jsw8671
- Jul 14, 2016
- Central Ohio
I'm looking into doing a carb-conversion on a b23f, and have figured everything out except the ignition. I want a points/condenser set up if at all possible (at least one person has done it, but didn't say anything beyond 'I dropped an aq series distributor in and it works great'), but I've noticed that the marine distributors all have a slot at the bottom rather than a drive-gear...so does one simply swap the gear onto the distributor shaft, or is there a specific model that drops in, or is electronic ignition the only option? What fits without major modifications?
(Please keep all 'why would you want a carb and/or points set up' responses to yourself)
Thanks!
Thanks!
