beatyourvolvo518
- Jan 11, 2020
Hey I was just wondering if anyone out there knew the power numbers for the 16 valve heads vs the 8 valve and any weak points that come along with them.
There are way too many variables to answer that question.
Well if the car was naturally aspirated with all oem parts with 130 ish thousand miles. a ballpark number even if its ridiculous. its a 1990 740 sedan if that helps.
Which do you prefer, more head flow or less?
16 valve heads are stupid
What did your wagon end up doing again?
Mine made 270 at the wheels on 10psi. With a shortened 16valve intake manifold and a heedspeed j pipe exhaust manifold.
The fitment bull**** on my car was all 240 related. In a 700/900 where the intake manifold was designed to fit you wouldn?t have these problems.
The understanding is that the first limit you really run into mechanically is the intake manifold before the cylinder head on an 8 valve head. Now stock for stock the 16 valve does flow more but for all the work required to fit a 16 valve head you could get a decent intake manifold that would probably negate any of the advantages swapping heads would accomplish.
0-350whp - built 8v
350whp+ - something that isn't a 4cyl
0-350whp - built 8v
Post up some dyno numbers, brah
I'd tweak that slightly and say:
stock - 300 hp - 8V
300 - 400 hp - 16V
400+ hp - something that isn't a 4 cyl
[snip]
