Old 07-25-2018, 08:55 PM   #76
MrBrown
You like popsicles?
MrBrown's Avatar
Awesome. Good info.
GhettoFab build thrizzie
Old 07-28-2018, 07:09 PM   #77
MSGGrunt
Swapped in a cleaned non deteriorated front passenger's door panel and a cleaned non deteriorated rear passenger's door panel. I am waiting to install the driver's side rear once I make a trip to my local pick n pull to see if I can find a good vapor barrier. I ordered two new ones for the front, but it appears the backs are NLA.
I am also looking for a good driver's side front door panel. The fiberboard on the lower part of mine is literally falling apart. Probably didn't help that the vapor barrier was missing. I used heavy duty Gorilla tape to install/seal the new barriers.
PM me if you have a nice tan panel you would like to part with.
1969 Triumph TR6
1986 BMW E30 325E, Auto, 2-door coupe.
1989 BMW E30 325iX 5-speed
1990 Volvo DL 240 Auto
1991 Volvo 240 Auto
1992 Volvo 240 GL Auto
1993 Volvo 245 5-speed.
2015 Volvo XC60 Platinum
MSGGrunt is offline   Reply With Quote
Old 07-28-2018, 07:12 PM   #78
MSGGrunt
Installed new "C" pillar trim pieces as well. These were originally black that I sprayed to match the rest of the interior.
I found that the contact for my window defroster had come "unstuck" from the window. Will have to look into a fix for that.
Old 07-28-2018, 07:28 PM   #79
MSGGrunt
The original rear door panels came with speakers in them, but the very clean replacements I used did not. I thought about trying to remove and swap the speakers, but wasn't so sure it would work well.
Then I thought about using a speaker mount like the premium sound offered in the same era BMW E30's back on the parcel shelf, that is until I saw the price of what two of these speakers were selling for on eBay.
Still thinking along this line I searched surface mounted car speakers and found that back in the day Pioneer made a TS line that was just what I was looking for. The problem being these are as old as our cars and not many around and those that I did find were for parts, or damaged or not guaranteed to work. Then I stumbled upon a new, still in the box pair of TS-66 that I think will mount nicely on the back shelf. I plan on removing the speakers and painting the plastic housings the same as I have all the other plastic trim pieces so they blend in more than if I just left them black. Nothing fancy and surely not modern sophistication, but that is ok by me.
I have already fished the speaker wires out of the door and just need to extend them to reach back to the rear shelf.
More pics once they arrive, are painted and installed.
Old 07-28-2018, 11:06 PM   #80
nel621
You could make your own vapor barrier with very heavy plastic sheeting available at your local home improvement store. Something like 4 mil if not thicker.
Old 07-28-2018, 11:26 PM   #81
nel621
Also you seem very talented. You can repair the panel. I was able to repair that same exact door panel for friend by cutting the lower half off. I cut straight along the back using the chrome trim in as my cutoff point. I peeled back the fabric/vinyl and over lapped by 1/2 in. some new fiber board from Home Depot. I used Gorilla glue to mate the 2 boards together. Then used some spray glue to bond the material to the board. You will need to make new holes for map pocket hardware. You could also staple the fabric back on but the staples need to be short.
Old 07-29-2018, 07:46 AM   #82
MSGGrunt
I did give some thought about fixing it until I got a good look at how extensive the damage is. After seeing how high up on the panel the deterioration was I decide on just finding a new panel.
Old 07-29-2018, 08:02 AM   #83
nel621
Still doable. Cut at the line, overlap the new section 1.5 inches above line, reinforce small section on right with fiberglass. Took me a while to find that same panel, driver side in good condition. It gets the most wear on the fabric.
Old 07-29-2018, 08:35 AM   #84
MSGGrunt
There is one for sale on eBay right now, but it appears to have wear on the fabric like you mentioned. I just had a thought, I have a couple driver's side panels in black, maybe I could remove the tan cover and install it on the good fiber board from the black panel. Of course then I would have to sacrifice a nice black door panel.
Old 07-29-2018, 08:48 AM   #85
sksmith
sksmith's Avatar
Sometimes it needs to be done when redoing an old car.
If you have the skills, I say go for it. No sense in not taking this all the way, it looks great so far.
Steve
sksmith is online now   Reply With Quote
Old 07-29-2018, 09:35 AM   #86
MSGGrunt
I just sorted through my hoard and have three complete sets in black, one set is going with some other interior parts I sold to a member on here, the other set is truly in perfect condition and it would be sacrilegious to sacrifice one of them, the only way you could find nicer panels is if you bought them new from the dealership, I am amazed at how nice they are, but the third set I guess I can bring myself to sacrifice a panel.
Old 07-29-2018, 09:35 AM   #87
nel621
Just go up to the damaged area. Don't give yourself more work. Easier to cut a straight line.
Old 07-29-2018, 10:52 AM   #88
MSGGrunt
No turning back now. Donor panel stripped, the tan cover removed from the rotted panel and now air drying after a good cleaning.
Old 07-29-2018, 11:17 AM   #89
TurboDenny
Why am I here?
Looks ridiculously good so far. I'm impressed.
Instagram: @itstotesdenny
Old 07-30-2018, 09:00 PM   #90
MSGGrunt
Back to the speaker project. They arrived today. Production date on the box was 1988, so very period correct. And to think these are new in the box. How they look in the car without the headrests installed. Once the headrests are installed I feel they will blend in nicely, especially painted tan to match the rest of the interior.
Old 07-30-2018, 09:10 PM   #91
MSGGrunt
My shifter cover is cracked and I went on the hunt for a new tan one and I found they are either not available or more money than I wanted to spend.
Another "project". I had a perfect cover in black, but clearly this would not match my interior. Looking at the cover's underside it looked like the top cover piece was pressed onto the main body while hot to retain the gear indicator and bushes. I drilled out the rivet looking things and the top cover came right off along with the brushes and gear indicator panels. Now I could paint everything and put it back together without getting paint where I didn't want it. I secured the top plate with gel superglue and it is holding perfectly.
Old 07-30-2018, 09:44 PM   #92
nel621
Have you tried a dry fit with rear headrests? Curious as to clearance. Shifter cover looks great.
Old 07-30-2018, 11:35 PM   #93
brickcupra
Hi, do you speak spanish? I just happenned to see the word " bocinas" before logging in. I a m working in some speaker covers as well from an old school toyota that need some small modification before putting some pioneer speakers to them as well. Nice interior job. Mine will have suby seats with suby/ saab seat covers with white center and black ends matching the black side panels and white roof.
seeya
DZ
brickcupra is offline   Reply With Quote
Old 07-31-2018, 07:00 AM   #94
MSGGrunt
I don't speak Spanish.
nel621, I did dry fit them and there is plenty of room. They actually "hide" pretty well behind the head rests.
Now I still have rear speakers they are just on the parcel shelf now instead of in the door panels. And I have nice clean, non rotted rear panels.
Old 07-31-2018, 08:38 AM   #95
57plymouth
57plymouth's Avatar
Where did you find a perfect set of brushes for the shift bezel?
Sven, the 1991 245
Old 07-31-2018, 10:34 AM   #96
Stiggy Pop
Stiggy Pop's Avatar
I hope you're getting some frequent flyer points with SEM
'79 242
943 pickup
Old 07-31-2018, 03:12 PM   #97
MSGGrunt
I was just lucky with the brushes.
SEM, while not inexpensive, is good quality and has been very durable.
Old 07-31-2018, 04:04 PM   #98
mblue240
mblue240's Avatar
Have you thought about sourcing a set of factory rear speakers and swapping in better speakers? I have a set of factory 6.5" grills that I'm going to hide modern speakers behind.
-Michael
Tbricks build
Yep, Michael is right.
Old 07-31-2018, 04:12 PM   #99
oldschoolvolvo
oldschoolvolvo's Avatar
Impressive. Much respect
-Mike
1998 V70 T5
|Feedback|
Old 08-01-2018, 06:27 AM   #100
MSGGrunt
I like the Volvo speaker boxes, but I imagine not very easy to find. I had a hard enough time finding the ones I did. It seems back in the 80's these were a popular style, but times have progressed I guess.
