Old 07-30-2018, 12:37 AM   #2051
LC4CARL
Aero challenged
LC4CARL's Avatar
Is there a way to “pre lube” a red block? I used to spin the oil pump on my Chevy with drill at the distributor drive.
Life begins at 10PSI.
Old 07-30-2018, 12:55 AM   #2052
Pro Sneaker Peddler
Spin the auxiliary shaft before putting the timing belt on.
Old 07-30-2018, 03:34 PM   #2053
LC4CARL
Aero challenged
LC4CARL's Avatar
Figures. Lol.
Old 07-30-2018, 03:41 PM   #2054
Uncleknucklez
bruspeed
Uncleknucklez's Avatar
Yeah, good way to check things before you get too far, I also prime the system by pulling the coil wire to the distributor and let the starter do the work, once you have pressure pop the wire back on and you're good to go.
1980 242 Turbo
2004 V70R
Old 08-02-2018, 11:22 PM   #2055
LC4CARL
Aero challenged
LC4CARL's Avatar
Good stuff. Should help me find the leaks and give me some peace of mind that she's not dry on start up.
Can anybody tell me where this goes?
Old 08-02-2018, 11:26 PM   #2056
LC4CARL
Aero challenged
LC4CARL's Avatar
Cleaned the fan-of-power.
Need some longer studs.
Old 08-03-2018, 02:14 AM   #2057
John242Ti
LH-Jet & Carb Free Zone
John242Ti's Avatar
Underside of the manifold. Heatshield for the alternator.
You can see it just below the turbo in this shot:
-J
Old 08-03-2018, 12:06 PM   #2058
culberro
culberro's Avatar
Somebody get this man a 90+ manifold stat!
Old 08-03-2018, 02:21 PM   #2059
LC4CARL
Aero challenged
LC4CARL's Avatar
Thx John.
Yeah, chicks dig '90+ manifolds.
Old 08-03-2018, 03:44 PM   #2060
Pro Sneaker Peddler
Meh, I promise no difference will be noticed.
Old 08-03-2018, 04:46 PM   #2061
culberro
culberro's Avatar
But jurbo is so much easier to mount on 90+ (once it's been milled flat and opened up).
Even if the 90+ 10hp increase over the early style is a farce, totally worth the upgrade just for ease of mounting... and for all the cracking that will inevitably happen.
Old 08-03-2018, 04:48 PM   #2062
Pro Sneaker Peddler
It can't be easier to mount if the turbo is already mounted!
Old 08-03-2018, 06:47 PM   #2063
bobxyz
bobxyz's Avatar
It rotates 90deg forward in this pic and bolts to the bottom & right side of manifold (the right side bolt also goes through spark plug heat shield). [click for full size]
Old 08-03-2018, 09:53 PM   #2064
LC4CARL
Aero challenged
LC4CARL's Avatar
Excellent / thx!
Old 08-04-2018, 11:07 PM   #2065
LC4CARL
Aero challenged
LC4CARL's Avatar
I need to install longer studs on the hot side of the turbo. I tried heating the cast iron housing with propane and backing out the stud with two nuts jammed together. Going to hose down with penetrating oil tonight. Would acetylene help? Do those weird stud tools that (I think) use an eccentric work?
Old 08-04-2018, 11:49 PM   #2066
Keep boiling the rust out with CLP break free and a heat gun, quench the nuts & stud with an ice cube, repeat until they come out.
Old 08-05-2018, 10:22 AM   #2067
LC4CARL
Aero challenged
LC4CARL's Avatar
Thx boss.
Need some help sorting my down pipe. Wish to connect the 3" V-band outlet from the ATP to the existing tubing. Need to check under the car to see what diameter the stock pipe is. Maybe 2.25"?
So, on Summit Racing we have a variety of 90* mandrel bends. Thought maybe a tighter 3" radius on top and a 6" radius on the bottom would clear things. Hopefully. Do I want stainless?
https://www.summitracing.com/parts/aph-10534/overview/
A stainless V-band top and bottom.
https://www.summitracing.com/parts/sum-694300
Braided, 12" long, flex pipe.
https://www.summitracing.com/parts/aph-8853/overview/
Not sure about heat wraps. Maybe this?
https://www.summitracing.com/parts/dei-010127/overview/
Kind of struggling with the reducer. As mentioned, under the car want to take the 3" down to the factory pipe. Will measure to confirm diameter.
So then O2 bungs for the LH2.2 and wide band?
What else?
Plan to have first 90* on at start up. Drive it to the shop open pipe, have the exhaust guys fit it together.
Old 08-05-2018, 07:38 PM   #2068
cwdodson88
Columbia River Mandrel Bends.
The Build Thread
SVEA - PUSHROD TURBO!
Old 08-06-2018, 12:36 AM   #2069
Pro Sneaker Peddler
Originally Posted by LC4CARL View Post
Thx boss.
What else?
Call Dan Crandall and have him sort ya out
Old 08-07-2018, 12:15 AM   #2070
LC4CARL
Aero challenged
LC4CARL's Avatar
My car hates me.
Old 08-07-2018, 07:42 AM   #2071
MrBrown
You like popsicles?
MrBrown's Avatar
My car hates me.
Mine hates me too.
What happened?
GhettoFab build thrizzie
Old 08-07-2018, 10:42 AM   #2072
soclosenotnear
They all hate all of us.
soclosenotnear is online now   Reply With Quote
Old 08-07-2018, 11:54 AM   #2073
Pro Sneaker Peddler
The turbo has a little crack by the wastegate hole. Carl's just being a baby
Old 08-07-2018, 12:04 PM   #2074
Don't they all?
Old 08-07-2018, 12:05 PM   #2075
Pro Sneaker Peddler
Indeed
