Old 08-07-2018, 11:43 AM   #726
HUB
Needs more cowbell
HUB's Avatar
Thank you everyone for the support.
HUB is offline   Reply With Quote
Old 08-07-2018, 02:27 PM   #727
Jack
junkman
Jack's Avatar
Congratulations on new addition. I been teaching my 11yo daughter to drive my Amazon, you'll be there before you know it. I love the attention to detail on your project.
Donít bother, I would literally rather throw them away than give you the pleasure. I will never sell to you.
Old 08-07-2018, 03:13 PM   #728
pat244ti
pat244ti's Avatar
Have not checked on this one in a while, lookin good!
- Patrick
83 244ti - road race
83 244ti - rally
73 1800es - resto
08 c30 T5 6spd - daily
97 dakota 5.2 4x4 single cab short bed - apocalypse mobile
Old 08-11-2018, 08:20 AM   #729
Funkee
Funkee's Avatar
Very nice, love the details! Hope the POR15 holds up, I have nothing but bad experiences with that stuff after a couple of years.
Old 08-12-2018, 06:44 AM   #730
HUB
Needs more cowbell
HUB's Avatar
Thank you everyone! Appreciate the support as always!
Old 08-12-2018, 06:51 AM   #731
HUB
Needs more cowbell
HUB's Avatar
Morning Everyone,
Had a few items arrive the other day.
Cargo carrier came in. This will be used on the 122 and my 325xi (currently mounted it to the 325xi).
Bought an 850 NA TB from a friend. Started cleaning it up. I guess I can swap out the plate for a 960 one that doesn't have the plastic piece for some better airflow. So if you have one, please let me know.
10 mins in the Ultrasonic cleaner.
Another round in the cleaner.
Radiator arrived last night. My current plan is to drill holes for the inlet, outlet, and mounting...
Thanks,
Old 08-12-2018, 06:47 PM   #732
HUB
Needs more cowbell
HUB's Avatar
Good Evening Everyone,
After a day of battle, the radiator is in. Should have enough room for a fan setup. However, front nose portion by the hood latch will need cut/ modified. Will also have limited room for a intercooler. Still trying to figure what size I need for my application.
Thanks,
Old 08-22-2018, 08:16 PM   #733
HUB
Needs more cowbell
HUB's Avatar
Got the intake manifold back from a coworker. As always, he did an amazing job! Bolted up and looks good. Will get it decked and the off for powdercoating.
Thanks,
Old 08-26-2018, 03:52 PM   #734
HUB
Needs more cowbell
HUB's Avatar
Starting putting the front back together. I have decided to mount the intercooler behind the radiator and put the fan in front due to space.
Thanks,
Old 08-26-2018, 06:04 PM   #735
Tfrasca
Tfrasca's Avatar
Looking so good!
Hey, do you know the purpose of that plastic wedge on the 850 throttle plate?
Old 08-26-2018, 06:16 PM   #736
77volvo245
77volvo245's Avatar
Originally Posted by Tfrasca View Post
Looking so good!
maybe it's there make the throttle to feel heavier
STSmachining
Old 08-26-2018, 07:31 PM   #737
Tfrasca
Tfrasca's Avatar
I'm hoping it's to reduce the on/off tendency of that TB on the 2.3 liter. I don't have the plastic thing and it feels like I'm at 1/2 throttle if I just barely touch the pedal.
Old 08-29-2018, 06:08 AM   #738
VQ
Not such a PRVert Anymore
VQ's Avatar
Looking good. Why haven't you ported the exhaust manifold at the same time that you machined it flat? The hole is smaller than even your wastegate port, and the first thing smart people do is port the manifold even with a td04 stock turbo. Let alone a larger one like what your using. Especially with a non stock intake!
hellastock
Speed Bumps? No Problem.
264 GLE RIP
88 740T wagon
1964 122s
88 760GLE
Old 08-29-2018, 06:42 AM   #739
HUB
Needs more cowbell
HUB's Avatar
No idea. Have 960 plate to swap it if I donít like it.
Thanks,
Old 08-29-2018, 01:15 PM   #740
Jack
junkman
Jack's Avatar
That’s just common side effect of going to NA throttle body on turbo whiteblocks. Plastic plate or not...I imagine it’s the same for using that TB on redblocks.
Whiteblock turbo TB is substantially smaller maybe for this reason
Some don’t like it. I do. That modification along with lightened/underdrive crank pulley we’re the only two performance mods my wife noticed on the 850
Edit... the plastic on came on early na 850s, dint remember the reason anymore
Old 01-13-2019, 03:31 PM   #741
HUB
Needs more cowbell
HUB's Avatar
Good Afternoon,
Sorry for the lack of posts. Having a little one makes things a challenging. Haha.
Intake manifold back. The thermostat neck will be modified. Also continue to work on the wiring.
Thanks,
Old 01-13-2019, 11:41 PM   #742
Vol242vo
Vol242vo's Avatar
Nice and tidy, well done!
Derek - 1980 242
Old 01-14-2019, 11:34 AM   #743
HUB
Needs more cowbell
HUB's Avatar
Thank you!
Old 01-14-2019, 03:50 PM   #744
stick70
All the gauges
stick70's Avatar
Looks good! Where's that pod gonna mount?
Returnless fuel system?
Old 01-14-2019, 05:43 PM   #745
R32RennSport
Outlaw Amazonian
R32RennSport's Avatar
Looking great, keep going!
I know the challenge, I pulled my Amazon apart almost three years ago right after having my first daughter and now with my second daughter I'm lucky to log a few hours a week in the garage if that.
1966 Volvo Amazon, 2004 VW R32 Golf
R32RennSport is offline   Reply With Quote
Old 01-14-2019, 06:37 PM   #746
HUB
Needs more cowbell
HUB's Avatar
This is my main gauge cluster. Havenít finished the return fuel setup under the hood. Everything else has been plumbed.
Thanks,
Old 01-14-2019, 06:39 PM   #747
HUB
Needs more cowbell
HUB's Avatar
Haha. Yep. Just get in the garage on Sundayís.
Thanks,
Old 04-01-2019, 03:06 PM   #748
jmc0369
jmc0369's Avatar
I really appreciate your efforts and cataloging this endeavor.
Member: TBCCS
"Emancipate yourselves from mental slavery; only ourselves can free our minds" - you know who!
"It is no measure of health to well adjusted to a profoundly sick society" - Jidu Krishnamurti
jmc0369 is offline   Reply With Quote
