Old 07-18-2018, 05:20 PM   #1
90volvo
Default new condenser unsure how much duracool?
I just put a larger condenser in my 240. I have duracool which I am a big fan of and have ran it for a while. I filled 30 percent of R12 capacity. But I think I am over charged and I cant seem to find a tempature pressure chart? Basically its 100 F. here and my pressures are 45 low and 145 on high side? Im 58 out the vents which is poor for duracool. I put 18 oz. of duracool in the system. Yes, is was pumped down and held a vacuum 24 hours. Please dont tell me duracool is dangerous. Ive read and heard all about it. Thanks.
Old 07-18-2018, 06:28 PM   #2
tryingbe
Boosting along.
tryingbe's Avatar
Did you read what Duarcool have to say?
http://www.duracool.com/-faq.html
85 GLH 367whp
00 Insight mpg > yours.
Old 07-18-2018, 06:47 PM   #3
dbarton
Dejected by Volvo
dbarton's Avatar
I think your pretty close to the correct amount. Volvo usually called for 2.9 lbs R12, which I think is about 16 oz. Duracool. You have a 42 deg drop in temp. Not horrible.
Was this with the fan on low or high? If high, try it on low. Lower fan should produce a cooler temp. Also was this idling or at speed?
Your low pressure seems a bit high to me. Mine runs under 25 psi.
Sounds like you did your homework, but I just want to mention if you accidentally added a bit too much oil, that can reduce efficiency.
Dave B
dbarton is online now   Reply With Quote
Old 07-18-2018, 07:01 PM   #4
I just went by 85% of the r12 label on my 1990 240 when I went to r134. It was over 2 lbs. 2.5 lbs i think.
Old 07-18-2018, 11:03 PM   #5
90volvo
Dave B
I removed some and got my temps to 45. I can live with that, plus low side came down. This winter I want to mod it like you did your AC. But gonna wait til I can park the car for a while. A buddy of mine had a ford ranger that thing would blow 28 on a 100 degree day. Man that would be sweet.
Old 07-19-2018, 06:21 AM   #6
dbarton
Dejected by Volvo
dbarton's Avatar
55 deg drop is about what I'm getting and it works pretty well. Edit: thats at idle. My wife's new Forester gets a 57 degree drop at idle.
Highway speed is different though.
I'm getting a 69 deg drop at 55 mph in my 240. 32 deg F vent with ambient 101.
Dave
