Old 06-02-2017, 07:13 PM   #151
Pro Sneaker Peddler
Always time a stock cam straight up.
Old 06-02-2017, 07:44 PM   #152
soclosenotnear
Really nice, clean looking wagon. So, the timing being off is what had you down on power? Also, what made you convert to round tooth gears?
Old 06-02-2017, 10:01 PM   #153
VeroDubs
The Big Swede
VeroDubs's Avatar
I will be from now on. Definitely like the driving characteristics of it straight up!
Honestly, I got the cam gear for $60 in the group by and another member hooked me up with the crank and IM gear for $40. So cost is the main reason. I was also told and read that the round tooth is less likely to jump teeth.
And yeah, the difference in Power below 4K is crazy. The power band starts around 25-2800 and pulls all the way through 5500-6000.
My '89 Brick -"The Big Swede"
VeroDubs is offline   Reply With Quote
Old 06-02-2017, 10:42 PM   #154
MrBrown
You like popsicles?
MrBrown's Avatar
Yay an update!!
GhettoFab build thrizzie
Old 06-02-2017, 10:49 PM   #155
VeroDubs
The Big Swede
VeroDubs's Avatar
Originally Posted by MrBrown View Post
Yay an update!!
My "to be installed" pile is growing fast. Got to start getting this stuff installed!
Old 06-03-2017, 06:50 AM   #156
oldschoolvolvo
oldschoolvolvo's Avatar
Nice project. Good work with the e-codes and 16vT will be a hoot!
-Mike
1998 V70 T5
|Feedback|
Old 06-03-2017, 05:30 PM   #157
VeroDubs
The Big Swede
VeroDubs's Avatar
Thanks, the ecodes changed the whole looks. And I'm turboing the 8v first, then build a 16v on a stand.
I did dyno it today to get my base line. Made 110.1whp @ 4950rpms and 130ft/lbs
Old 06-03-2017, 09:17 PM   #158
oldschoolvolvo
Ah gotcha! Sounds like a reasonable plan.
Old 06-03-2017, 10:53 PM   #159
LC4CARL
Aero challenged
LC4CARL's Avatar
Looks nice.
Life begins at 10PSI.
Old 08-05-2018, 06:46 PM   #160
VeroDubs
The Big Swede
VeroDubs's Avatar
So, can everyone else see my photos now? Apparently they have come back from the dead... I got some big changes happening and am thinking about updating the thread!
Old 08-06-2018, 03:09 PM   #161
MrBrown
You like popsicles?
MrBrown's Avatar
Looks like it. Get some updates.
Old 08-12-2018, 07:31 AM   #162
VeroDubs
The Big Swede
VeroDubs's Avatar
Well the T5 lost 1st and 2nd gear. Not sure what happened, but apparently the humming on deceleration was actually not a good thing
So I started hunting around to source a new T5 to swap everything over to and came across something better.
Of course a new engine means tear down and my boys are all about taking things apart!!! My older one tore down almost the entire engine with my guidance.
Also ordered a new strut bar, but I am pretty sure I will need to switch the a car intake to make it work.
Talking to a guy right now on facebook about a Weiand 300-111 intake for pretty a good deal with billet fuel rails.
Next on the purchasing block to make this thing ready to install-
-STS Motor and Tran Mounts
-220/220 Cam
-LS2 Timing Chain
-Hooker Cast Headers
-New oil pan to clear subframe
-New stall. Thinking 3000 or 3200. See what I can get a better deal on.
Also need to work on piecing together the accessories for the front of the motor to work with the intake. I know I can maintain all the truck stuff and relocate the idler and cut the bracket, but the alternator will stick up so high. All thing I will have to figure out.
Old 08-12-2018, 01:43 PM   #163
MrBrown
You like popsicles?
MrBrown's Avatar
Nice. Keep updating. I want to swap out the red block for something else one day.
Make them boys learn early!
Old 08-14-2018, 12:51 AM   #164
Vol242vo
Vol242vo's Avatar
So cool to show your kids how to enjoy something you love too! I don't think enough parents have the patience to teach and guide something like this to youngsters. A+ dude!
Derek - 1980 242
Old 08-14-2018, 09:18 PM   #165
VeroDubs
The Big Swede
VeroDubs's Avatar
I will. Really can't wait to get the LS into the Volvo. It is going to be a completely different vehicle!
Thanks! I definitely try and keep my boys working on new things and learning. All things I wish I would have done more with my dad when I was younger. And when they ride in a fast car and there faces light up, it's awesome!
I did drive over to the center of the state and snag up some new suspension for when I start tearing things apart. Needs new inserts and I may need to upgrade the front springs to compensate for the weight of the new motor.
Old 08-15-2018, 09:02 AM   #166
Uncleknucklez
bruspeed
Uncleknucklez's Avatar
Nice! I would seriously consider redrilling those top mount stud holes to mount those plates so they help with caster instead of camber if handling is important to you. I wish I would have done that on my set. Caster is really important in these cars, and as we lower them (and add rake like I did) we are removing some caster.
1980 242 Turbo
2004 V70R
