Old 09-02-2017, 12:09 PM   #101
BR1CKHOUS3
740s are Volvos too
BR1CKHOUS3's Avatar
What's McKevitt? I'd be up for a trip to Sacramento soon
We don't do it for the glory.
Originally Posted by SlowRide View Post
Only two ways to find out...18 bolts or 18psi
BR1CKHOUS3 is offline   Reply With Quote
Old 09-02-2017, 03:29 PM   #102
gsellstr
Vintage anti-ricer
gsellstr's Avatar
Got a thread on events, McKevitt Volvo, next Saturday, Oct in San Leandro. Our the following weekend there is a generic car meet up here is Sac that the Sac chapter is attending, fundraiser so it is 20 to reg.
Figure I will take the wagon next weekend, nicer on long drives, 140 the following weekend.
RIP
Nick Fengler "fengler" 8/6/18
74 144 B20
90 745Ti
Old 11-15-2017, 02:07 AM   #103
BR1CKHOUS3
740s are Volvos too
BR1CKHOUS3's Avatar
Passed smog with really good numbers. Gotta do something about the one tire fire now that it runs pretty strong
Old 02-27-2018, 11:31 AM   #104
BR1CKHOUS3
740s are Volvos too
BR1CKHOUS3's Avatar
So....T5 injectors ARE apparently plug and play because I put a set in and the car runs Already has a 3.0 bar FPR
Engine is pretty tired and leaky. Trying to find a low-mileage bottom end before Davis
Been happy with the rebuilt 15g. Think the stock turbo was blown?
Old 04-07-2018, 07:15 PM   #105
BR1CKHOUS3
740s are Volvos too
BR1CKHOUS3's Avatar
More Davis prep. 1/2 off weekend at pick n pull so I'm swapping my hydraulic mounts for the old style ones and replacing a control arm that got tweaked by a pothole a while back. A little rain doesn't stop a TB'er
Old 04-10-2018, 05:27 PM   #106
BR1CKHOUS3
740s are Volvos too
BR1CKHOUS3's Avatar
Put the E-fan setup from my 242 in for Davis. Need to clean up and paint the radiator top and IC pipes once I R&D the fan for a couple days and test it out Excited for Davis if y'all can't tell
Old 04-16-2018, 03:42 AM   #107
Janspeed
Originally Posted by BR1CKHOUS3 View Post
is it me or is the passengerside strut topmount installed backward? (L and R topmounts are not installed in the same orientation)
The effect would be less caster angle on the passenger side resulting in less grip in tight left turns. It also has adverse effect on straightline stability.
Easy fix: just jack up the car, maybe remove s/bar droplink, remove topmount nuts, somehow pull that strut downward, spin topmount around 180degr, put nuts back on, etc. Done.
Other then that: nice car!
Old 04-16-2018, 11:05 AM   #108
BR1CKHOUS3
740s are Volvos too
BR1CKHOUS3's Avatar
You may indeed be right...I measured with a tram bar previously and the passenger side is indeed tweaked, but I will flip the mount around and see if the 'tweak' goes away. Definitely not above making a simple mistake like that. Thanks for the sharp eye! I'll post results in a few days...the car is going up on jack stands for a rear main seal, wheel polishing, and some suspension correction
Old 04-17-2018, 08:25 AM   #109
Janspeed
no worries, i have seen it before. I think it is a bit of a design error. Volvo should have designed that topmount so it would have 3 bolts in a triangle configuration. That way it would only be possible to install that topmount in 1 correct orientation.
Let us know if you can feel the difference.
Old 04-17-2018, 02:07 PM   #110
BR1CKHOUS3
740s are Volvos too
BR1CKHOUS3's Avatar
I will definitely report back with my findings
Time for rear main, distributor rebuild, motor mounts, tranny mount, other Davis prep...
Old 04-18-2018, 03:51 PM   #111
Uncleknucklez
bruspeed
Uncleknucklez's Avatar
how is your garage so empty??? Godspeed on your endeavors.
1980 242 Turbo
2004 V70R
Uncleknucklez is online now   Reply With Quote
Old 04-18-2018, 04:30 PM   #112
SquareD
An Anomaly
SquareD's Avatar
Yeah man, looks like a nice space to work. Get er dun.
Old 04-19-2018, 10:36 AM   #113
BR1CKHOUS3
740s are Volvos too
BR1CKHOUS3's Avatar
Thanks guys My roommate and I both came from pretty cluttered homes so we do our best to keep our place nice
Trying to keep myself on track for the show
Old 04-21-2018, 11:27 AM   #114
BR1CKHOUS3
740s are Volvos too
BR1CKHOUS3's Avatar
So I scrapped the 22's my friend gave me, but saved the center caps and....they fit the Azevs! I'm grinding the STANCE logo off for sure. Also gives me an excuse to play with my new bench grinder Going to see if someone can make me some Volvo or Azev logos Giving my back a break today so I started messing with a little metal polish on the wheels and caps
Old 04-21-2018, 06:39 PM   #115
Bling blang on the thing thang.
Old 04-21-2018, 08:44 PM   #116
BR1CKHOUS3
740s are Volvos too
BR1CKHOUS3's Avatar
Polished (left) vs unpolished
Old 04-23-2018, 10:21 AM   #117
Uncleknucklez
bruspeed
I love these wheels, especially with those small caps like that now!
Old 04-23-2018, 04:11 PM   #118
LC4CARL
Aero challenged
LC4CARL's Avatar
Soo jealous...
Life begins at 10PSI.
Old 04-24-2018, 10:11 AM   #119
BR1CKHOUS3
740s are Volvos too
BR1CKHOUS3's Avatar
Thanks guys! I'm for hire if you need your garage cleaned out
Got the TV/monitor off the work bench to free up some space. Used utility hooks because TurboBricks
Old 04-24-2018, 03:09 PM   #120
BR1CKHOUS3
740s are Volvos too
BR1CKHOUS3's Avatar
Instead of methanol or nitrous injection, I decided to go with Premium malt liquor instead. Will report back with power gains
Old 04-25-2018, 02:32 PM   #121
BR1CKHOUS3
740s are Volvos too
BR1CKHOUS3's Avatar
Painting done Time to clean up the engine bay, put the new belts on, and put 'er back together
Old 04-25-2018, 02:45 PM   #122
gsellstr
Vintage anti-ricer
gsellstr's Avatar
Hmm, sounds strangely familiar...
Looks like I have a second driver for Sunday so your car will have some company.
Old 04-25-2018, 03:41 PM   #123
BR1CKHOUS3
740s are Volvos too
BR1CKHOUS3's Avatar
Sweeet. Hope you can give me a ride while I'm there
Now if someone could just polish these wheels for me
Old 04-25-2018, 05:11 PM   #124
gsellstr
Vintage anti-ricer
gsellstr's Avatar
Not too likely on the ride, since in/out from the show is kinda dicey, plus, well, Davis traffic. lol
Old 04-27-2018, 10:56 AM   #125
BR1CKHOUS3
740s are Volvos too
BR1CKHOUS3's Avatar
No worries Gary, we'll do a track night up there sometime
Engine is back together. Testing for leaks before I button everything up
Used this paint for the engine bay stuff. I like it so far. Looks OEM but has a tiny bit of flake in it so it looks nice in the sun.
