Old 03-28-2018, 07:27 PM   #26
Bobbyz
Originally Posted by oifish View Post
That tool worked great, popped the solenoid out without issue. I found this guide for disassembling the OD unit which has been super helpful: http://www.buckeyetriumphs.org/techn.../JOD1/JOD1.htm
That's the site I used during the rebuild of my J type, had a couple of manuals too but the site gives real tips.
Used another site for the M41 but it's a relatively straight forward transmission rebuild.
A wooden dowel sanded down and cut to length is handy for holding the lay shaft bearings in place during reassembly.
Remember that lay shaft, shaft is bigger on one end. I forget which now but it has to go in and out the right way! A bigger hammer is not your friend here.
Bobbyz is offline   Reply With Quote
Old 03-28-2018, 07:28 PM   #27
oifish
I'm feeling extra zazzzy
oifish's Avatar
hiper, what tool do you use to remove the plugs to access the valves? I have a crappy adjustable spanner wrench, but I can't get enough torque to turn it.
oh and the solenoid rattles when I shake it fyi
1990 Volvo 744T M46 - Daily Driver - ( ͡° ͜ʖ ͡°)
1996 Chevy C1500
__________________________________________
Buy/Sell Feedback
oifish is offline   Reply With Quote
Old 03-28-2018, 08:03 PM   #28
I have one of the tools IPD used to sell. It's a short piece of 1" hex steel with 2 pins on one end.
I also just got one of the OE Volvo tools last week. I haven't even had a chance to use it yet.
As for the lay shaft, the thicker end goes in the rear of the trans, so always tap the shaft out from the front.
Old 03-29-2018, 11:59 AM   #29
oifish
oifish's Avatar
One of the guys on my lemons team has a couple different types of pin spanner wrenches. If none of them work, I'll try my hand at fabing something up
Old 03-29-2018, 12:07 PM   #30
Old 04-05-2018, 11:58 AM   #31
oifish
oifish's Avatar
My homemade tool (3 foot length of 1" square tube steel with 2 bolts about 15mm apart at the end) worked great for the 2 larger plugs, but the chincy bolts started to yield when removing the smaller center plug. A little tappa tap tap with a punch was enough to break it free.
Old 04-25-2018, 02:20 PM   #32
oifish
oifish's Avatar
I came across this fun surprise after removing the pressure plate. I guess the prior owner sheared off one of the flywheel bolts. The broken end came out easy enough though, just used a punch and hammer to back it out. The rear main seal looks ok but I'm going to go ahead and replace it anyway.
Old 04-25-2018, 05:55 PM   #33
tintintin
So the PO busted off the head of the bolt but left the rest of the bolt in there, that you were easily able to easily back out? Unbelievable! Bet they used a zip gun to run them in.
Old 04-26-2018, 08:55 AM   #34
oifish
oifish's Avatar
Yea, I was super relieved that it backed out so easily. He also stripped one of the hex screws for the pressure plate. Vice grips popped that loose.
Old 04-27-2018, 01:03 PM   #35
oifish
oifish's Avatar
The kit doesn't come with the piston seals for P type OD's, so you'll need to buy them separately.
https://www.ipdusa.com/products/7349...ve-piston-seal
I discovered the kit also doesn't include the gasket for the high pressure filter (#6814456) which got ripped up trying to remove it. Tasca has them for cheap so I added one to the order of new pressure plate and flywheel bolts. Solenoid o-rings were not included either, so I'm the owner of 100 -007, -010, and-014 Buna-N o-rings. If any else needs a couple to refresh their OD solenoid let me know.
Old 05-05-2018, 10:33 PM   #36
oifish
oifish's Avatar
Is there any particular alignment of the holes for the dashpot sleeve and reduction valve during re-assembly? Part #23 and #18. There are holes in each and a hole in the cylinder wall. I didn't see any mention in the ipd guide or the buckeyetriumph OD site.
Old 05-07-2018, 09:43 PM   #37
Simi
Upsetti Spaghetti
Simi's Avatar
I don't remember having to align them upon assembly.
I rebuilt my m46 OD once, turns out the pressure spring broke in half, causing it not to build pressure after it warmed up. Replaced the spring and it was good to go.
I did pull off the OD while leaving the trans in the car. Was able to flush the whole thing out and inspect it all. For anyone who needs to take the 3 plugs out of the bottom, i used an adjustable wrench and two drill bits. It worked perfectly.
It may seem intimidating at first but all the serviceable components are relatively easy to get to, it just sucks trying to find replacement parts.
1989 240 Turbo
1988 745 Turbo - SOLD
1991 940SE - SOLD
1995 850 T5-R
1991 740 Turbo
1987 240
Leave Me Feedback
Simi is offline   Reply With Quote
Old 05-08-2018, 01:56 AM   #38
tintintin
Same thing happened to mine (broke PRV spring). Where did you find a replacement spring?
Old 05-16-2018, 06:01 PM   #39
oifish
oifish's Avatar
Wellll ****. Everything is back together. New clutch is nice.... but the gd overdrive just kicks in and out. worse than before now.... maybe the solenoid is bad? I really have no idea at this point where to look. The "5" light stays lit as the OD kicks in and out
Old 06-25-2018, 12:07 PM   #40
oifish
oifish's Avatar
I finally had the time to clean up the wiring and made sure every connection is solid and now works just fine! The OD is super smooth now. What sucks is that it still leaks. I'm going to remove the unit from the trans and put some gasket sealer on in combination with the paper gaskets.
Old 06-25-2018, 04:08 PM   #41
planetman
planetman's Avatar
Before you remove the O/D, see if you can determine where the oil is coming from.
Maybe it's a seal that is accessible without removing the O/D.
Eric
Torrance, CA 90502
Old 06-25-2018, 05:19 PM   #42
oifish
oifish's Avatar
I'll try... ATF is dripping from a number of places.
Old 08-02-2018, 10:50 AM   #43
oifish
oifish's Avatar
Baaaaaaaaammmmmm this fixed the drip: http://forums.turbobricks.com/showthread.php?t=343551
I didn't realize the studs were exposed to the guts of the OD. Thread sealant fixed it.
Now to work on these never ending oil drips....
Old 08-02-2018, 05:21 PM   #44
283SD
Did you do a pressure test when in O/D. there is a port to check this. you will need a 1000 lb gauge, it should put out 450 lbs aprox when in O/D, and the proper fittings, I had an 8' hose made up so that you can drive the car and test it.
Old 08-02-2018, 06:05 PM   #45
alschnertz
Enough already!
alschnertz's Avatar
Here's another resource for overdrive parts, repair and advice.
http://www.quantumechanics.com/
It's been a long time (10+ years) since I last used Quantum Mechanics, but at the time, John was very helpful.
Old 08-02-2018, 07:56 PM   #46
oifish
oifish's Avatar
nah didn't mess with it. probably would have been a good idea before taking it apart, but it's super smooth and engages perfectly now/
