Old 06-12-2018, 10:22 PM   #1
niquemarshall
Default Front end knock in 940 & driver side strut is stiff
Recently my 940 started knocking and clicking when going over bumps and uneven terrain. When applying the brakes, theres a rather loud "klunk" when slowing at low speeds. Its seems to coincide with the front end leaning, so if you pump the brakes, it will occur again and again, like a "ka-klunk"; this seems to be more pronounced in turns than anything. Also noticed when the wheel is turned to the right, the driver side corner is very stiff, as if it were a coilover. The passenger side bounces fine. Driver side will bounce if wheels are straight, but not if wheels are turned. Otherwise the car rides fine; this is an intermittent issue. Any ideas?
Cone bushings replaced in November (ipd blue)
Endlinks replaced in December
Ball joints replaced in 2016
niquemarshall is offline   Reply With Quote
Old 06-12-2018, 10:52 PM   #2
white855T
Recently dealt with the same issue. The strut mount bearings were binding. Once I replaced the bearings, the issue has now gone away. The strut mount could also be bad as well. The rubber will separate from the mount. I went ahead and replaced strut mount and bearings on both sides.
These are the parts I used because I had them already from another car.
https://www.fcpeuro.com/products/vol...40-960-s90-v90
Buyer/Seller Feedback
Old 06-13-2018, 10:43 AM   #3
niquemarshall
Any tips on replacement? Or pretty easy
Old 06-14-2018, 01:03 AM   #4
Bready
board deviant
Bready's Avatar
Find out what the actual problem is. May be a strut mount bearing, may be a ball joint - and take it from someone who had one fail while driving a 940 you DO NOT want that to happen.
If you want to fix stuff yourself at least get a proper diagnosis first. The ball joint is a cheap repair for most shops to do, the bearing shouldn't be too bad either.
Originally Posted by ErikS View Post
Eat the dog, shove the gold up my ass, and move to Canada.
Keep your minds out of my pants.
http://math.350.org/ http://www.rollingstone.com/politics...-math-20120719 MUST READ!
Old 06-14-2018, 05:03 PM   #5
niquemarshall
Yeah I dont think it's the ball joint because those made different noises and showed different symptoms when they went bad. That's why they were replaced in 2016
Old 06-14-2018, 05:06 PM   #6
white855T
Quick Google search yielded this... https://www.google.com/amp/s/blog.fc...%3fhs_amp=true
