Old 05-09-2018, 12:25 PM   #1
jvluntzel
Default Air vents not blowing when accelerating
Hi All!
trying to figure this one out. When I accelerate or hold throttle going up a hill, my air vents inside stop blowing air. I am assuming this has something to due to the fact that the engine is in a 0 vacuum state and some actuator is moving when it shouldnt or vice versa.
Any direction on this is greatly appreciated!
jvluntzel is offline   Reply With Quote
Old 05-09-2018, 12:30 PM   #2
EivlEvo
iirc there is a one way check valve (black and white) on that hose from the IM that prevents such a thing.
However, you didn't list which vehicle this is and I believe your assessment may be inaccurate or mis-stated but to be clear... your vents are closing off via vac yes? Your blower motor doesn't actually stop running correct? If so, then check that valve.
Old 05-09-2018, 12:31 PM   #3
Ursan
الله الفول السوداني شطائر
Ursan's Avatar
Don't forget to mention, (as always) year make and model.
how psi a stock can support?
I think this might be my chariot if I can jew the price down.
Old 05-09-2018, 12:40 PM   #4
Drive backwards.
Old 05-09-2018, 12:43 PM   #5
white855T
Vacuum actuator for vent has a torn diaphragm. Common problem. Only source is the junkyard. Sometimes new/nos one pop up on ebay.
Buyer/Seller Feedback
Old 05-09-2018, 01:07 PM   #6
Khrrck
Professional Amateur
Easy way is to unplug it (optionally, attach a bit of clean hose) and blow air in each end. If air passes in both directions it's fukt.
If ithe check valve is working, then you have a leak somewhere else in your under-dash vacuum system. Good luck!
'87 240 budget wagon.
Old 05-09-2018, 02:11 PM   #7
XxJenoxX
Skin Suit
XxJenoxX's Avatar
I've got a spare or two, if that's your problem.
AND THEN THERE WERE TWO (and a half)
2008 XC70 3.2: Stubborn sensor on wheels
1992 M47 240 Wagon: Why did anyone let me have anything this nice?
1990 240 DL: Parts car
1983 242 TIC +M46: Ticket to the 242 Crush Club
I have no idea what's going on, but I think I can fit more 8====D in my mouth than 240240
Originally Posted by Wilford Brimley View Post
Mmmmmm curvy girls and cock excess
XxJenoxX is offline   Reply With Quote
Old 05-09-2018, 05:35 PM   #8
jvluntzel
Drive backwards.
this is genius. I love it
91 volvo 740 wagon non turbo REX
Pics of valve if you have any
pics of diaphragm?
hell yea bro. pm me
Old 05-09-2018, 05:44 PM   #9
Old 05-09-2018, 07:36 PM   #10
centason
Knipex=welfare queen
centason's Avatar
Make sure said valve above isn't backwards.
Member: TBCCS
"The kind of man who wants the government to adopt and enforce his ideas is always the kind of man whose ideas are idiotic." -H. L. Mencken
Old 05-09-2018, 09:13 PM   #11
2 old for this
Or you have a busted actuator. Break out your hand held vacuum pump and test the circuits.
Old 05-09-2018, 11:08 PM   #12
Kjets On a Plane
Devoid of Luxury
Kjets On a Plane's Avatar
How PSI a stock can support?
Old 05-10-2018, 07:01 AM   #13
jvluntzel
Not uncommon for all the air to be on the floor on a 7/9 climbing a hill with a torn vac servo I’d the check valve and all else works.
In that case,
Add a vacuum pump or crush the car, it’s not worth fixing
Now now then...that's not the TB mentality! There's gotta be a ghetto hack workaround
Old 05-10-2018, 11:04 AM   #14
Ursan
Ursan's Avatar
I had this same issue. I installed a vacuum pump with a vacuum switch. No cutting, no cursing. Works well.
Once vac is 2<. it turns on, Once <4 it turns off. It's connected only to the vac source for the HVAC controls.
Old 05-10-2018, 12:54 PM   #15
jvluntzel
Could you post more pictures and information?
Old 05-10-2018, 01:16 PM   #16
Ursan
Ursan's Avatar
https://forums.tbforums.com/showthre...19#post5412619
Old 05-10-2018, 01:21 PM   #17
white855T
Here are pictures of a vacuum actuator that is torn and one that is good.
Its easier to just replace part in my opinion.
Old 05-10-2018, 02:40 PM   #18
Kjets On a Plane
Devoid of Luxury
Ursan and I posted the work-around/hack.
Though a world where all 7/9 owners/losers would hurry up and crush those things drove kias/corollas with 100k waranties and wasted the dealer’s time would be wonderful...
Replaced them the “right” way with another near new pnw weather actuator that will just split and go bad in a few short years. Time consuming, more bother than those worthless cars are worth.
Hack in a vac pump and switch! 760s with the early auto climate control came with an aux vac can and loud vac pump anyway
Old 05-11-2018, 09:42 AM   #19
jvluntzel
You have a link to your thread?
Thanks! I am so glad to hear about this workaround :D
Old 05-15-2018, 02:51 PM   #20
Ursan
Ursan's Avatar
I posted a link to the instructions already.
