Old 12-10-2017, 08:39 PM   #1
daijoubanai
waste of skin and blood
daijoubanai's Avatar
Default I put a Honda Civic tach in my 240
So my 240 tach stopped working, and instead of spending the money on another one, I'm cheap and spent even less on one from a honda civic since its about the same size.
I figured with some minor trimming it should fit, and hooking it up should be easy. I used the power and ground from the cluster, and the tach signal I'm getting from MS.
Was it worth it? Probably not. It took my a couple hours, and I could have just paid a bit more for an actual 240 tach. But this was cheap, and a learning experience.
Comparison.
after some dremel work
had to modify the cluster a bit for the tach circuit board.
All wired up
back plate on
installed and working
checking it with tuner studio at different rpm, to make sure its accurate. And it is.
daijoubanai is offline   Reply With Quote
Old 12-10-2017, 08:44 PM   #2
LeedomtoFreedom
LeedomtoFreedom's Avatar
Nice job, I like little things like this. Notice any difference between the two, maybe the honda tack keeps up with the revs quicker than the 240 one.
Old 12-10-2017, 09:19 PM   #3
DrHutch
That's pretty awesome. Was this out of an EK civic?
DrHutch is offline   Reply With Quote
Old 12-10-2017, 09:25 PM   #4
daijoubanai
It was. It was one of the cheapest on ebay, so its what I went with. I think the EG tachs are pretty much the same size, and would have also worked.
Don't know to be honest. My 240 tach hasn't worked in so long I don't even remember.
Old 12-10-2017, 09:28 PM   #5
Broke4speed
Broke4speed's Avatar
Ok, now THIS is the **** I like.
Good job!
Old 12-10-2017, 09:32 PM   #6
cwdodson88
Pic of installed and operating shows 900 rpm, tuner studio shows 1773, so are the pics lying? Or were the two pics at different times?
The Build Thread
SVEA - PUSHROD TURBO!
cwdodson88 is online now   Reply With Quote
Old 12-10-2017, 10:01 PM   #7
brian smith
Does it exhibit the better damped needle of a more contemporary tachometer, or simply a functioning replacement?
I disliked the Volvo tach so much I put the darned clock back in and used a 2 1/16" Spek in the 3-hole spot.
the howdeedoo:
Old 12-10-2017, 10:05 PM   #8
tryingbe
Boosting along.
tryingbe's Avatar
Good job!
85 GLH 367whp
00 Insight mpg > yours.
Old 12-10-2017, 10:20 PM   #9
daijoubanai
honestly I don't remember the original tach really having a problem. I haven't really driven around yet with this in so I'll update how it is.
I was wondering if someone was going to mention that. But yes it was different times, I just didn't bother uploading the other image. It was more to say that I checked it at a range of different rpm to check for accuracy. Just to make sure I didn't have to mess with the tach calibration or anything.
Here it is though.
Old 12-11-2017, 11:28 AM   #10
propav8r
F*ck Edgar
propav8r's Avatar
That's a pretty cool look. Looks like the finish on the gauge face is a good match too. A little orange paint on the needle, and it would almost be unnoticeable!
Originally Posted by Hockey930
Jb welding tiny pieces of a fuse to the injectors seems to have worked perfectly
Originally Posted by Quin
i improved my life by just getting rid of my 940
nipple farts
My Project
K-Jet to Megasquirt Article
Old 12-11-2017, 12:21 PM   #11
cwdodson88
Now swap the speedometer face.
Old 12-11-2017, 12:59 PM   #12
Thumbs up.
Old 12-11-2017, 02:07 PM   #13
Ursan
Bored Member
Ursan's Avatar
how psi a stock can support?
I admit I'm stupid...
Old 12-11-2017, 02:50 PM   #14
J_Jones
J_Jones's Avatar
Very neat. What did you use to hold the tach to the cluster?
Old 12-11-2017, 02:55 PM   #15
Mueller
Mueller's Avatar
Looks good, I like.
Old 12-11-2017, 04:56 PM   #16
240240
Poobacca wil survive 2020
240240's Avatar
Looks good, now swap engine
Originally Posted by bobxyz View Post
I'm sure glad that our mods are protecting us from excess poop in these trying times of TP shortages....
Shoot the poop!
Originally Posted by centason View Post
I WANT TO BE HIRED BY 240240!!!
"e-gay"
Old 12-11-2017, 06:11 PM   #17
daijoubanai
Well, when I trimmed it, it just so happened to stay mostly in place by itself. Though I realized with vibration it could pop out. Between the back of the gauge circuit board and the black back cover, I just put a small piece of foam which adds just enough pressure for it to not move.
too much work/money. Though I'd be totally down with it.
Old 12-11-2017, 06:37 PM   #18
So what type of rpm signal does this tach use? Would it use the same signal as the VDO original tach?
1982 242 turbo. 340k miles. MVP coilovers and 3" exhaust. Flowed 405 with a V15. Cossie turbine housing with upgraded compressor housing. 90+, IPD remote oil filter. Some other goodness, too. Been lots of fun over 25 years. Restored in 2k. Now ready for a 2nd restoration.
Old 12-11-2017, 06:48 PM   #19
tryingbe
Boosting along.
tryingbe's Avatar
Signal from Microsquirt.
Old 12-11-2017, 07:28 PM   #20
Broke4speed
It uses a square wave, 5 or 12v. The original tach used a flyback voltage spike from the coil. At least I think that's what it's called. Most modern cars have been using a square wave for decades, so their tachs integrate nicely with aftermarket engine management.
Old 12-11-2017, 07:28 PM   #21
daijoubanai
This. I figured I could get the signal I needed anyway because of MS, but as you can see in the picture of the laptop it was pretty straight forward.
The original signal on the civic comes from the distributor, as well as most honda's since at least the late 80's, so if you don't have MS, it probably wouldn't be difficult to do this.
or this I guess.
Trying to get the signal from the coil like the 240 originally does probably wouldn't work, which is why I didn't try it.
Old 12-11-2017, 09:41 PM   #22
Thanks I was wondering about that signal. That may be something to do when some type of the squirt family of injection is installed on my turbo. Looks great in there. My interior is blue in my turbo so it would be a nice little blue touch.
Old 12-11-2017, 10:05 PM   #23
M.H. Yount
M.H. Yount's Avatar
Is there a switch of some sort that allows the choice between a 5V or 12V signal?
Old 12-11-2017, 10:59 PM   #24
Broke4speed
No, I just don't know the exact voltage used, lol. It's either 5 or 12.
Old 12-12-2017, 06:54 AM   #25
M.H. Yount
M.H. Yount's Avatar
If it went in without a 'resistor' adjustment, it's likely set up for a 12V signal just as the VDO tach was. When I hooked up the LS ecu output (5V) to the stock Volvo/VDO tach without any adjustment, it read WAY low. Had to "T" in another 12V connection through a 1000 ohm resistor.
Don't know my Civic nomenclature -- what year did the tach come out of?
