Old 02-04-2006, 05:32 AM   #1
phillazenby740t
Snorting coca cola
phillazenby740t's Avatar
Question elusive b230ft double valve springs
Does anybody know of anyplace that might sell double valve springs for my b230ft, just ordered ipd turbo cam and im afraid the stock ones will float.
Thanks
Phil
phillazenby740t is offline   Reply With Quote
Old 02-04-2006, 05:34 AM   #2
volvo944ti
stock ones should be fine but i believe volvo sells double valve springs for the b230's
volvo944ti is offline   Reply With Quote
Old 02-04-2006, 07:31 AM   #3
Kjets On a Plane
Devoid of Luxury
Kjets On a Plane's Avatar
Is your rev limiter set to the stock 6K? If so, don't bother IMO. At most get a set of stiffer single springs.
How PSI a stock can support?
Old 02-04-2006, 09:01 AM   #4
pbonsalb
For the IPD cam and stock engine management, stock springs are fine. New stock springs would also be fine if yours are high mileage (like 200,000 miles). If you are using 7000 rpm or more, you may want to look into a cam beyond the IPD cam and stiffer springs. I use stiffer single springs, rather than double springs. There is no advantage to creating any more drag on the valvetrain than is necessary.
Philip Bradley
pbonsalb is offline   Reply With Quote
Old 02-04-2006, 10:14 AM   #5
volvorsport
you could also buy some inner springs quite cheaply
muhahhahahhhahhaha !!!!!!!!!!!!!!!!!
volvorsport is offline   Reply With Quote
Old 02-04-2006, 10:24 AM   #6
Boosted242
Boosted242's Avatar
i just got some springs for my b230ft. they are out of a nissan engine. they are much stiffer than volvo stock springs, but they are the exact some diameter and size. so they fit perfectly, no changing the seats or retainers. if you give me a day or two i'll get the box from my shop and give you the exact specs so you can try to order some.
1982 242 with '94 B230FT... full blown race car... she's really boosted
Boosted242 is offline   Reply With Quote
Old 02-04-2006, 11:39 AM   #7
str8krewzn
str8krewzn's Avatar
Question hey
So if using a 531 with kg2t cam and planing to redline at 7k
stock valves wouldnt cut it?
were can i get stiffer springs?
str8krewzn is offline   Reply With Quote
Old 02-04-2006, 11:51 AM   #8
B20Paul
Get springs & retainers from KG Trimning when you get the cam. Single springs will pass through bad harmonic periods, the only exception being the varible rate barrel shaped springs that are gaining in popularity.
B20Paul is offline   Reply With Quote
Old 02-04-2006, 03:27 PM   #9
The Aspirator
It's a girl!
The Aspirator's Avatar
Please do! That would be really interesting information to have floating around the board.
'83 242
'95 T5R
'98 S70
The Aspirator is offline   Reply With Quote
Old 02-04-2006, 06:04 PM   #10
ElPiloto
Any kind of valve spring will weaken significantly after 50 to 100 thousand miles. At least get a new set of stockers. If you want to wind it over 6000 rpm, go stiffer.
"Four in a row makes it go"
ElPiloto is offline   Reply With Quote
Old 02-04-2006, 06:13 PM   #11
str8krewzn
str8krewzn's Avatar
Question so
Is there anywere in the US that sell stiffer springs?
Old 02-05-2006, 01:26 PM   #12
Patrick
For 6000 stock springs work just fine, 7000 is the limit (that is where I have my stop), if you want to go above 7000 you need harder/double springs.
But with redblocks, 6000 is enough for 300 hp, 7000 is 400+ territory.
Patrick
member of Team AP-Turbo Racing
1984 Volvo 245T 303 RWHP@16 PSI but now @20 + mods -> 396 (Theoretical) RWHP
1979 Porsche 931 ~400 hp
Patrick is offline   Reply With Quote
Old 02-05-2006, 01:47 PM   #13
str8krewzn
str8krewzn's Avatar
Question ko0
But im not sure how much miles the 531 has
and im getting larger vlaves in it
so im not sure if stock springs strong
enough to hold larger valves and go up to 7k
Old 02-05-2006, 02:03 PM   #14
Stereophile33
Stereophile33's Avatar
I will disagree that 7000+ rpm is 400+ territory.
Peter made 400+ horsepower at 5200 RPM with a 6000 rpm redline........these are not honda motors. Great HP can be made at a useable range.
Stereophile33 is offline   Reply With Quote
Old 02-05-2006, 04:17 PM   #15
frpe82
Guest
I´m just saying, easy power: 375.8HP / 533NM (393lb/ft) @ 4000rpm @ 1.7bar (25psi)
And it is mostly on common parts (at least here in Volvo country).
Don´t believe me? Look here: http://www.garaget.org/?car=1562
Tell me if you need any translation.
Old 02-06-2006, 12:27 AM   #16
DerSnart
Keyboard Engine Builder
DerSnart's Avatar
Originally Posted by frpe82
Im just saying, easy power: 375.8HP / 533NM (393lb/ft) @ 4000rpm @ 1.7bar (25psi)
Dont believe me? Look here: http://www.garaget.org/?car=1562
On 7:1 none the less.... crazy. Any more info on the nissan springs yet?
1982 242 GLT 5spd (no turbo )
Originally Posted by isaac
I've got this problem where I blow up engines a lot due to merciless boosting.
DerSnart is offline   Reply With Quote
Old 02-06-2006, 01:11 AM   #17
mAydAy
Fabricatin'
mAydAy's Avatar
Comp Cams 981-16
PN: 981
Quantity: 16
# Outside diameter: 1.254 in.
# Inside diameter: .880 in.
# Seat load: 105 lbs. at 1.700 in.
# Open load: 295 lbs. at 1.250 in.
# Coil bind: 1.150 in.
# Rate: 423 lbs.
Widely available, very very welllll tested in race duty, drop in springs for a B230.
-Andy
Originally Posted by KLowD9x View Post
As long as I can sit in the corner and watch you get it on with an admin while I masturbate with nothing but tears in my hand, I will be happy.
mAydAy is offline   Reply With Quote
Old 02-06-2006, 03:21 AM   #18
frpe82
Guest
Originally Posted by DerSnart
On 7:1 none the less.... crazy. ...
Yes, it was just a little thing on the side to show you can make power without high RPM.
Old 02-06-2006, 09:24 AM   #19
Patrick
Missunderstand me correctly.
I am not talking about where max power is, rather what I meant with 7000 rpm is where the usable rev-range is. For example a more or less stock engine will have a useable range from 2500 - 5500, start tuning with a larger turbo, another cam etc, and you will most likely move the range higher. A typical 400 hp redblock will most likely have a range from 3500 - 7000.
In most cases the more power you make the higher rpm you will have to use.
Actually rpm = horsepower, but that is a different discussion.
The most interesting part of that power is that the dyno said 303 RWHP and then managed to make that 375 FlyWHP, that is why RWHP is always much more interesting to read about.
Also, the peak hp was at 6000 rpm and peak torque was at 4000.
Patrick
Old 02-06-2006, 10:25 AM   #20
VQ
Not such a PRVert Anymore
VQ's Avatar
and torque is what makes the thing go, horsepower is merely a byproduct.
hellastock
Speed Bumps? No Problem.
264 GLE RIP
88 740T wagon
1964 122s
88 760GLE
Old 02-06-2006, 10:38 AM   #21
JohnMc
JohnMc's Avatar
This is an old chestnut of the web.
But torque is meaningless without rpm. And if you combine torque with rpm, then you get HP. HP is the meaningful measurment that includes both how hard the motor is twisting and how fast it is twisting, which results in how much work it can do. Torque, by itself, is almost meaningless. An old flour mill water wheel, for example, could have huge torque figures, staggering amounts of torque, with multiple buckets of water weighing 200 lbs each pressing down on a 12 foot long arm. But it turns at 25 rpm, and thus only produces 1 or 2 hp. Torque figures can be misleading, it's nearly impossible for a HP figure to be misleading.
Torque at 4000 rpm is nice. The same amount of torque at 8000 rpm is twice as nice.
'63 PV Rat Rod
'93 245 16VT Classic #1141
Old 02-06-2006, 11:51 AM   #22
Patrick
This does not add anything to the discussion, but I just thought I'd make things even more lovely (and confusing for those that have not been enlightened), what makes the car accelerate is torque at the wheels...
Not engine torque and not engine horsepower.
Patrick
Old 02-06-2006, 01:25 PM   #23
rallyvovo
too much bs to read in this thread, but you can vuy double valve springs from Sten parner Motor in Sweden for not a whole lot
stenparnermotor.se
:::: 9 series pimpin' ::::
rallyvovo is offline   Reply With Quote
Old 02-06-2006, 02:19 PM   #24
pbonsalb
If these springs are also sold under a Crane part number, I am pretty sure they are in my built B230FT. I bought them from Summit a couple of years ago. Reportedly, they were drop in, but the machine shop told me otherwise. As I recall, there was an issue with the Volvo retainer. The shop either made a change to adapt the retainer or ordered another aftermarket part, possibly from Scat. The shop did, however, like the spring and its specs for use in my built motor. It researched alternatives and came up with nothing better that we could get in the US on short notice.
Philip Bradley
Originally Posted by mAydAy
Comp Cams 981-16
PN: 981
Quantity: 16
# Rate: 423 lbs.
-Andy
Old 02-06-2006, 02:51 PM   #25
JohnLane
I have not seen anyone mention what the safe speed limit is for stock springs.
If double springs are not NEEDED I would not fit them.
