Old 05-12-2018, 06:06 AM   #1
David945FT
Default B234F to B230FT
Im taking out my b234f and putting in a b230ft in my 740 glt. Can I use the stock b234f wiring harness or do I need to take the harness from the 940 where the b230ft comes from. As I can see, the only difference should be that there are no resistors for the injectors.
Any help will be appreciated.
David945FT is offline   Reply With Quote
Old 05-12-2018, 10:40 AM   #2
Lando
Arthur Digby Sellers
Lando's Avatar
Put the turbo on the the 16valve!
Originally Posted by amerbritcan View Post
Lando you have an enticing midriff.
get on my lawn
Lando is online now   Reply With Quote
Old 05-12-2018, 02:57 PM   #3
Cross member is different.
Downpipe may be an issue.
Wiring would just need MAF pigtail run over there or restrung. And ballast pack put in for greentop injectors.
Old 05-12-2018, 04:00 PM   #4
