Old 05-14-2018, 09:57 AM   #1
105Charlie
Default Temp gauge wiring to non-standard dash
Hi,
I need to wire up my 940 turbo engine temp sensor to my 343(volvo) dash. I assume I can take the wires straight from the temp sensor to the two wires on the back of the dash?
Does anyone know exactly what wires/sensor I should connect up to and how?
Thanks
105Charlie is offline   Reply With Quote
Old 05-14-2018, 06:40 PM   #2
Khrrck
Professional Amateur
We're mostly familiar with American cars here. Do you know the original engine of the 343? Even better, the part number or output range of the sensor in it?
Best case, the sensor is the same range as the 940 sensor, and you can just wire it up.
Worse case, the 940 sensor is wrong but you can screw a 343 sensor into the same hole.
Worst case, you may have to find an adapter or other improvised solution so you can attach a 343 sensor to the 940 cooling system.
'87 240 budget wagon.
Old 05-14-2018, 09:26 PM   #3
bobxyz
bobxyz's Avatar
The LH2.2 engines use a 2-pin single temp. sender for the ECU. The LH2.4 engines use a 2-pin dual temp. sender (one goes to ECU, one to EZK, ground through the block). The sender for the dashboard gauge is single pin (with ground through the block). It might be easiest to just try it and compare the dashboard gauge with an IR thermometer reading of the block/radiator/hose connections.
Old 05-17-2018, 10:50 AM   #4
105Charlie
So I've got three senders in the block under the inlet, all with two pins?
I can't see a single sender with one pin!
