Old 07-29-2017, 01:44 PM   #1
Johann245
Volvoholic
Johann245's Avatar
Default 94 945 Turbo rough to start
Went and bought this '94 turbo the other day. Rough to get it to start, then when it starts it will idle normally. Any slight amount of throttle it dies or if I let it idle, dies after 20ish seconds. Maf or fuel pump/system related? 300k+ miles, cali car, stock.
Real Wood Trim
"Classic" Project 1993 Classic 245 with 29” BFG KO2s
Feedback
Johann245 is offline   Reply With Quote
Old 07-29-2017, 02:36 PM   #2
supreme940
supreme940's Avatar
Try unplugging the MAF and starting it
supreme940 is offline   Reply With Quote
Old 07-29-2017, 02:42 PM   #3
Johann245
Volvoholic
Johann245's Avatar
I'm on my way out there now.
Old 07-29-2017, 04:46 PM   #4
Johann245
Volvoholic
Johann245's Avatar
Swapped out mafs, unhooked battery for a awhile. Still will only accept q tiny bit of throttle once in a while and surge. There is only one pump on the '94 with just a filter under driver.
Old 07-29-2017, 04:48 PM   #5
Johann245
Volvoholic
Johann245's Avatar
Going to pick up a cheap pump for now and swap in, see what happens.
Old 07-30-2017, 01:46 AM   #6
John242Ti
LH-Jet & Carb Free Zone
John242Ti's Avatar
Sounds like maybe another '95, but with the 760 headlamps.
1994 should still have the dual fuel pump setup.
-J
@1982_volvo_242_turbo on IG
Old 07-30-2017, 05:29 AM   #7
nordmaschine
forced instruction
nordmaschine's Avatar
Yup, '94 - dual pumps.
'95 - mostly single. Mostly. '96 - '98, single pump.
Jetronic is romantic.
Whiteblocks
Old 07-30-2017, 10:04 AM   #8
Stalls when revving sounds like an air leak. Pull all the hoses and carefully inspect them.
Old 07-31-2017, 10:59 PM   #9
Jimmy E. James
Pull the vacuum hose off the pressure control reg before you start your way down the wild ass parts hang guessing games rabbit hole
Seriously, check that first
Jimmy E. James is offline   Reply With Quote
Old 08-01-2017, 03:50 AM   #10
jerryc
jerryc's Avatar
If someone took out the main pump next to the filter, which is unlikely but possible, there wouldn't be enough pressure for it to run. In any case, check fuel pressure IMO. 94 as said should have two pumps. Maybe someone put in a Walbro intank and it's failing?
What's the female equivalent to a dick pic? twat shot?
There isn't one because dudes aren't grossed out by unsolicited vaginas.
jerryc is offline   Reply With Quote
Old 08-02-2017, 08:58 AM   #11
Johann245
Volvoholic
Johann245's Avatar
I'm blind I guess. Didn't see pump past the filter underneath.
I first swapped in a cheap new intank. Still nothing. Then swapped main with my old one from my classic. Fired right up. Drove it home.
Old 08-02-2017, 05:30 PM   #12
John242Ti
John242Ti's Avatar
Cool.
-J
Old 08-02-2017, 05:51 PM   #13
I'm confused. How did you know the main pump was bad?
Old 08-02-2017, 06:34 PM   #14
iHateVolvoPeople
He replaced it with one that worked, then drove the car home.
Feedback Thread
Current:
'93 244T M47
'95 Camry A140E, 254k
'99 Camry A140E, 256k
Old 08-02-2017, 08:37 PM   #15
James10952001
That's exactly how my megasquirted 242 behaved when a wire came off the fuel pump relay. An engine will start and idle for a surprisingly long time on residual pressure in the line or the flow from the pre-pump.
James10952001 is offline   Reply With Quote
Old 08-02-2017, 09:38 PM   #16
Johann245
Volvoholic
Johann245's Avatar
Wasn't priming with key nor with a jumped fuse. The relay was clicking. Obvisouly ive got spark because it was starting, my air was known good by swapping mafs. Last thing I need is fuel.
Old 08-03-2017, 02:48 AM   #17
John242Ti
John242Ti's Avatar
It's also how my old silver K-Jet 242Ti behaved when the main pump crapped out on Union Hill Rd in '01. Start, run at a random unstable idle for about 15-20 seconds, then die.
Old 08-03-2017, 10:23 AM   #18
Good test. I understand now.
