Old 11-11-2019, 01:47 AM   #26
IansPlatinum
IansPlatinum's Avatar
Repainted bottom coils where I had sandblasted
Sewed some limit straps from 850 seat belts. Tex 105 should be fine
Only had 3 anchors, so one limit strap loops around the long spacer on the shock. I added some bartacks for extra strength.
Axle going in
Full articulation
'96 854 Platinum - "Trusty"
'92 245 - "Boat"
'71 145 - "Rusty"
Previous:
'73 1800es - "Sunny"
'92 940T
'98 S70 T5
'99 S70 GLT
Old 11-13-2019, 05:59 PM   #27
TempleUWS6
TempleUWS6's Avatar
Stunning work!
'90 245 340k mile DD
'79 242DL
'02 Trans Am WS6-Konis+Stranos, full exhaust, 353rwhp/373rwtq, Fikse FM5
'76 BMW R75/6
TempleUWS6 is offline   Reply With Quote
Old 11-19-2019, 02:22 PM   #28
brickcupra
Default rear axle !!!
Hey I've heard about the dana lock form the 740 s and 940 s fit into the 240 rear end pumpking housing, Right or wrong?
I see you lost the rear right reverse cover on the tail. I am doing a used and new tails in mine plus a million things.
Looking good in your project. Mine is coming along well after almost 12 days in a row working weekends and afternoons
Take care
DZ
Old 11-19-2019, 02:32 PM   #29
IansPlatinum
Take care
DZ
I think you're right, there's been several how-tos on swapping to a g80. I chose the trutrac.
I have the tail light cover, just removed it because it was loose, and needed regluing. It's back on there now.
Old 11-21-2019, 10:00 PM   #30
jmc0369
jmc0369's Avatar
Nice work. Looking forward to seeing it all properly lifted. If I could convince the Mrs. I'd ditch the Tacoma for a lifted 245 or 965.
Member: TBCCS
"Emancipate yourselves from mental slavery; only ourselves can free our minds" - you know who!
"It is no measure of health to be well adjusted to a profoundly sick society" - Jidu Krishnamurti
jmc0369 is offline   Reply With Quote
Old 12-01-2019, 12:30 PM   #31
IansPlatinum
Casualties so far include a sticky EGR valve (will delete soon) and frozen water supply. I didn't realize how much 8200 ft elevation affected baseline intake vacuum measurements too. Normally idles at 20 in Hg in Texas, that turns into 14 in Hg at 8200 ft. Tires inflate more too... had to let some air out to get better traction. Despite a weird whine while turning & coasting, the truetrac seems to be doing it's thing.
Doggo is loving the snow
Old 12-01-2019, 02:02 PM   #32
brickcupra
Default Hey !!!
Kinda a bit far up from Texas ,Aren't you? lol. Looking good
Take care and enjoy the RIDE!!!!
DZ
Old 12-02-2019, 10:32 PM   #33
IansPlatinum
Driving uphill (7% grade) @ 11,000+ ft really pushes the b230f to the limits.
Intermittent starting issue now... sometimes I'll get no response when I go to start, no click or anything. Sometimes it'll turn over, and right as it's about to catch, it stops. Seems like a failing starter to me. I've already jumped the neutral safety switch, it's not the problem. Swapped computers too, no dice. Right now the solution is just to wait, then it starts right up. Hope I don't have any chewed up flywheel teeth
Old 12-09-2019, 01:43 AM   #34
IansPlatinum
OHV park went well.
I got a kick out of everyone pointing at the wagon on the trails.
Old 02-09-2020, 11:56 PM   #35
IansPlatinum
Added butyl dampening and fat mat to the underside of the hood. Butyl to cut down noise ( I didn't notice a difference), fatmat to keep some heat off the hood and protect the paint, and reduce noise a bit.
Old 02-16-2020, 09:37 AM   #36
IansPlatinum
Old 02-16-2020, 10:28 PM   #37
IansPlatinum
The camp spot
Some findings at the camp spot
Ended up turning around at this stream, not having a map and not knowing how much further the trail went. The trail was definitely side by side width, with a little evidence of jeeping. Speed was limited to about 5 mph because of the rocks and brush. Reverse gear was giving me issues too, and crossing the stream and coming to an impasse would mean having to drive in reverse across the stream which would have been bad news for the 250K aw70.
Also had my starter (or related wiring??) give out on the way back. I measured full voltage from negative battery terminal to positive starter terminal, but only 10V from the spade connector to the negative battery terminal when trying to start the car...
Guess I have some ohm testing to do...
Old 03-27-2020, 09:23 AM   #38
IansPlatinum
Got a chance to knock out some little things:
Stance simulation via jack stands:
That's about 2" added front and rear, for a total of about +2-3" front and +4" rear. Rear would be accomplished with eibach 20" long 125lb springs. Front would require Ben's coilover's. Planning on 100-125# in the front
I think I'd still have about 5" of droop in the rear and around 3-4" in the front
Also got to install a USB charger voltmeter, freeing up a gauge slot for something else
Ipd poly bushes for stock bar with some zerks
And another idea cooking - removing center vents in favor of two smaller ones opening a middle slot for a sixth gauge. The vents will require some trimming but seem like they'll drop right in once they're the right size. I'll have to find a good way to secure the gauge in place, but I've got some ideas
Old 03-28-2020, 03:15 PM   #39
IansPlatinum
Getting close...
Old 04-01-2020, 09:51 PM   #40
IansPlatinum
PSA: if you think your car is rust-free, you're probably wrong
Found a couple tiny spots underneath the driver's & passenger's butyl damping sheets. About half the butyl damping in the car was completely brittle and not adhered to the primer. I scraped what I could up, and am contemplating heating up the rest and going ahead with removal, to be replaced with new butyl damping sheets. The brittle nature tells me that they are no longer doing their job, and boy would I love this car to be quieter. Also found one of the floor plugs had popped up... gonna be a few weeks before I get this finished
Old 04-09-2020, 12:11 PM   #41
mrcarter
Wow I'm so impressed with your attention to detail and patience, giving that 240 the love it deserves! Curious to see how your soundproofing endeavor goes. My car is very loud on the highway and I would love to find ways to remedy that since I like roadtrips!
1989 245 (3rd generation owner)
1986 744 TI
Santa Barbara, CA
mrcarter is offline   Reply With Quote
Old 04-16-2020, 10:20 AM   #42
IansPlatinum
Mucho gracias
I'll be putting stuff back together until I have all the supplies gathered to do the soundproofing the way I want to do it. Probably around May or June
Old 04-16-2020, 10:22 AM   #43
IansPlatinum
Boat got a wicked schweet awning yesterday
Old 04-16-2020, 12:14 PM   #44
Vol242vo
Keep it clean...
Vol242vo's Avatar
That's a great addition!
Derek
1980 242
-Project Thread-
Follow on IG: @vol242vo
Old 04-19-2020, 07:15 PM   #45
LC4CARL
Aero challenged
LC4CARL's Avatar
Great build. How do you like the EBC pads?
@PDXvolvo on IG
Life begins at 10PSI.
Old 04-20-2020, 04:22 PM   #46
IansPlatinum
Thanks!
I honestly cannot tell a difference
They dust just as much as the OE pads (a bit peeved about it), and don't have any different brake feel than OE.
I got them hoping to get a high quality grippy pad with less dust, but oh well. My calipers aren't showing any evidence of dragging either.
Old 04-21-2020, 08:24 AM   #47
IansPlatinum
More ouachita camping last weekend, this time featuring the fiancee's XJ
Preparation:
Camp:
Trails:
Old 05-09-2020, 02:36 PM   #48
IansPlatinum
Soon
Old 05-10-2020, 04:03 PM   #49
Estateman
K-Jet or Bust
Estateman's Avatar
AW71? What happened to the one in there now?
88 245 - M46 3.73 Gears
>>FEEDBACK<<
Estateman is offline   Reply With Quote
Old 05-10-2020, 06:38 PM   #50
IansPlatinum
Yes aw71 from cool weather pnw, supposedly also has the tailshaft bearing. The aw70 is just giving in due to 250K miles of use and abuse in a hot climate
