Old 05-15-2018, 12:45 PM   #1
clintsnow
Default Where to buy new rear coil springs?
Ď89 244
Iíve had some rear suspension noise for quite some time now. Iíve replaced all the bushings and the shocks and still getting noise from the back of the car, basically around the rear passenger wheel well when going over bumps. Itís kinda like a creaking sort of sound. I was told by an employee at IPD that itís possible that itís the rear springs causing it so Iím interested in replacing them, but I donít know where to buy them from. IPD only sells the overload springs which are more than I want to spend and not necessary for my daily driver. I see a lot of aftermarket ones online, but wanted to see if anyone has any recommendations here. Just want something close to the stock ride.
clintsnow is offline   Reply With Quote
Old 05-15-2018, 01:02 PM   #2
culberro
culberro's Avatar
Moog CC215 are a stock replacement rear spring. Dirt cheap.
You may want to find the spring isolator as well, it’s the rubber donut that goes between the spring and the upper perch.
Old 05-15-2018, 01:07 PM   #3
clintsnow
You may want to find the spring isolator as well, itís the rubber donut that goes between the spring and the upper perch.
Perfect, thanks!
Old 05-16-2018, 08:47 AM   #4
240240
Is Always crushing it
240240's Avatar
Buy wagon overloard springs, put them on your 244. No regrets when 4 adults are ever in your car
240240 is online now   Reply With Quote
Old 05-16-2018, 11:28 AM   #5
KeizerBrickGuy
Sh*t pot stirrer
KeizerBrickGuy's Avatar
Moog CC217 rear springs, for a wagon
-Stephen
#mclovethesenuts
