage to the coil is around 14- 2 = 12 volts. With a 0.4 ohm coil resistance that would translate to a peak coil current of 30 amps with no current limiting and unlimited dwell. Clearly the BIP will limit current before it hits that value. With a 0.8 ohm coil resistance the peak coil current with no limiting and unlimited dwell will be 15 amps, so the BIP may or may not enter current limiting.
Because of the self protection built into the BIP 373, it should be able to handle either a 0.4 or 0.8 ohm coil without risk of damage to the BIP (assuming that it is properly mounted on a heat sink surface). The more important question will be what is the repeated current limit on your 0.8 ohm coils. The 12 - 16 amp limit in the BIP may be beyond the limit of the coil if you do something really silly with your dwell time. Find out what the dwell limit is for your coil, respect that limit in the ignition settings and the BIP 373 won't present any issues for you.
Old 02-19-2017, 05:39 AM   #19
per0lund
per0lund's Avatar
Thank you that is what I wanted to know.
I donīt have all data for these coils all I know is Primary resistance 0,8 ohm inductance 5,6 mH,
Secondary is 1,1 KOhm and 30H.
Old 02-19-2017, 10:30 PM   #20
142 guy
If you go to the MS Megamanual ignition section (B&G, not MSExtra), they provide a discussion and an analytical model for calculating the spark energies from a coil based upon the coil resistance, inductance, charging voltage and dwell time. I think they also link or you can find references on the web that discuss the spark energy required for reliable ignition. You already have the resistance and inductance and should have a reasonable value for your coil charging voltage. Once you find the range of spark energies required to achieve reliable ignition, you should be able to use the B&G analytical model to calculate what is a reasonable maximum dwell that you should be using for your coil. The B&G model is not perfect; but, it should provide you with a good starting point for estimating dwell if the coil vendor does not specify a maximum dwell and maximum primary current.
Old 02-20-2017, 06:11 PM   #21
per0lund
per0lund's Avatar
I tried to find it but, couldnīt so far, can you make a link?
Old 02-20-2017, 07:20 PM   #22
142 guy
This is the calculation for Dwell time.
http://www.megamanual.com/ms2/configure.htm#dwell
Here is the BG link that has the spark energy calculator:
http://www.bgsoflex.com/igncoil.html
Its based upon a points type ignition system and dwell is entered in degrees rather than time. You will have to convert time to degrees which is speed sensitive. With a fixed dwell time that means that calculator can only give you a correct spark energy at the RPM that you did the conversion at. A bit clunky, but, informative.
I referred to spark energies; but, in fact what I meant was the stored energy in the ignition coil. The B&G calculator is also dealing with stored energy and not actual spark energy. In a perfect world, the stored energy in the coil would equal the energy dissipated in the spark. Reality is that because of parasitic losses and other effects, the actual spark energy will be less than the stored energy in the coil; however, it should be reasonable close. Calculating the stored energy in the ignition coil is extremely easy if you don't want to use the B&G calculator. It is given by the simple formula
Energy = 1/2(Li**2) where L is the primary winding inductance (in henries) and i is the peak primary coil current (in amps) just before triggering of the spark.
I will let you search for references about required spark energies. I recall seeing some references which suggest that 30 mJ is a good value for reliable ignition.
Old 02-22-2017, 03:22 PM   #23
per0lund
per0lund's Avatar
Thank you, I was looking in the wrong place.
It seems like slight less 0,4 would be a proper dwell.
Old 02-22-2017, 03:35 PM   #24
142 guy
0.4 what ??? 0.4 ms would seem a little short. How did you work that out?
Old 02-23-2017, 02:45 AM   #25
per0lund
per0lund's Avatar
4 ms, but I īm not sure what values for current to put in.
The amplifier has a max output of 11,5 amp. If I put in 7 amp. dwell value raises to 5 ms and if amp is calculated to 10, dwell becomes more than 9 ms.
