Old 06-03-2020, 05:56 PM   #1
xDread92x
xDread92x's Avatar
Default Very unhappy with turbobricks TAB tool
In just one job the bolt and nut threads are done and the tool wont actually “press” when it comes time. After starting on my second job I was barely able to remove the first but got it. Now after 4 hours of just trying the second one, when it comes time to press the nut and bolt wont even turn, even with a 2 foot breaker bar!
This is ridiculous and has wasted my day. I shouldn’t have to spend time trying to find a replacement bolt and nut after one trailing arm bushing job.
Do the hardware stores even carry an 8” grade 8 bolt. Lowes gave me a galvanized steel 8” that snapped right in the middle after little pressure
xDread92x is offline   Reply With Quote
Old 06-03-2020, 06:08 PM   #2
apachechef
Burnt Sierra Madre
who made it?
did you lube it?
if you made it, you didn't use the proper bolts
Dammit, Lummert.
Old 06-03-2020, 06:16 PM   #3
white855T
It's a fine thread bolt. Its like 7 or 8 dollars for one.
Old 06-03-2020, 06:17 PM   #4
white855T
The holes on mine weren't centered. So it didn't work for removal of bushing. I sawzalled old bushing out. It works for pressing in bushing. You only need 1/2 to 3/4 inches of movement. I hope the oe tool works better.
Old 06-03-2020, 06:26 PM   #5
xDread92x
xDread92x's Avatar
Its the tool being sold on here. I bought it last year. It worked great for the first job. I also remove the metal centers of the old bushing to ensure centering of bolt. The bolt just cant handle several uses. The second half of the bolts threads are screwed. Everything lubed and proper. I know how to do this job right the first time.
I dont know if lowes carrys the grade 8 fine thread bolt. They claim they dont. If I have to order and wait for one ill be furious for sure.
Old 06-03-2020, 06:29 PM   #6
white855T
They don't. It's a special bolt. Mcmaster carries it. Well inas about to say ace hardware might carry one.
Old 06-03-2020, 06:29 PM   #7
xDread92x
xDread92x's Avatar
Yea exactly. More bs
Old 06-03-2020, 07:04 PM   #8
Just for your information. The center bolt on my genuine volvo tool is considered the 'consumable' part of the tool. When the bolt on mine broke I got a new one from Baum tools. That is when I found out the bolt is the wear item on this tool. With plenty of penetrating oil on the bushing for a few days and then the tool well greased I haven't broken a bolt in a long time.
1982 242 turbo. 340k miles. MVP coilovers and 3" exhaust. Flowed 405 with a V15. Cossie turbine housing with upgraded compressor housing. 90+, IPD remote oil filter. Some other goodness, too. Been lots of fun over 25 years. Restored in 2k. Now ready for a 2nd restoration.
Old 06-03-2020, 07:09 PM   #9
white855T
The bolt wearing down is a given. I have used the homemade press at least 6 times and my bolt is good(I've forgotten about greasing it a few times and it still worked, well for pressing bushing in).
Old 06-03-2020, 07:11 PM   #10
nel621
I have the OE and a DIY tool. The grade 8 bolt on both are the weak link.
Old 06-03-2020, 08:01 PM   #11
culberro
culberro's Avatar
Did you grease the threads up on the bolt and nut before you started?
I'm on 3(?) sets of TABs with the DIY tool that's being sold here. I just use moly grease on the threads, and I even use it with my big air impact for instant gratification and fear.
Old 06-03-2020, 08:25 PM   #12
Keep it greasy so it goes down easy.
Frank Zappa.
Old 06-03-2020, 08:58 PM   #13
F*ck 12
Frank Zappa.
You' made my day, thank you
"i will destroy all of you!"
-Sheldon Plankton
Booty Scooty
https://youtu.be/i4oAOZ8nbq4
Old 06-03-2020, 10:13 PM   #14
apachechef
Burnt Sierra Madre
I have a vague remembrence of a rec to use anti-sieze, not grease. something something about the pressures involved, vs friction?
Old 06-03-2020, 11:13 PM   #15
Khrrck
Professional Amateur
Depends on the kind of grease. Some are rated for high pressures and should not squeeze out, others are not. Detailed specs should be available online. I think most of the "extreme pressure" greases have moly(bdenum disulfide) in em.
'87 240 budget wagon.
Old 06-03-2020, 11:20 PM   #16
You have it. Noted.
Old 06-04-2020, 12:36 AM   #17
carver
Redblock for life.
carver's Avatar
Here's the bolt from McMaster... Love that place
And the nut...
My OEM tool died on the first try fully lubbed and with bushing shells soaked overnight. Goes to show you never know...
carver is offline   Reply With Quote
Old 06-04-2020, 12:54 AM   #18
apachechef
Burnt Sierra Madre
And the nut...
I have 49 of those nuts in a dusty box.
Old 06-04-2020, 01:50 AM   #19
Otto Mattik
Otto Mattik's Avatar
It appears you have a lot of nuts.
Old 06-04-2020, 05:49 AM   #20
cleanflametrap
cleanflametrap's Avatar
I found uses for about half of them over the years. Here's where at least six of them went.
For OP, +1 on grease, and I think maybe forgo the impact tool on this.
-Art
Old 06-04-2020, 02:53 PM   #21
carver
Redblock for life.
carver's Avatar
Yeah, just checked... same here.
Old 06-04-2020, 06:30 PM   #22
I also add in that the grease I use is the extreme pressure moly stuff. It's the stuff used for CV joints.
Old 06-04-2020, 10:03 PM   #23
doucheNozzle
doucheNozzle's Avatar
Where did you buy it from? A specific member?
'93 944 T - #TrophyVo
'00 XC70 SE - Slow
'04 V70 T5A - Feels Fast
Old 06-05-2020, 08:00 AM   #24
xDread92x
xDread92x's Avatar
Yea dont remember the name. The bottom line is if you’re going to buy this tool you’re going to need the extra hardware. Really after the cost of the tool with shipping plus the extra hardware (which is hard to get bc most places that sell these grade bolts don't sell to individuals, only businesses) you’re better off buying the volvo tool for $90 on fcpeuro
Old 06-05-2020, 02:16 PM   #25
If the volvo tool is $90 that is almost half the price it use to be. When I bought mine I paid about $175 for it. Do a couple of TAB jobs for some other folks and that will pay for the tool.
