Old 03-24-2018, 12:06 AM   #76
PromiseRing
We don't even like Volvos
PromiseRing's Avatar
That's not how Volvogeorge Swift taught me to do it, but carry on since you know it all...
Oh and he is a mechanic, in fact he's an engine builder for Jay Leno now just FYI.
Is that not what you told me
And again, irrelevant post. What darkness said was stupid. It’s not a mechanic who assembled these cars from the factory.
Feedback Thread
Current:
93' 244 m47
93' 245 m47
90' 744 AW70
94' M-Edition Miata, 93k
95' Camry auto, 246k
94' 945T AW71(L?)
93' Camry auto, 278k
Past:
80' 242gt m46
88' 245 m47
92' 940 turbo AW71
Bready is a joke of a mod
Old 03-24-2018, 12:07 AM   #77
PromiseRing
Did you knock the cups back against the circlips?
This
Yes, I did.
Old 03-24-2018, 12:36 AM   #78
Originally Posted by PromiseRing View Post
This
Yes, I did.
Damn kid you're so stubborn you're almost stupid.
You stated you tapped them in until they CLEARANCED and the circlips popped in.
Clearance is a space however small...
Not knocked back tight against the clips to allow for proper articulation like I've been TRYING TO TELL YOU.
Old 03-24-2018, 12:53 AM   #79
PromiseRing
Why didn’t you say that 77 posts ago Ken? And I’m not stubborn.
Old 03-24-2018, 01:35 AM   #80
Darkness
By the way neither of your posts make any sense and are irrelevant lol. People who work on an assembly line aren’t mechanics, for the record.
So, your Volvo is special huh?
Never had driveline work in 25 yrs?
Yeah right.
So, I guess your 5.8 posts per day versus my 3 posts per year makes you an expert eh?
Darkness is offline   Reply With Quote
Old 03-24-2018, 01:37 AM   #81
Darkness
Why didnít you say that 77 posts ago Ken? And Iím not stubborn.
Yeah, not stubborn. It is most definitely something less noble than that.
Old 03-24-2018, 09:43 AM   #82
I kinda did, but didn't think I'd have to gold plate it to get you to understand the logic in it.
Oh BTW & just FYI a factory worker is actually a factory trained technician not some self taught billyjoebob 'mechanic' down at the corner gas station.
Old 03-24-2018, 11:04 AM   #83
PromiseRing
Yeah right.
I have every maintenance record since 1993 as far as I know. Iím more than willing to bet itís original u joints, carrier bearing etc.
You should know by now if it isnít written in crayon on a paper plate Iím not gonna understand it.
And yes, thatís what I said.
Old 03-24-2018, 02:00 PM   #84
tintintin
So are the buckets supposed to outwards towards the c clips? Because all 4 caps are touching the c clips.
I did try to explain it as best I could. Sorry for my lack of english writing and descriptive skills. Yes, whatever you say, yes, you are correct, yes. Whatever.
Trying one last time. The cups may be touching the circlips but may still be a bit tight to the crosspiece, causing binding at some point(s). Driving them back outwardly against the circlips moves them ever so slightly away from the crosspiece, hopefully opening enough clearance to eliminate any chance of binding. Keywords: moves them ever so slightly. Even though they may be touching the circlips they are still able to move outward a bit. What is the word, elasticity maybe? Clearancing? Not sure. Somebody help me.
Of course, you gonna say "there's no binding," so you have established that without a doubt so you can forget about all this.
Just thought it was important you understood the concept instead of immediately condemning it. Of course these are tricks the pros use, not necessarily for TB mechanics to use on their old cars.
Well I had one more idea for you before I get off this thread permanently. Another TBer had a recent driveshaft thread where he found the problem was a lateral displacement of (I think it was) the center bearing. He slotted the holes to remount it lined up straight and that fixed it. You may want to check for something like that.
Old 03-24-2018, 02:05 PM   #85
bobxyz
bobxyz's Avatar
If you have the Bentley Manual, there's a great picture of indirectly tapping out the bearing cups (or seating them) in the Driveshaft chapter (pg 450-2 Fig. 3).
Old 03-24-2018, 02:16 PM   #86
Do you have problems with your textbooks in school?
Asking for a friend...
Old 03-24-2018, 03:17 PM   #87
PromiseRing
Alright everybody sorry for being a stubborn prick, I was just flustered to say the least. If it ever stops raining I will follow yours and Kens instructions and better inspect. To me it seemed like there was no binding since I was able to move the ujoint in all directions without resistance.
Old 03-24-2018, 08:04 PM   #88
TestPoint
TestPoint's Avatar
Post #13
Originally Posted by TestPoint View Post
In a six month effort to completely eliminate shaft vibration my shaft balance guy coughed up the fact that there are three standard snap ring thicknesses.
The new U-joints and included snap rings I was working with bound the bearings far too tightly creating vibrations.
Setting the caps back against the proper thickness snap rings is obviously a critical criteria that I had no knowledge of at the time. I had set the joints back against the rings but that wasn't enough. My balance guy replaced the included rings with thinner ones and sent me happily on my way.
Ford V8 Conversion Manual -
TestPoint is online now   Reply With Quote
Old 03-24-2018, 08:54 PM   #89
PromiseRing
Post #13
So rings may be too thick. Is there anyway of knowing mine are too thick?
Old 03-24-2018, 09:06 PM   #90
TestPoint
TestPoint's Avatar
Vibration . . . or something else.
I had paid the shaft guy about $100 to shorten and balance a one tube custom shaft for my 302 conversion with new U-joints that I had installed. When I couldn't get the vibration out I took it back and he explained about the three thicknesses of snap rings. I do not know if that is because of rust in the ring cut or because of tolerances of the yokes.
The bottom line is that an U-joint cannot be bound tightly in the yoke without causing problems.
Old 03-24-2018, 09:44 PM   #91
JohnLane
OP U-Joints in the late cars last much longer then we saw in early cars with the 'Two smalls and a medium' driveshafts.
I have installed $10.00 U-Joints only to solve the new vibration with Volvo U-Joints.
I've also got to have the driveshaft guy balance a shaft after doing U-Joints.
If you dented a tube as part of your process it will shake.
But you know this. Ahhhhh snowflakes!
Old 03-24-2018, 10:39 PM   #92
PromiseRing
Nooo apparently I donít know anything about this ujoint stuff or I wouldnít have messed it up
So I can
-Change to Volvo OE u joint
-Check snap ring thickness
-Make sure u joint isnít pushed too far in
-Find someone to balance the shaft(s)
I donít think I dented it but I guess Iím not 100% positive. All the u joints went in and out easily except the first one I pressed in. I I think most of the force was exerted on the joint and not the ears.
Old 03-24-2018, 11:12 PM   #93
JohnLane
We've all had a U-Joint needle fall over and got to throw one away for it.
Plenty of suggestions in this thread which if followed will help you to solve the issue.
Best of luck.
Old 04-10-2018, 02:24 PM   #94
PromiseRing
Has anyone noticed a plastic type of coating in or on the splines of the rear shaft? I seem to remember having to peel off quite a bit of plastic coating in order to fit the rear shaft splines into the front shaft. Perhaps that plastic was supposed to be there? It was damaged and that’s why it would not allow for reinstallation without removal.
Old 05-15-2018, 01:35 PM   #95
PromiseRing
SOLVED: installed an m47 driveshaft from the junkyard for $27. It was from a 1992 car and had the arrows on each shaft unlike my 1993 cars. In fact, the arrows looked to be off a couple splines, and the center support bearing made noise when I spun it by hand, but i left it as is and all vibrations are completely gone from 0-90mph haven’t had it past that but that’s good enough for me. I will most likely have to replace the center bearing at some point but for now we will consider this solved. Thanks for all the advice, hopefully you guys have better luck than me
