Old 05-16-2018, 10:05 PM   #1
thelostartof
unbalanced chemical
thelostartof's Avatar
Default 7/9 failed clutch master or slave cylinder test?
So while driving home today I go to step on the clutch and the pedal goes full soft and to the floor, lucky me I was already moving and in 2nd gear so I rev matched and put it into 3rd and made it the entire way home in 3rd.
So I now have a hydraulic clutch pedal that goes to the floor dull sof when I step or push on it. Feels like the MC isn't even there, is this a sign of a failed master ? My slave looks fine but I have not had a chance to have someone step on the clutch while I am watching.
Ideas or things to check?
Old 05-16-2018, 10:18 PM   #2
Pull the dust boots on the master and slave back and see if there's any fluid behind them. If there is, it's bad.
Old 05-16-2018, 11:52 PM   #3
thelostartof
unbalanced chemical
Ok i will check tomorrow if I can find some time. I had someone stop by and it looks like while pressing on the clutch the slave piston is moving but just barely, almost looks like the boot is swelling so I guess a good chance the slave cyl has blown out again.
Old 05-19-2018, 01:08 PM   #4
eeaves42
eeaves42's Avatar
Cable swap?
"never give up never surrender"
1996 Volvo 960 Wagon
2002 Saab 95 Linear Wagon
1999 Mercury Grand Marquis
Feedback
http://forums.turbobricks.com/showthread.php?t=205098&highlight=eeaves42
eeaves42 is offline   Reply With Quote
Old 05-19-2018, 03:04 PM   #5
When the fork and/or pivot pin is worn out, the travel can be too much and cause fluid loss. Just an idea.
Old 05-20-2018, 03:47 PM   #6
thelostartof
unbalanced chemical
Well I found the cause of my failure.
I took a spare piston out of an old slave and installed and an I am still getting a dead pedal so good chance I blew out the master also. Either way I guess I will be ordering a new master and slave combo.
