Old 02-17-2017, 02:57 AM   #1
dirtbag240
Default unknown gauge light
he folks so I'm brand new here, I just got a 1989 245, and was wondering if anyone could help me figure out what this light was connected too/ what it meant, anything is helpful here's a photo
dirtbag240 is online now   Reply With Quote
Old 02-17-2017, 06:19 AM   #2
alschnertz
Enough already!
alschnertz's Avatar
Choke (actually fuel enrichment device) is on.
You could always check the owner's manual. They're available online and have lots of good information about the car if you are not familiar with its operation.
Old 02-17-2017, 09:59 AM   #3
Kenunot
In what part of the world does an 89 245 have a choke?
Kenunot is offline   Reply With Quote
Old 02-17-2017, 10:48 AM   #4
freevolvos
Maybe it's an early cluster?
Old 02-17-2017, 11:35 AM   #5
cleanflametrap
cleanflametrap's Avatar
The cluster shows 20kph sitting still.
-Art
Old 02-17-2017, 12:38 PM   #6
Kenunot
I think OP is probably a troll so good for you.
I saw this in US owners manuals up until around 1985
Which I would interpret as "Warning you are in Canada".
Old 02-17-2017, 12:46 PM   #7
dirtbag240
hey guys hate to break it to you not a troll,actually didn't notice the 20kph standing still thing till this morning,and yep I am definitely from Canada, I would have looked on the manual but alas I do not have one.
and I'm definitely a novice here but why would a fuel injected motor have a choke?
Old 02-17-2017, 12:54 PM   #8
Kenunot
Why would you put milk in a bag or have 2 official languages?
Canada is very mysterious.
Old 02-17-2017, 12:58 PM   #9
cleanflametrap
Well, it is a very good question. I'm just as interested in the answer. I mean, the fuel injection needs the same thing a carbed engine needs for starting and warmup, but we only call it a choke as metaphor. I doubt Volvo connected that light to the ECU of an EFI motor to alert you to the warmup function.
Instead, I get a strong hint the car may have been owned by someone before you, and given its age, accumulated some modifications. I think that's what happened to you. You got an earlier cluster.
Here in US (check my location) the 88 and earlier had the choke light in the third position so if an 88 cluster got stuck into an 89 (maybe to make it sell) the Check Engine Light (CEL) no pun intended would appear at the choke light. To see if this is your situation, briefly remove the 25A blade fuse under the hood (you should by now know this fuse) and put it back in. Check with the key on and start it up to see this choke light turned off.
Old 02-17-2017, 01:14 PM   #10
Kenunot
Canadian cars with a B21A have a carb. http://forums.turbobricks.com/showthread.php?t=323599
It would have to be an earlier cluster with a later electronic speedometer. Or the year is wrong. The VIN will tell you everything https://www.volvoclub.org.uk/vin_200.shtml
Old 02-17-2017, 01:26 PM   #11
dirtbag240
there was a definite cluster change as he mentioned he did the big clock small tach swap if that helps put any insight to what it may be?
Old 02-17-2017, 01:31 PM   #12
cleanflametrap
Don't hold back now...
Old 02-17-2017, 01:39 PM   #13
dirtbag240
"Airbox has also been improved to increase airflow and i've done away with the preheating flapper and wax filled mini "piston" that is a common to fail item that can overheat and damage the air mass meter."
just a copy and paste from the original ad, other then that nothing else I know of that's been done to the engine or cluster,though there may be a fuse issue as the lighting behind the cluster will sometimes not turn on after a particularly rough patch of road?
Old 02-17-2017, 01:55 PM   #14
cleanflametrap
You bought the car from a TBer.
Old 02-17-2017, 01:55 PM   #15
Kenunot
That is a separate issue probably the fault of the dimmer switch.
Have you decoded your VIN so you know what you have yet? Then you can determine what is supposed to be there. The weird thing about an earlier cluster isn't the funny light but the fact that it is lit.
Old 02-17-2017, 02:10 PM   #16
cleanflametrap
I guess he's at work or school. Can take suggestions but not act on them yet.
Old 02-17-2017, 03:20 PM   #17
dirtbag240
I may be foolish but I can't seem to de code this with the link you guys gave me, any input?
and yes currently in school so a bit stuck on being able to actually do things right now
Old 02-17-2017, 05:37 PM   #18
Kenunot
lol no, that would be my bad. That was the first result when I googled "volvo vin decoder" and it is not for US and Canada cars.
YV1AX8850K1810685
YV1 = it's a car
A = 240
X = 3 point safety harness
88 = B230F
5 = 5 door wagon
0 = Check code US/Canada
K = 1989 model year
1 = [Sweden] Torslanda Plant VCT 21(Volvo Torslandaverken) (Gothenburg)
810685 = chassis code
from https://en.wikibooks.org/wiki/Vehicl...olvo/VIN_Codes
Old 02-17-2017, 05:54 PM   #19
I checked the wiring diagrams and it seems the choke light connection (connector 32, pin 3) was re-purposed as the check engine light on later clusters. Try clearing the codes and see if it goes out.
Old 02-17-2017, 06:53 PM   #20
bobxyz
bobxyz's Avatar
That's the rare "Choke PO" light. We all wish we had one at times....
bobxyz is online now   Reply With Quote
Old 02-17-2017, 09:55 PM   #21
freevolvos
88 would be Volvo Chrysler ignition no c,e,l light?
