Old 05-14-2018, 07:30 PM   #1
SenseiRice
Default M47 pops out of 3rd gear when decelerating
So a few weeks ago I dropped a rebuilt 93 squirter motor and an 88 m47 into my car. I put a new bellhousing gasket and rear cover gasket+seal in the m47. I also put 2 qts of wolfshead synthetic universal atf in it. I also welded an extra 1/2in or so of lenght under the shifter ball to give myself a bit of a short shifter. Been about 500-600 miles since the swap and just earlier it decided to pop out of 3rd gear while I was decelerating. I put it back in 3rd then coasted for a bit and again it popped out. Seems to be random how long it stays in 3rd gear before it pops out and it hasn't popped out of 3rd gear while accelerating, only when my foot is off the gas. The transmission had 150k miles when I got it from a friend of mine and it shifts through all the gears smoothly with no grinding. My thoughts are the fluid I used but I'm not sure. Any ideas why it doesn't stay in 3rd while decelerating, pretty annoying when I'm engine braking on hills.
Just a single man with a single overhead cam.
SenseiRice is offline   Reply With Quote
Old 05-14-2018, 08:11 PM   #2
Happy Mew Year!!!
Is the rubber boot pushing it out of gear?
Old 05-14-2018, 10:24 PM   #3
SenseiRice
I do not believe so
Old 05-14-2018, 10:59 PM   #4
Make sure you didn't extend the shifter so far that it's hitting the overdrive housing and preventing you from shifting all the way into 3rd.
Old 05-14-2018, 11:00 PM   #5
EivlEvo
Are you certain it's nothing externally like that boot and/or the sponge?
Old 05-15-2018, 07:20 AM   #6
SenseiRice
Just moved the boot up the shifter to see what would happen and hasn't popped out of third gear since.
Old 05-15-2018, 09:35 AM   #7
EivlEvo
Myth busted?
Old 05-15-2018, 12:43 PM   #8
SenseiRice
I think so, I just need to find a way to keep the shiftboot in place
Old 05-15-2018, 01:15 PM   #9
SenseiRice
Spoke too soon, it's still popping out
Old 05-15-2018, 08:42 PM   #10
Acid8000
Acid8000's Avatar
This happened to me. Turned out to be a dead tranny mount . Wasn't allowing the shifter to go fully into gear
Daily Driver: '83 242Ti w/ B21FTi and M46. IPD Sways, Bilstein HD Struts, Lowering Coils. Mistu 13c @ 10psi - Her name is Domino.
Hi my name is Jason, i'm addicted to boost
Acid8000 is offline   Reply With Quote
Old 05-16-2018, 08:42 AM   #11
240240
Is Always crushing it
240240's Avatar
Time for bronze shifter bushings and new mounts.
Ive used a dead motor mount in place of stock mount for sloppy m46. Its about 1/2" thicker than stock trans mount. Muscle it in there and your shifter will sit just a bit higher and everything is slightly tighter perfect mod for the brokeass turbobricker.
This is for a 240. If you're driving a 7/9 crush your car
Old 05-16-2018, 12:13 PM   #12
SenseiRice
I did just put a brand new mount in it, it is a duralast part though.
Old 05-16-2018, 08:10 PM   #13
Can play the blues
I would suggest a different lube in there.
Old 05-17-2018, 02:33 PM   #14
freevolvos
freevolvos's Avatar
worn shift collar and probably the 3rd speed gear engagement teeth, hub keys, maybe or even a failed pilot bearing , although that's usually affects fourth gear ,possibly the shifter as well
Old 05-18-2018, 04:18 PM   #15
SenseiRice
Is there a more definitive way to test if it's the transmission itself? It only has 150k miles on it. I'm really hoping it's not that because the old m47 my car had was total junk so I scrapped it.
Old 05-18-2018, 07:09 PM   #16
petiww
petiww's Avatar
Try a stock shifter lever in it first. Maybe its only that, who knows.
1980 Brown 244 GL
petiww is online now   Reply With Quote
Old 05-20-2018, 09:50 AM   #17
SenseiRice
I already donated the old transmission (with shifter) to my highschool because the auto program wanted a manual transmission to cut apart and use as a demonstration piece.
Old 05-20-2018, 11:46 AM   #18
EivlEvo
What parts do you need? I have an M47 lying around here...
Old 05-21-2018, 01:40 AM   #19
JohnLane
M-47 uses needle bearings between the gear and mainshaft doesn't it?
The old ones with bushings between gear and mainshaft would pop out on decel when the bushing got worn.
Old 05-21-2018, 06:03 PM   #20
SenseiRice
It's out of an 88 so I think it's an m47II
Old 05-21-2018, 06:04 PM   #21
SenseiRice
Sounds like I may be looking for a whole m47 lol
Old 05-22-2018, 10:57 PM   #22
JohnLane
Originally Posted by SenseiRice View Post
Sounds like I may be looking for a whole T-5 lol
Fixed that for ya.
Old 05-23-2018, 06:47 PM   #23
SenseiRice
Fixed that for ya.
Hell I'd love too lol, but does an NA redblock with a cam really warrant a t5.
Old 05-23-2018, 06:48 PM   #24
SenseiRice
Don't know if this adds any insight to the problem but when I go back into 3rd after it pops out it grinds but doesn't grind any other time. Also I notice a pulsating vibration in only 3rd and 5th gear.
Old 05-23-2018, 06:53 PM   #25
EivlEvo
I have an M47 off of my old car if you're after one. (Don't recall if I mentioned) it ran great, shifted smooth etc. It is however missing the bell housing and the shifter is removed. Thus... it would be useful to someone like yourself, but not to someone looking to convert to manual.
Shipping seems complex, but... I'm not opposed to attempting (I'm in NC)
