Old 05-16-2018, 01:08 AM   #1
matt b
Default Overdrive wiring question
Trying to avoid having to re-do things when I'm on a limited timeline.
My Amazon is taking a long road trip tomorrow (Tucson, AZ to Austin, TX). I am wiring up the OD for the new owner and using the following diagram (using a 240 relay).
I have a wire going to my solenoid, I understand that it plugs to my #87 prong on the relay.
I have two wires going to my 4th gear lock out switch on top of the transmission, does it matter which is used as a ground and which is wired to my #85 prong ?
My switch is a simple momentary switch to avoid issues. Seems like it will connect to prongs 15 and 86, no apparent issue there.
Thanks
Old 05-16-2018, 01:26 AM   #2
No, it doesn't matter which terminal you ground and which one you connect to the relay.
Old 05-16-2018, 01:37 AM   #3
matt b
Thanks Ian. Looks like it's good to go.
I'm envious of the road trip even if it's hot, and I want the car to be 110% ready. I'm being a little neurotic.
