Old 05-07-2018, 05:37 PM   #26
Can play the blues
The 85 trigger wire on each relay is connected to an existing headlight wire. One for low beam and one for high beam. The ground wire for the same headlight connector is used for the ground 86 on each relay.
In the aftermarket harness this is where they use the male headlight connector to plug into an existing headlight connector to trigger the relays.
Old 05-07-2018, 05:48 PM   #27
XxJenoxX
Skin Suit
XxJenoxX's Avatar
OHHHH right, I forgot all about that male connector thing. Ok, so I probably just have to add a length of wire from the existing wire on the far side, and use the existing ones without lengthening on the driver's side.
AND THEN THERE WERE TWO (and a half)
2008 XC70 3.2: Stubborn sensor on wheels
1992 M47 240 Wagon: Why did anyone let me have anything this nice?
1990 240 DL: Parts car
1983 242 TIC +M46: Ticket to the 242 Crush Club
I have no idea what's going on, but I think I can fit more 8====D in my mouth than 240240
Originally Posted by Wilford Brimley View Post
Mmmmmm curvy girls and cock excess
XxJenoxX is offline   Reply With Quote
Old 05-07-2018, 08:27 PM   #28
Can play the blues
Unless you totally want to balance out the bulb out circuit No need to run wires from the old ones on the passenger side. You only need to trigger the relay from the left side for both headlights on your new harness. I only connected the harness to the one side and it doesn't have a bulb out light on. Probably not enough current in that part of the circuit for it to function anymore.
Old 05-10-2018, 09:15 AM   #29
XxJenoxX
Skin Suit
XxJenoxX's Avatar
After an insane amount of thrashing with the old headlights, they're installed. Harness is hooked up.
Doesn't fkin work.
I didn't have much time to troubleshoot since I was long past out of daylight, but I have power through the fuse box but not at the H4 connectors. So My guess is the relays aren't doing the clicky clicky, or they aren't getting the trigger signal. I didn't have time to double-check my wiring, so hopefully the rain will hold off and I'll have time today. I also admittedly am using the bulbs that came with them, and I have no clue what kind of condition they're in. Just trying to get them running at this point.
But also, one of my corner lights/turns doesn't work. I have yet to change the bulbs (visual check was ok, but that's unreliable) but here's the thing...The passenger side corner light has 3 wires in the 3-wire connector, and the driver's side has 2 wires in the 3 wire connector. Receiving end has 2 wires each. Both have an additional ground.
The side with 2 wires does not work. No marker lamp, no turn signal. Anyone have any idea on the different wiring? The boot covers were different, too. One genuine and one aftermarket, perhaps? They look so similar in quality that I hadn't really considered that they might be different until I was installing them and noticed the wiring.
Old 05-10-2018, 12:15 PM   #30
Can play the blues
The side lights can have the extra wire for a daytime running light. Not always but it can be there. So maybe you have one with a drl and other doesn't.
If you have no power on the lights. I agree start with the trigger signal pin 85 on the relays. If that is working then you want to make sure the ground on pin 86 is working otherwise the relay won't turn on at all. For ground checking with a test light connect the clip to power and check that pin 86 turns on the test light.
Old 05-10-2018, 05:49 PM   #31
XxJenoxX
Skin Suit
XxJenoxX's Avatar
Ok, so here's what I've got so far...
Power at the fuse junction, both iin and out is good.
Power measured at the trigger junction amd relay ground is good.
Power at the H4 connector is .5 V
Relay no go clicky, I think. But why? I've swapped out for ice cube relays and had the same exact result. Swapped out the fuse panel for a fusible link. Nada. Bupkiss. Checked thr ground, got nothing.
Old 05-10-2018, 05:50 PM   #32
XxJenoxX
Skin Suit
XxJenoxX's Avatar
Also powered the 87a to make sure something isn't backwards. Nada to the H4.
Old 05-10-2018, 06:14 PM   #33
XxJenoxX
Skin Suit
XxJenoxX's Avatar
NEVERMIND, I DUMB. Wow.
Old 05-10-2018, 06:18 PM   #34
Can play the blues
Use a test light to make sure the connections conduct. I just had a bad ground on my brothers 91 BMW install with this same stuff. It was the ground for the headlights themselves on the right side in his case.
So you are providing power on 86 and it is grounded on 85 then the relay should be on. You should measure constant hot power on 30. 87 should be on only when you apply power to 86. If that is working move to checking the continuity to the headlight connector if you aren't lighting the test light on the headlight connector.
Old 05-10-2018, 10:00 PM   #35
XxJenoxX
Skin Suit
XxJenoxX's Avatar
I missed a ground.
But now I have a different problem. Low and high beams are all good.
But NO turn signals. Standard fast-flash from the dash, nothing up front. No corner lights, either. And the left tail light is now out, as though the fuse for the turn signals and left tail is blown. But I tried spinning the fuse, tried changing it, not blown, but not working. Something on that circuit isn't right.
I ran out of daylight AGAIN, so I think I'm gonna go to work late rather than drive 60 miles like an as$hole with no turn signals. Maybe I missed another ground in the dark. I did have to take it all apart to finish the final routing and looming.
Old 05-11-2018, 01:01 AM   #36
Can play the blues
When I installed the DJ ecodes they had wires wrong on the park/turn signal connectors. I had to switch things around. Good find on the ground. Looking at it with a new day will help you figure it out.
Old 05-11-2018, 05:34 PM   #37
XxJenoxX
Skin Suit
XxJenoxX's Avatar
ALLLLLRIGHT.
So after a combination of things being broken, backwards, and just WRONG on my behalf...
Turn signals work. Headlights work.
But only passenger side parking light works.
No hazards (maybe been like this forever, I'm not sure at all.)
Driver's side tail light is still out. No dice on bulb change. 0V getting to it.
What could I have bumped in the process that would have kicked my tail light power? Fuse is still good, too.
Old 05-11-2018, 06:37 PM   #38
Can play the blues
Check the bulb out relay for a no pass through problem. The tailight circuits pass through the relay. You should see 12v in and 12v out from the relay.
Double check fuses. Because if they are the pot metal they will look good and be open. For the no parking light it could be the same thing with the bulb out relay if there is 0v at the socket. Should see 12v in and 12v out of that circuit on the relay as well.
Old 05-11-2018, 10:04 PM   #39
XxJenoxX
Skin Suit
XxJenoxX's Avatar
Well allllrighty.
I had a bunch of red herrings with the fuses. Despite the fact that I recently removed, cleaned, adjusted, greased, and replaced every single damn fuse and position, a bunch of them wanted to be spun.
So now all the lights work! Success!
However, I need to get these bad boys not pointed at the sky. Any memory on whether the upper or lower adjusts vertical position? And what happens if I'm turning it and nothing happens?
Old 05-12-2018, 04:49 PM   #40
Can play the blues
Those damn fuses! At least those are easy to deal with. Did you get the lights to adjust?
Old 05-12-2018, 07:50 PM   #41
XxJenoxX
Skin Suit
XxJenoxX's Avatar
For real, I JUST did everything I could to make them as reliable as possible, and they're still an issue. Converting to blades next.
I do actually have a mock-up idea for a way to directly replace them with blades on the existing panel, but no clue how to actually make it...
I didn't. But I spent the day painting trim and fixing my rear wiper.
Old 05-13-2018, 02:02 PM   #42
Can play the blues
A good cleaning on the contacts. Retension slightly if needed and use the brass and copper fuses and it'll be much less of an issue.
