Old 05-21-2017, 12:14 PM   #26
MrBrown
You like popsicles?
MrBrown's Avatar
Build a leak tester using pvc cap from the plumbing section and a tire stem.
GhettoFab build thrizzie
Old 05-21-2017, 12:21 PM   #27
centason
Knipex=welfare queen
centason's Avatar
cheapest way and it works great.
Member: TBCCS
"People will believe a big lie sooner than a little one, and if you repeat it frequently enough, people will sooner or later believe it." -Walter Langer
Old 05-21-2017, 09:18 PM   #28
TurboDenny
Why am I here?
That's what I had in mind and it worked well. got all the leaks taken care of! It builds 20psi no problem, which is a problem within itself. Seems the wastegate can't keep up.
Instagram: @itstotesdenny
Old 09-17-2017, 03:03 PM   #29
TurboDenny
Why am I here?
While this setup has been fun for the summer, it's time to move on to bigger and better things!
I'll be ditching the T5 in favor of a TH400 since I don't think the T5 is going to like the new power goals. I'm really torn between keeping the redblock and just swapping in an I6 whiteblock. I'll be shooting for ~450-500whp next spring. I'll have to do more research on how well the B230 will withstand that power.
I have a MS3pro Ultimate ECU sitting on my desk, which will be plenty for either engine I decide to go with. Rear end will be swapped for a beefier unit as well, however I'm still undecided on which I will use.
Old 08-07-2018, 05:29 PM   #30
TurboDenny
Why am I here?
It's put back together again! Really lost interest in this thing over the past few months, but it feels great to see it rolling again! Just a stock redblock and M47 for now while I figure out the whiteblock swap.
Added some ATS brakes, 25/25 sways, E-code headlights, and new wheels. 17x8/9 et2 BBS LM with 235/40R17 Federal SS-595 rubber. Cut 2 coils out of the front, and 0 rear. Really needs coilovers to sit right, but it handles surprisingly well right now.
Old 08-07-2018, 07:22 PM   #31
soclosenotnear
Really nice looking car. Brakes definitely fill up the wheel.
Last edited by soclosenotnear; 08-08-2018 at 09:53 AM.. Reason: break/brake spelling
Old 08-07-2018, 09:45 PM   #32
MrBrown
You like popsicles?
MrBrown's Avatar
Lookin good!
Old 08-08-2018, 12:16 AM   #33
BraZZers
What's the name/manufacturer of those white steelies? I've been looking for something like that in 5x108 for ages!
'88b Volvo 744 B230F - long term project
'88a Volvo 745 B230FB - on hold
'99 Audi A6 1.9 TDI - daily
BraZZers is offline   Reply With Quote
Old 08-08-2018, 12:26 AM   #34
MrBrown
You like popsicles?
MrBrown's Avatar
Diamond racing
Old 08-14-2018, 01:22 PM   #35
6thousandths
I really like the look of this car
6thousandths is offline   Reply With Quote
Old 08-14-2018, 03:31 PM   #36
TH400 makes me sad... TKO would hold up.
www.BEIGEPOWER.com
Kaplhenke Racing Facebook
The only safe bet is Ben.©
Old 08-14-2018, 04:44 PM   #37
80/20 speed parts club
Whoa there Mr. Money Bags
Old 08-14-2018, 04:52 PM   #38
TurboDenny
Why am I here?
Thanks!
You're not wrong, but I will be going for more of a street\strip car, and consistently rowing gears down the 1320 is a challenge. I'd like to pick up a 242 eventually and make it handle well.
Old 08-21-2018, 02:30 PM   #39
TurboDenny
Why am I here?
Started working on the T6 swap. Received my bellhousing adapter for the TH400 last week from KL Racing, and am currently working with Roger Dee to get an adapter made up for the torque converter. Also trying to find a 960 semi-local to yank the engine out of for the rest of the swap parts. Once I get the oil pan I can start mocking things up and fabricating engine/trans mounts. I think I'm going to make a new trans tunnel to fit the TH400, driveshaft loop, and clearance for a 1 piece driveshaft. We'll see how close it is.
Old 08-21-2018, 03:46 PM   #40
That bellhousing looks awfully wide. Will it even allow a decent size down pipe past?
Old 08-21-2018, 04:07 PM   #41
TurboDenny
Why am I here?
The "ears" on either side are getting cut off. It's no larger than a 4l80 or T56 bellhousing once that's done. 3" shouldn't be a problem at all, especially if it makes a turn beforehand and heads for a fender...
Old 08-21-2018, 07:17 PM   #42
Hank Scorpio
Chubfest 2009 Survivor
Hank Scorpio's Avatar
I don't know why you'd need a new trans tunnel, it'll be the same bellhousing as every LS/SBC swap on here.
Edit: what's your plan for the oil sump since you're going vertical on the motor? Going to mod it at all or leave it be?
Old 08-21-2018, 11:21 PM   #43
TurboDenny
Why am I here?
We'll see. I'm mainly concerned about the driveshaft. I'm going to use a 1 piece aluminum shaft. Would also allow me to set the engine back a little further. Like I said, we'll see.
Haven't thought about the oil system yet.
