Old 09-21-2018, 09:09 PM   #1
MickeyMoose
Default SVO 2.3 in a 142
I have an SVO engine that I was planning to swap into a 4cyl mustang that I have. The car is very rusty and I’m kind of losing interest in the swap do to the poor condition of the car. I recently purchased a 1969 142 that’s an automatic and is in really good shape. I was looking into converting it to manual trans because I can’t stand automatic. I started looking on eBay for all the parts needed and I started thinking...would it be possible to swap the 2.3 into the Volvo? Am I crazy? I started reading about the similarities between the two engines but googled the swap and nothing comes up. I know a lot of SVO guys do the Volvo head swap. Looking for opinions on this swap. Should I just piece together the parts for a manual trans swap or should I get crazy?
MickeyMoose is offline   Reply With Quote
Old 09-21-2018, 10:42 PM   #2
The path of least resistance and expense would be to source an M40 or M41.
The answer to the rest of your question depends on your desires, abilities, workspace, and ultimately your budget for said swap.
Old 09-21-2018, 11:25 PM   #3
Jack
junkman
Jack's Avatar
Better off keeping the b20 or going b230 with or without 16v
Donít bother, I would literally rather throw them away than give you the pleasure. I will never sell to you.
Old 09-21-2018, 11:30 PM   #4
shaned
shaned's Avatar
the 2.3 sounds like a good swap provided you have all the parts. I was surprised how many options that exist for that engine. I would go that way if you are mechanically inclined. I did an m41 swap, and I would recommend getting a parts car. I spent a year tracking down all the parts individually.
shaned is offline   Reply With Quote
Old 09-22-2018, 09:35 AM   #5
MickeyMoose
I have all the harnesses and the computer for the SVO. I think Iím just going the m40 route. I donít want to lose the simplicity of the Volvo. Maybe one day😄
Old 09-22-2018, 11:16 AM   #6
I have an M 40 front driveshaft for $50 plus the ride if you're in need.
Old 09-22-2018, 01:47 PM   #7
2manyturbos
I would lean toward the 2.3 Ford. 300 HP is easy to get out of one of those while still having a very reliable engine. Also, they get 31 mpg in a SVO/Turbocoupe body with the T5 transmission behind them. A 142 isn't anywhere near as aerodynamic, therefore, take 2-4 miles per gallon off of that figure. Something to think about. A B20 with M40 is not going to impress you. I had a 1971 142 with the B20F and M40 back in 1979 when it was a fairly new car. I loved it, except, the fact it was so under powered. Top speed on it was a whopping 91 mph with it floored on a level highway. It only got on the order of 20-22 mpg as well.
Old 09-22-2018, 03:32 PM   #8
Front sump / rear sump, flat tunnel, 430 gears, EFI fuel tank?
There's a few dots to connect here for this swap.
Old 09-23-2018, 08:53 PM   #9
lummert
lummert's Avatar
Lots of info on circle track racing the Ford 2.3.
Old 09-24-2018, 06:13 PM   #10
240240
Cocaina space cowboy
240240's Avatar
Is this build done yet?
Old 09-24-2018, 06:46 PM   #11
Jack
junkman
Jack's Avatar
Lots of info on b23/230/21 builds
Old 09-24-2018, 06:47 PM   #12
Jack
junkman
Jack's Avatar
2.3 Mercedes 16 cosworth gray market of gtfo
Old 09-24-2018, 07:18 PM   #13
80/20 speed parts club
I mean, you have the engine. Throw it on and get something done.
Old 09-24-2018, 07:24 PM   #14
Tfrasca
Tfrasca's Avatar
There seems to be a better aftermarket for that engine, too. Based on my one Google search, of course.
But yeah, throw that thing in there. 140s are way more fun with two or three times the power they came with.
Old 09-26-2018, 11:12 AM   #15
240240
240240's Avatar
16v B20 rsport dual weber biach.
Old 09-26-2018, 11:42 AM   #16
142 guy
On the Sweedspeed forum, about 3 - 4 years ago, there was a thread covering the installation of the turbo version of the Lima engine in an 1800. That thread may provide some usable information.
Old 09-26-2018, 11:53 AM   #17
2manyturbos
There is much better aftermarket support for the 2.3 Ford and a T-5 bolts right up to one. No expensive adapter required. Stock, it will have 2X the power of the B20.
Old 09-26-2018, 05:53 PM   #18
Jack
junkman
Jack's Avatar
yeah but eric and ian arent dead yet
and I haz cossie
