Old 07-27-2018, 10:37 AM   #26
thessejway
Wannabe TBer
thessejway's Avatar
Default All red taillights
Tested out the all red taillights last night with some red film
Inspired by MrBrown
thessejway is offline   Reply With Quote
Old 08-06-2018, 07:42 PM   #27
thessejway
Wannabe TBer
thessejway's Avatar
Thumbs up All Systems Go?
Had a very productive and successful weekend
Started this weekend with the goal of getting the car running. It's been sitting in the exact same spot and hasn't been started up since I crashed it in October, for fear of wrecking something in the engine and driveline. On the crushed subframe everything had been pushed back about a 3/4". Also the power steering lines were dry and I figured it wouldn't be good running the pump with no liquid.
Now that the new subframe was in and everything was back in place, I felt confident and ready. I had fuel stabilizer in the 9 month old fuel, power steering fluid topped up and also put in fresh oil and a new filter.
Mind you I still hadn't figured out my collapsed steering column, so I had no steering except by manually reaching down into the engine bay and turning it by hand. So there was no driving even if I had started it.
With the battery charged, I decided to go for it.
After a few failed attempts of the engine just turning over and not starting I realized I couldn't hear the fuel pump. Thankfully I have a bunch of spare relays so I tossed in a different fuel pump relay and... she started right up.
Here's a few clips of it running. Let me know if you think it sounds healthy. I feel like I may need to shim my valves.
I did noticed that on initial startup, it is idling extremely low, but gets up a little higher once warm
It was idling like this for a few minutes
Then was up to about 600rpm when it was more warmed up
Maybe need to adjust the distributor?
After getting it running, I was anxious to drive it so I set about figuring out a way to fix my Steering column. This turned out to be pretty easy. I took a piece of 5/16" steel rod, put it down the top of the column and hammered away. Believe or not, this did a very good job of extending the telescoping part of the column and getting it reattached to the rack
Got the Steering wheel assembly all reassembled and was finally able to dive it for the first time in 9 months. Mind you I didn't leave my driveway.... But I drove it! Now all I need to get it back on the road, is an alignment and an emissions test(Thinking I'll take off the MBC for that).
Oh yeah!
I put my new wheels on.. and I think they look awesome
They fit perfectly flush
A very happy day
This project went from being at a point were I wasn't sure I would ever get it back up and running on Friday to Essentially having it road worthy on Saturday.
Old 08-06-2018, 09:43 PM   #28
soclosenotnear
Congratulations
soclosenotnear is online now   Reply With Quote
Old 08-07-2018, 10:52 AM   #29
thessejway
Wannabe TBer
thessejway's Avatar
Originally Posted by soclosenotnear View Post
Congratulations
Thanks
Feel like a huge weight has been lifted
Old 08-10-2018, 01:12 PM   #30
thessejway
Wannabe TBer
thessejway's Avatar
Default Adjustable panhard bar
How recommended is it that I put in an adjustable panhard bar on my lowered car?
Old 08-10-2018, 01:51 PM   #31
soclosenotnear
Depends how lowered you are. If you're not rubbing the tires on the fender well on either side, and the rear end being off center does bother you aesthetically, I wouldn't bother. Just my two cents though.
Old 08-10-2018, 03:53 PM   #32
thessejway
Wannabe TBer
thessejway's Avatar
I'm about a fingers distance from rubbing. As in I can just barely stick my finger between the wheel and the fender
So the adjustable panhard bar is just aesthetic? and doesn't really affect the cars tracking/performance?
I'll have to do some measuring to see the difference between the 2 sides
Old 08-10-2018, 08:54 PM   #33
soclosenotnear
No, it centers the rear axle. When I lowered my car, it didn't rub. But I could visibly see the rear was off center, and that bothered me aesthetically. So I got an adjustable panhard.
Old 08-14-2018, 02:31 PM   #34
thessejway
Wannabe TBer
thessejway's Avatar
Default This past weekends accomplishments
Did a crappy driveway alignment with some string to keep me going in a straight line until I can get a proper alignment
I've also reduced the amount of camber since these pictures were taken
I got some scrap pre galv sheet metal from work. They were prototypes for a product I was designing that the fabricator messed up.
I have a few things I want to reuse the sheet metal for on my cars. First of which is a cold air intake box. I have very little experince working with sheet metal... other than design parts in solidworks and sending them off to a fabricator. So this was an interessting experience. especially with my limited tools
Started out with a rough "CAD" model (cardboard aided design)
And began tracing and cutting
A brake press would have been nice...
I used the grinder and made some reliefs to get it to bend a little cleaner
Not quite...
A little trimming later
And it fits
Im going to have to work out fastening and get a 45degree elbow for it all to be complete
Also ordering some edge guard, to go around the shard egdes
I know it's not pretty.. but for my first real attempt at working with sheet metal, and with very limited tools... I don't think it's too bad
Also. Discovered this...
Old 08-17-2018, 08:38 PM   #35
JCol91
Macaracachimba
JCol91's Avatar
Good job on that sheet metal!
JCol91 is offline   Reply With Quote
Old 08-17-2018, 10:39 PM   #36
thessejway
Wannabe TBer
thessejway's Avatar
Thanks! not bad for a first timer eh?
Thinking I might redo it to get some better fitment
Old 08-19-2018, 02:00 PM   #37
thessejway
Wannabe TBer
thessejway's Avatar
Default Window Trim
Where can I get this trim from the bottoms of the windows?
Old 08-20-2018, 11:00 PM   #38
JCol91
Macaracachimba
JCol91's Avatar
I'm also in need of a set of those. Dave Barton had them for sale at his website.
http://www.240turbo.com/740WindowMoldings.html
Old 08-21-2018, 08:22 AM   #39
thessejway
Wannabe TBer
thessejway's Avatar
Thanks
Yeah looks like he doesn't have the seals for the fixed rear windows
Old 08-21-2018, 10:35 AM   #40
thessejway
Wannabe TBer
thessejway's Avatar
Default First Drive in 10months
Had the car on the road for the first time in 10 months yesterday
Took it pretty easy, but it felt great!
I've got an emissions test and an alignment scheduled this evening. If all goes well with the e-test I'll be all in the clear and fully road worthy.
Very excited to have putt putt back in service. I've never liked driving any car as much as I love this one.
Old 08-26-2018, 07:58 PM   #41
thessejway
Wannabe TBer
thessejway's Avatar
Default Update
Thought I'd give a quick update on the car
It passed emissions early this week and I've been driving it the last few days
Really missed driving this thing and its so nice to have it back on the road
Did A little cleaning yesterday
Not bad for 25 year old paint
Old 08-28-2018, 08:46 PM   #42
JCol91
Macaracachimba
JCol91's Avatar
Sweet! Good to hear you're back on the road again! Did you get a chance to find a supplier for the window trim?
Old 08-28-2018, 10:06 PM   #43
thessejway
Wannabe TBer
thessejway's Avatar
Thanks! Sucks commuting in my other car now. I just want to drive the Volvo,
...But fuel economy and reliability...
No I haven't been able to find it
Old 08-30-2018, 02:57 PM   #44
Chilm
Double Dutch
Chilm's Avatar
Good job and nice wheels man, outstanding
Double Dutch - Build and goodies thread ;P
Volvo 945 - Blue Pearl - LPT Polar 2.3 Limited Edition
B230-FK Turbo - 90+ ported - 15G Ported - Airintake
Erland Cox Regrind - Blabla Chips - 3 inch exhaust
MBC on 0.95 - Wasted Spark - Sponsored by my wife
Chilm is offline   Reply With Quote
Old 08-30-2018, 08:35 PM   #45
thessejway
Wannabe TBer
thessejway's Avatar
Thanks
They were a great find
Old 09-22-2018, 11:41 AM   #46
thessejway
Wannabe TBer
thessejway's Avatar
Default Quick Q
Just did a quick Compression test
Any Reason to not cut this off, so that I can fit my strut brace?
What are these mounting holes intended for?
Old 09-22-2018, 01:18 PM   #47
white855T
^ That would be for egr stuff which you don't have. Cut as you see fit.
Buyer/Seller Feedback
Old 09-23-2018, 07:13 AM   #48
Sjeng
Sjeng's Avatar
You mean the oil? Normal with stock breather system.
Old 09-23-2018, 02:20 PM   #49
soclosenotnear
Even with egr, I hacked away at that bracket for the same reason. Go for it.
Old 09-24-2018, 08:09 AM   #50
thessejway
Wannabe TBer
thessejway's Avatar
Thanks! I've made the cut
Okay good, Thanks!
