Old 05-13-2018, 09:44 AM   #1
apollo's 940
Default need 240 wiring diagram for idle control valve
green 1992 245 b230f --- stock
idle is very bad, shaking side to side
brand new genuine volvo motor mounts
stock m47 volvo tranny mount --- good condition
using electronic vacuum leak test --- passed. perfect. zero leaks
using vape smoke test into intake side --- passed. zero smoke leaks
disconnected the idle control valve --- nothing happens. zero effect. bad idle continues
swapped ICV with my other stock white 240 b230f
1. icv from the green 245 works perfectly on the white 240
2. the working icv from the white 240 into the green 245 --- results to bad idle on the green 245
in short: both ic valves work perfectly on the white 240 , but both do not work at all on the green 245
both engines are stock b230f
therefore --- must be a wiring issue on the green 245
my mechanic friend can trouble shoot the green 245 but says he needs the wiring diagram for the icv
a. where can I obtain this wiring diagram for a stock b230f 240/245
b. any other ideas of the source of this bad idle before we go on a ghost hunt via the wiring diagram?
thanks in advance
andrew
apollo's 940 is offline   Reply With Quote
Old 05-13-2018, 12:26 PM   #2
EivlEvo
This assessment is a questionable cause logical fallacy.
You have bad idle and therefore assume that your IACV has a wiring issue but have you confirmed a number of other issues that would cause idle problems?
Are you implying that your idle is low? Does your AC function? Is your TPS adjusted properly and functioning? Is your throttle body and plate cleaned? Are any codes being stored? Have you reset the LH ECU at any point? Have you run the IACV diagnostic testing in the LH OBD system? Don't just start hacking a wiring harness because you assume your IACV isn't getting proper power... lets find out WHY it isn't. It may well be the wiring, but there are plenty of stops along the way worth checking.
I'd start with cleaning your TB and plate, checking your TPS for proper adjustment, tell us what your idle really is (though you might not have the tach now that I think of it) are you auto or manual, AC or not, and of course... run the LH OBD test to SEE/HEAR if your IACV can in fact be controlled by the ECU.
Old 05-13-2018, 01:23 PM   #3
TWD
TWD's Avatar
After you do the above, check for vacuum leaks. Don't forget the intake manifold gasket.
TWD is offline   Reply With Quote
Old 05-14-2018, 06:43 AM   #4
apollo's 940
ok lets go through that list slowly:
Are you implying that your idle is low? --- nope, not implying. after I unplugged the iacv nothing happens. so that is a strong sign that I should pursue that furthr , hence my posting
Does your AC function? --- entire AC system deleted. all parts removed, very cleanly done. could this have something to do with this bad idle? I might have missed something
Is your TPS adjusted properly and functioning? --- I HAVE NO IDEA
Is your throttle body and plate cleaned? ---- very clean. engine was out of the car and disassembled except for the head. everything is brand new
Are any codes being stored? --- car has no black box tester for codes
Have you reset the LH ECU at any point? --- I HAVE NO IDEA WHAT THAT IS
Have you run the IACV diagnostic testing in the LH OBD system? --- NOPE, BECAUSE I DO NOT KNOW HOW TO
Don't just start hacking a wiring harness because you assume your IACV isn't getting proper power... lets find out WHY it isn't. It may well be the wiring, but there are plenty of stops along the way worth checking. --- fully agree with you
I'd start with cleaning your TB and plate, --- done
checking your TPS for proper adjustment, --- HOW DOES ONE ADJUST THE TPS?
tell us what your idle really is (though you might not have the tach now that I think of it) --- idle is sawing the engine left to right by more than one inch, but when I rev it smoothens out
are you auto or manual, --- m47, new oil, very good condition mount
AC or not, --- AC deleted
and of course... run the LH OBD test to SEE/HEAR if your IACV can in fact be controlled by the ECU. --- please tell me how to do that. please please please
plug wires --- checked. all sending spark
thanks in advance
andrew
Old 05-14-2018, 07:21 AM   #5
Lando
Arthur Digby Sellers
Lando's Avatar
Go to volvowiringdiagrams.com and down load the green book for LH2.4. It tells you how to do everything you are asking about. It has easy to read troubleshooting flow diagrams for every possible failure in the fuel system.
Originally Posted by amerbritcan View Post
Lando you have an enticing midriff.
get on my lawn
Lando is online now   Reply With Quote
Old 05-14-2018, 07:27 AM   #6
apollo's 940
thank you lando
andrew
Old 05-14-2018, 09:13 AM   #7
XxJenoxX
Skin Suit
XxJenoxX's Avatar
If it's a '92, it's got either 2.4 or 3.1 and it absolutely has a black box tester unless someone removed it. Inside the driver's side fender, up on the back side of the strut tower. It's pretty small, maybe 2"x3".
AND THEN THERE WERE TWO (and a half)
2008 XC70 3.2: Stubborn sensor on wheels
1992 M47 240 Wagon: Why did anyone let me have anything this nice?
1990 240 DL: Parts car
1983 242 TIC +M46: Ticket to the 242 Crush Club
I have no idea what's going on, but I think I can fit more 8====D in my mouth than 240240
Originally Posted by Wilford Brimley View Post
Mmmmmm curvy girls and cock excess
XxJenoxX is offline   Reply With Quote
Old 05-14-2018, 12:45 PM   #8
EivlEvo
Are you implying that your idle is low? --- nope, not implying. after I unplugged the iacv nothing happens. so that is a strong sign that I should pursue that furthr , hence my posting I'm trying to figure out which problem you've got and are trying to solve. Just because your idle doesn't change when you unplug your IACV doesn't mean that it's bad... there are some other variables at work here.
Does your AC function? --- entire AC system deleted. all parts removed, very cleanly done. could this have something to do with this bad idle? I might have missed something The reason I asked about this is because if you have LH2.4 (I don't know about 3.1) the AC switch/relay sends a signal to the ECU to increase the idle speed during compressor operation.
Is your TPS adjusted properly and functioning? --- I HAVE NO IDEA lol well dude, you've got to check! The throttle position switch is on the firewall side of the throttle body (it's a black bosch thing usually) with the engine off, if you manually open the throttle plate, you should hear/feel it clicking. That might lead you to it. Also... the wires for it come out of the same harness for the IACV. iirc it's IACV, starter and the TPS.
Is your throttle body and plate cleaned? ---- very clean. engine was out of the car and disassembled except for the head. everything is brand new Good, but just consider that new doesn't always mean working or adjusted. Let's sideline this for now though.
Are any codes being stored? --- car has no black box tester for codes As was mentioned, if you have a stock ECU on this car it's either 2.4 or 3.1. Both of these are OBD1 and have a black box for diagnostics under the hood on the intake side strut tower. It has it's own connectors
Have you reset the LH ECU at any point? --- I HAVE NO IDEA WHAT THAT IS The engine control unit (ECU) is your fuel computer. You need to check codes that might be stored in that aforementioned black box. Have you gotten any check engine lights? You can also "reset" this all by disconnecting the battery for a few minutes BUT we should maybe diagnose before we just do the battery.
Have you run the IACV diagnostic testing in the LH OBD system? --- NOPE, BECAUSE I DO NOT KNOW HOW TO First. It might be worth while to go into your passenger (right side) footwell in the car and remove the kickplate that's just ahead of the door. You'll find your fuel ECU there and under the knee bolster cover thingy in the same spot you'll find your EZK (ignition computer). Grab the numbers off of these and you'll then be able to find out which LH system you've got... might help with all this diagnosis.
tell us what your idle really is (though you might not have the tach now that I think of it) --- idle is sawing the engine left to right by more than one inch, but when I rev it smoothens out Do you have a tachometer though? A redblock vibrating side to side isn't good, but that might not be an idle issue... it could be a balance issue as well
thanks in advance
andrew
Old 05-14-2018, 03:53 PM   #9
Pull the intake hose and check for leaks.
I use a smoke machine.
Old 05-16-2018, 09:21 AM   #10
KeizerBrickGuy
Sh*t pot stirrer
KeizerBrickGuy's Avatar
Double check for vacuum leaks(manifolds, hoses/lines), clean grounds, conduct a wiggle test on your IACV and TPS as well as your knock sensor under your intake manifold. A poor connection could cause this and with a vacuum leak can cause a rough idle. Green Books are your friend, to double tap with Lando, Green Books galore
-Stephen
#mclovethesenuts
