anotherusername
- Mar 9, 2015
- Madrid
Evening fellas!
As I write this I'm about to start crying since I don't know how to proceed anymore...
A bit of background: owner of a 1995 (from Europe) Volvo 940 low pressure turbo B230FK. Currently running poorly on a PNP megasquirt (still a long way to go tuning it) but this shouldn't affect my issue since I plugged in ye good ol' ECU and obtained the same results. No codes on the ECU btw.
Now with the issue.
No start on the Volvo with no spark.
Car was running early December, left it in the garage and now in January it won't start. Battery is not the issue since I tried jumping it with another car after draining the battery when cranking.
Engine as stated turns over, I can hear the fuel pump and it stops after 2 seconds or so. Ignition relay was changed mid-2016, and I can hear 2 clicks.
Already tested the coil and it's working ok.
Unplugged a sparkplug wire and tested there was no spark.
Momentary power on terminals 1 & 15 at the coil when key on position II (then one right before it starts cranking).
Tested Power Management Module connector, got momentary current on pins 1 & 4.
When cranking the RPM needle didn't move (neither on the dash or on the lapotop) so I changed the RPM sensor. Thought this would be the issue but it wasn't.
On the relay I can see how the furthermost interruptor clicks 2 times, withe second one meaning it's not closing the circuit anymore.
I somehow can trick the relay, and after cranking for about 10 seconds, waiting and cranking again the engine starts up with a bang (I believe this must be the fuel injected previously) and even I give it gas it will eventually die after 10.20 seconds of running.
Bonus point: on the tunerstudio screen, the RPM signal icon stays in red while cranking, when I stop cranking turns briefly to green.
Please any help will be welcomed... and I don't wanna think that it's a grounding issue since the car was running before being parked, had never had this issue and now it doesn't start.
Now with the issue.
