Old 02-16-2017, 09:43 PM   #1
spoolywizard
spoolywizard's Avatar
Question 740 turbo cams
i am looking to upgrade my cam on my 86 740 turbo from the stock t cam to the a cam from a euro 740 from the b230et engine. has anyone here ever done the swap? ,is it worth it and is the power difference noticeable
Thanks
1986 740 turbo wagon 4speed
1987 240 DL wagon 5speed
-VAGABOND-
spoolywizard is offline   Reply With Quote
Old 02-16-2017, 10:34 PM   #2
Wilford Brimley
enjoys the beetus
Wilford Brimley's Avatar
Isn't it the same?
(Insert Photobucket pic here)
http://forums.turbobricks.com/showthread.php?t=316428 91'744T .57 t3/t4, big ic, greddy type s, 55lb/hr injectors, bosch 044, tloa ecu/ezk, 3"amm, rsi stg 3 cam, ttr cam gear, top mount header, 3" exhaust, kevlar tbelt, e-fan, 22 psi, intrax springs, cherry turbo brace, ipd rear sway, dual front sway bars, bilstein struts, camber mod, accum mod
Old 02-16-2017, 11:42 PM   #3
PromiseRing
We don't even like Volvos
Originally Posted by Wilford Brimley View Post
Isn't it the same?
No, according to this, the euro motor would have the "A" cam.
Op, I had a B cam in my +t motor (b is similar to a), and it pulled pretty hard compared to the stock cam. You may lose some low end though.
Current
straight pipe
-93' 245 m47-iPd sways, B-cam
Past
-80' 242gt m46-
spill it MClovin and WTF happens to your glasses you piece of ****..
Feedback Thread
PromiseRing is online now   Reply With Quote
Old 02-17-2017, 12:14 AM   #4
Wilford Brimley
enjoys the beetus
That'd be sweet
Old 02-17-2017, 02:22 PM   #5
Addi_Sig
My friend had a 740ti with a B230ET engine, with the waste gate actuator preload as tight as possible and a chip from Sweden.
My Nissan Laurel never had as much acceleration as when it was towed home on my friends 740 when the nissan's engine broke down
Addi_Sig is offline   Reply With Quote
