Old 05-13-2018, 09:02 PM   #1
Patestrickland
Patestrickland's Avatar
Question Anyone Have 240 Guage Cluser Wiring Diagram?
Hello everyone, my gauge cluster recently stoped working and I want to see if it’s a wiring problem and see if I find any broken wires as opposed to going and buying a cluster and that not be the issue. Does anyone have the wiring diagram for a 1993 240 gauge cluster (like from the green books)? Thanks.
Patestrickland is offline   Reply With Quote
Old 05-13-2018, 09:08 PM   #2
http://www.volvowiringdiagrams.com/v...20Diagrams.pdf
Old 05-14-2018, 12:49 PM   #3
EivlEvo
Hiper... you happen to know any good/best practices for testing gauge clusters and/or why one would go completely dead?
Pate was over my house the other weekend to steal parts off of my parts car. He's got a project on his hands heh...
Old 05-14-2018, 01:54 PM   #4
Check the obvious stuff first. Make sure it's got good power and ground connections and that none of the terminals have spread open. If that's not it, check the PC board for any burnt tracks.
Old 05-14-2018, 02:15 PM   #5
Uncleknucklez
bruspeed
Uncleknucklez's Avatar
Check the Voltage regulator, its the 3 prong transistor thingy screwed to the metal plate on the backside of the cluster.
1980 242 Turbo
2004 V70R
Uncleknucklez is online now   Reply With Quote
Old 05-16-2018, 09:43 AM   #6
EivlEvo
Pate mentioned that this was the ground pin in the main cluster. The connector had widened itself out. He saw on another thread that someone had the same issue so he got in there and crimped it a bit tighter and boom... working cluster.
